01-30-2010, 07:52 PM | #1 |
| 1BJBs 86 4Runner 3/31 shake down run @ Raush Creek pics
SO I have had probably 80% of the parts needed to SAS my runner but had several set backs...No one to weld, no 220 outlet, no welder, bad birfield etc... I put in an order with TG on Monday for 2 new 4330 better then stock birfields, backing plate eliminators, ARB air compressor, 4.88 gears, solid spacer, bearing kit etc...Had the the birfields and backing plate eliminators 3 day mailed and started working on the axle last night. Everything came together this week, got a 220 line dropped in, found people to weld and friends to help Sure enough, I put the new TG Birfs in all my problems went away. I was having this weird issue that when I installed the marlin one, only on the drivers side...soon as I put the spindle on the entire axle would start binding and it would get worst the more you assembled it. I called marlin they said theirs are beefier then stock and I need to clearance the knuckle ball...I thought this was weird because the other one fit perfect on the other side. I had my step dad's friend's machine inspect it and its only .002 larger in over all out diameter over stock. All the other measurements checked out as well so the only thing we could assume is that the bearings inside are bad...kinda sux cause they were NIB :? when I got them from my friend with the axle. Anyways, I started cleaning up the frame last night I took the truck to my Step dad's friend shop and he welded the front hanger and tubes in for me, I then headed back to my garage and started tearing down While I dissembled my friend Joe welded on the plate on the drivers side perch Dropped the steering links Cut the torsions bar and removed the upper A arms Front spring perch Shackle tubes and plated frame hole My buddy Wade working the torch Myself working the torch Lighting my balls on fire...NFG Yeah, they are still there.... IFS IS OUT! Long days work...started at 7 am starting to grind stuff down and my friend Joe snapped this while I was acting like an asshole pretending to pissing on the IFS crap be tomorrow we are starting at 7am again, have to finish cutting some stuff off and grinding everything down. Then we have to weld in the motor mount plates and then we can installed leafs and slide the axle under Stay tuned -Mike Last edited by 1BadJeepBruiser; 01-30-2010 at 07:58 PM. |
01-30-2010, 08:04 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
| http://www.sky-manufacturing.com/new/ check him out for any thing you may need
01-30-2010, 09:05 PM | #3 |
Built, not bought Join Date: Oct 2004 Location: Gresham
It's about time you got somewhere on this. Glad to see it's starting to come together for you. |
01-30-2010, 09:26 PM | #4 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
Looking good, figure out how you are running your front brake lines without the backing plate? I cut my backing plates down, so I could use the stock brake line mounting bracket as you can see in this picture http://www.turtlecrawler.com/toyota/...s/P1010878.jpg I would have been hanging that axle up tonight, and finish grinding and welding the frame up tomorrow, just to see the axle under the truck |
01-30-2010, 10:41 PM | #5 |
Looking good Mike, I know you have been waiting a while for this. |
01-30-2010, 10:48 PM | #6 |
Quarry Creeper Join Date: Jul 2009 Location: West GA, USA
No turning back now! Lookin good man. |
01-31-2010, 06:31 AM | #7 | |||
Heading out to grab a coffee and some breakfast then its back into the garage | |||
01-31-2010, 07:48 AM | #8 | |
http://www.pirate4x4.com/forum/showt...ine+welded+arm http://www.pirate4x4.com/forum/showt...ine+welded+arm http://www.pirate4x4.com/forum/showt...ine+welded+arm http://www.marlincrawler.com/hardwar...line-mount-set | |
01-31-2010, 10:17 PM | #9 | |
Rock on dude, I am definitely just going to cut my stock backing plates and bolt it to the caliper, that is easy enough Here are todays pics Went at the frame with two grinders While Wade and I were grinding Joe welded the bump stops up for the u bolt flip Joe doing work with the welder, welded in the motor mount supports Some last minute inspecting before hanging the shackles Hanging some shackles Hanging the leafs Ready for the axle now Axle slid under Time for the shock hoops Me fighting with the lower shock mount Wade was pretty upset that i got over spray on my steering links, so he went at it with some toyota brake cleaner Look at those silly 31s All finished up...was a long weekend but it went really really well. Everything is done except for the brake lines and steering stabilizer...we didn't realize you have to weld a new bracket it for the new one and had already put the welding stuff away all neatly :? Gotta pick up some new calipers, truck had been loosing brake fluid a little bit over a long period of time...finally saw it was coming out of the caliper. tomorrow I am going to drop the tank and get started on the rear stuff for now its rolling again thanks to help of a few good friends Thanks for looking -Mike Last edited by 1BadJeepBruiser; 01-31-2010 at 10:46 PM. | |
01-31-2010, 10:26 PM | #10 |
Looking good Buy calipers for a 94 4runner with a v6, they are larger then the calipers you had. Any v6 caliper will do, just easy to tell them you have a 94 Give them your old 4cyl calipers as cores, they won't know the difference. But bring the cores in later, side by side you can see the difference. I am not running a steering stabilizer, don't feel I really need one. Might help a little, but its not critical to get it on the road. And it looks like you could have used some flap wheels for the final grinding I use those for grinding, and finish work all the time. Hardly touch grinding discs, its either a cutting wheel or flap disc. They run $5-10 a disc depending on where you buy them, Harbor freight sells the Norton wheels for $5 a pop, everyone else sells the same wheel for $10 or more. |
01-31-2010, 10:29 PM | #11 |
Trying to have Fun Again Join Date: Apr 2006 Location: In your fridge stealing a beer
Looks good Mike. I picked up a 85 4-runner that I plan to do a trail gear lift on. How much lift did you go?
