08-07-2006, 04:12 PM | #41 | |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
08-09-2006, 07:01 PM | #42 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
You seem pretty determined to do everything the hard way! If you cut your Willys up lie you say you are going to, what is going to be left to make it a Willys? The point of starting with a classic is to have something left that resembles a classic. I think if you start with a YJ frame and frame only!, that your build will proceed farther, faster, safer and cheaper than if you mangle and needlessly reinforce and inherently weak frame. The YJ enjoys alot of popularity because it's versitile. You can run coils, leaves, or even 1/4 eliptical. Also you can run just about any engine/trans/x-case combo you want with adapters available all over the internet. From the sound of your posts (most of them angry retorts at those trying to advise you) you are pretty much building a beast with part of a Willys tub stuck to it, so why not make it easier on yourself. You will not comprimise the build by using newer model parts, that's basically what you're doing anyways. Trust me, you'll be a lot happier trying to make a newer model frame work than the old stamped rails. |
08-09-2006, 07:29 PM | #43 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
I think you should name it "What's punctuation?".
