06-22-2012, 03:46 PM | #21 |
| Re: Toyota Engine options I have 21 out of my 22re, i don't think i'd be getting that once i swapped to a v8, probably about 15...or does the weight of the toyota make that much difference?
06-22-2012, 03:52 PM | #22 | |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Toyota Engine options Quote:
i think i would get better mpgs if i dropped a sbc in the darn thing. | |
06-22-2012, 03:52 PM | #23 | |
Best I ever got out of a 22r was 19 and that was milking it. | |
06-22-2012, 04:08 PM | #24 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
Swap a Nissan VG30 in it! I generally get 20 city and 25-27 highway at about 65mph in my little pickup. Plus, much more power then the 22re.
06-22-2012, 04:35 PM | #25 |
RCC Addict Join Date: May 2010 Location: Midwest
I'm working on putting a small block ford in mine... meh.
06-22-2012, 05:26 PM | #26 |
| Re: Toyota Engine options I was refering to this, catalog_product If you ever wanted more power its as easy as turning up the boost. |
06-22-2012, 08:23 PM | #27 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
I'm wondering why you don't list it on C's list and pass it off as a good rock crawler project like nearly every other individual (in this wonderful valley of ours) with a Toyota P/U on it's last leg.
06-22-2012, 08:25 PM | #28 |
| Re: Toyota Engine options |
06-22-2012, 10:20 PM | #29 |
RCC Addict Join Date: Mar 2010 Location: Yelm
Ignore my stupid carburator issues in this video, but here is my 4runner w/ the 350. lapisto1011090.mp4 video by Phillbilly1 - Photobucket Sorry for the link. I am video dumb. Don't know how to embed them correctly. |
06-22-2012, 10:59 PM | #30 | |
My 1992 22RE 2WD pickup got an honest 29 as a daily driver. I miss that truck | |
06-25-2012, 02:47 AM | #31 | |
I'd be lucky to sell the truck for 1500...got 2300 into it...and if i was to get anything else it be a newer toy or a mid 90's power stroke ('96 ex.cab short box preferably), and i don't just have 4 grand laying around to cover the difference. It was my crawler project, but i ended up getting a jeep commanche instead so i dumped some cash into keeping it as a good dd, as the truck is in good cosmetic condition for being 22 years old...i was going to sand it down and squirt some paint on it this summer but i think it'll be getting a powertrain overhaul instead | |
06-25-2012, 05:45 AM | #32 |
Well if you are going to go through with it stick with a 22re to avoid too much cost. The other "cheaper" option would probably be to find a wrecked S series from GM with the 4.3 and transmission. As for your tires, you got ripped off horribly or upsized dramatically thus killing your Toyota. Last edited by gdhknives; 06-25-2012 at 05:50 AM. Reason: i forgot to add something. |
06-25-2012, 02:15 PM | #33 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
I have had two sbc toys one 5spd and and one auto The auto was a 83 toy with a 350 and a turbo 400 trans with a adaptor to the transfer case. Hated that truck . The 5spd was a 89 with a built 327 with an adaptor to the stock toy 5sp loved that truck. the 83 I bought built. and the 89 I did the swap on had no problems with the ifs when I did my swap
06-25-2012, 07:54 PM | #34 |
Way back when, I had a '85 reg cab 4x4 SR5. 33" tires, 4:88 gears, TRD posi in the rear. The truck would get about 18 mpg on the freeways, probably 12-14 in stop and go traffic. The gears helped turn the bigger tires but they still strained the engine. It was so under powered I had a buddy with a 2wd S-10 pickup w/ the 2.8 and he was quicker!
06-26-2012, 02:18 AM | #35 | |
I'm pretty sure a $400 tire bill on my toyota is awhole lot better than the $3000 tire bill on my jeep... I don't see how you think it be cheaper to swap in a chevy 4.3 than an old carb'd engine w/out computer bs...i can always get a tbi kit and build up the v8 once i buggy out the toy, but an old carb'd v8 in a toy should/could get pretty good gas mileage | |
06-26-2012, 02:19 AM | #36 | |
06-26-2012, 02:53 AM | #37 |
it was a few years back but as I recall it was stock lift maybe a 2 inch max but im pretty sure it was not lifted. and i only had lil 31 swampers on it
06-26-2012, 11:05 AM | #38 |
Rock Crawler Join Date: Sep 2011 Location: truckee
Is this truck 2wd or 4wd? What did you replace suspension wise that was 600? Have you done a compression test? If it was me I would fix the known issues first. Then pull the valve cover and check out the timing chain guides. Replacing a timing chain on a 22r is about as easy as it gets, pull the radiator and there is plenty of room. A lot easier then an engine swap. |
06-26-2012, 12:15 PM | #39 |
Rock Stacker Join Date: Apr 2012 Location: Goodyear,AZ
Eff the 2jz swaps, if the motor was as good as its said to be why wouldn't japan have used it in their race cars.... use a 4.7 out of a new one or rebuild 22re. i have a 22re and they last forever. lcengineering has a ton of parts for the rebuild too.
06-26-2012, 01:27 PM | #40 | |
Toyota Engine options - Similar Threads | ||||
When you really should have a look at your engine... | Micropuller | Chit Chat | 18 | 04-10-2012 03:29 AM |
Engine | trickedoutTLT06 | Newbie General | 11 | 07-13-2006 06:34 PM |
Toyota engine question | chimp | Chit Chat | 4 | 05-23-2006 07:34 PM |
