06-26-2012, 04:55 PM | #41 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
| Re: Toyota Engine options
Carbed? V8? Gas mileage? Don't think so. You'll be looking at ~15 if you've got a solid engine and properly tuned carb.
06-26-2012, 08:11 PM | #42 |
| Re: Toyota Engine options |
06-26-2012, 08:27 PM | #43 | |
| Re: Toyota Engine options Quote:
Problem is, if i was todo just the timing chain and seen a potential issue or problem then i'd replace that, and it just snow balls like the tires and suspension did. Went to replace tires (we've got a tire machine), while it was up on jacks i noticed how scary sloppy the front end was (and yet it drove like a champ down the road), working on the suspension i noticed one of my cv boots was trashed and the joint was trashed as well, so replaced a drive shaft, then i noticed brake pads were shot... So i'd just start fresh with an complete rebuild if i was to keep the 22re, which would require me to pull the engine anyways, my tranny needs work so i'd pull it too. | |
06-26-2012, 08:48 PM | #44 |
Newbie Join Date: Mar 2012 Location: Winchester
Do a rebuild with a mild cam(RV style) and header. The 88 22re had different fuel injectors(impedance) and cold start injector time switch that never worked right. Ebay usually has some rebuilt infectors pretty cheap. Have you checked your shifter bushing? They wear out and cause the shifter to pop out under and off load. I too considered a v8 swap. But I decided to do a 5vz 3.4 swap instead. I put it in my 88 4runner and now it's in my 94 pickup. The 4runner required me to cut and move my motor mounts.I had to also relocate the exhaust to dump on the drivers side, get a v6 trans and adapter for my doubler. If you do go v8. Get a Ford. Not being biased, just the distributor is in the front. Makes for less firewall and hammer work. They 22re is and will never be a powerhouse but there pretty tough. a few that I thought should |
06-26-2012, 09:30 PM | #45 | |||
Only 6 cylinder i'd probably consider is the ford i6 Quote:
----- I'm not after info on which is easier and which is cheaper, i know this. I just don't know what issues i'll have when i swap out the engine. So i can consider the issues and possible solutions and costs of the solutions. I have a small junk yard to work with as well, we don't throw nothing away. So once again, i know what the path for the 22re rebuild is, but there is some fog on the engine swap road, i'm wanting that fog to be cleared up abit so i can make a more informed decision. I'm pretty sure if i can get it mounted, then all i'd need is a conversion radiator, exhaust, and fuel should be fairly easy for a carb...which should come in at a grand or less...but i may be missing something...from what i've read the ford 302 will bolt up to stock motor mounts and not cause alot of fitment issues (originally i was thinking a chevy 350 as they are cheap to work on and buy)... Thanks for your guy's input so far | |||
06-26-2012, 09:36 PM | #46 | |
No i haven't checked the bushing, i've been delaying dropping the tranny till i pulled the engine...is the bushing a common issue? | |
06-26-2012, 10:17 PM | #47 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
| Re: Toyota Engine options If it's like anything else you've built...buy, buy, buy!!!. Last edited by gdhknives; 06-26-2012 at 10:19 PM. Reason: corrections |
06-26-2012, 11:59 PM | #48 |
06-27-2012, 05:55 AM | #49 |
| Re: Toyota Engine options Austin, wow. That hurts so bad. I just feel crushed with your harsh words. If it wasn't your dad doing the building on the 1:1 I might be able to believe half the shit you put out. I find it amusing that you toss up a lot of bs on this forum and when you get called on it you start pouting. Now I will give you credit, you are smart as hell with electronics for the toys we have, but from what most of us that actually know you, that's it. Any other dumbass comments feel free to give me a call. I did start out by just giving my .02 but when you continually say ignorant statements based on Google, wikipedia, or your own appraisals, I will mess with you.
06-28-2012, 08:18 PM | #50 |
| Re: Toyota Engine options I don't believe it... Is that something you looked up online or is that something you've done the calculations on and figured on your own?
Toyota Engine options - Similar Threads | ||||
When you really should have a look at your engine... | Micropuller | Chit Chat | 18 | 04-10-2012 03:29 AM |
Engine | trickedoutTLT06 | Newbie General | 11 | 07-13-2006 06:34 PM |
Toyota engine question | chimp | Chit Chat | 4 | 05-23-2006 07:34 PM |