01-31-2010, 10:36 PM | #12 | |
I went with the 3" kit, A lot of people seem to do the 4" but I didnt want it to be insanely tall...plus I only want to run 35s...Most say that the 3" kit is really equivalent to a 4+" inch lift between the front hanger bar and the shackles. Truck seems HUGE to me now, the springs will settle a lot I am sure...but it will definitely clear 35s with no problem | |
02-09-2010, 08:56 PM | #13 |
Last Friday I yanked the rear out of the 4runner I dropped the tank out as well, I just had this feeling that welding near it with it in the truck was a bad idea...when I went to pull it down I discovered that the main fuel line was actually rotted out and was seeping through Good thing I pulled it.. Rear suspension came apart real easily...even the 2pc shackles which NEVER come apart usually came apart I also finished up a few last things on the front of the truck. Using Etype's links to Pirate I found a clever way of securing the front brake lines using the stock mount part from the original backing plates As per Etype's advice I also upgraded to v6 calipers (bigger) and installed factory brake pads, shims, and hardware Also got the steering stabilizer in My friend Joe tack'd everything in place, then we checked shackle angle and sunday my Stepdad's friend George came by and fully welded everything in Its rolling again Today I ordered these http://www.4wheelparts.com/Tires/BF-...0697&t_pl=6396 and these http://www.4wheelparts.com/Wheels/Ro...21&t_pl=101829 Also grabbed a lock right from them as well for the rear. Next up is to get the tank back in (getting boiled out and cleaned), hook up rear brake stuff, then get the drive shafts made up and the rear gear set and locker done. Also have a set of Marlin sliders for it too Its getting there...More to follow -Mike Last edited by 1BadJeepBruiser; 02-09-2010 at 09:00 PM. |
02-09-2010, 09:06 PM | #14 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
Looks good, One of these days I'll have a shop and will do a nice trail truck too.
02-09-2010, 10:05 PM | #15 |
Pebble Pounder Join Date: Oct 2006 Location: Ogden, Utah
Looks great, but your spring hanger gussets are on upside down... I would also recommend gusseting the back of the hanger to the frame too.
02-10-2010, 12:14 AM | #16 |
Quarry Creeper Join Date: Nov 2004 Location: In the saddle...
God I hate taking apart those rusty shackles. We did this when we swapped leafs on my Buddy's '88 pickup and it was a nightmare. Granted it was pouring rain and we had to make it to inspection by closing time the same afternoon. Looks imposing, but needs the bigger tires. Good choice with the Mud Terrains btw. Last edited by radishkid; 02-10-2010 at 12:18 AM. |
02-25-2010, 07:48 PM | #17 |
4Runner is drivable again, not wheelable yet, but its getting there. I borrowed my moms 35s off of her rolled Tacomer to get an idea of what it will look like with 35s on it. Drove it to work today, did a brake flush on it, stops good now also did an alignment...took all of 5 minutes More to follow |
02-25-2010, 07:54 PM | #18 |
Rock Crawler Join Date: Mar 2007 Location: babylon, long island ny
looks awsome mike! that sas came out sweet! |
02-25-2010, 07:54 PM | #19 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Bigger!!!!! Looks like room for 36's maybe 37's to me. You got wheels with more offset then that right? |
02-25-2010, 08:15 PM | #20 |
Looks like you cut your rear fenders, how did that go for you? looking good |
