09-16-2012, 11:21 PM | #41 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
| re: I got a 97' cherokee, now what lol
The red one is going to be the Renix, which while not horrible, can be a nightmare if poorly maintained. Rotten wires, bad connectors, improperly set up TPS, stuck IAC, etc, etc, and since it's pre-OBD, you can't just plug in a code reader and figure it out. Then again, if it checks out- runs well and the wiring doesn't look like its been butchered, then have at it. Just beware that Renix parts are going to be a lot more expensive than the Chrysler fuel injection system. As for the other one, check it out too. If it needs a radiator, you could drive him down on the price. A radiator, water pump, thermostat, and hoses aren't bad to replace. Only thing would be if you replaced the heater core, that would be a bitch. You have to tear the hole dash out and get at a bunch of nuts on the firewall behind the engine and such, with barely enough room for your hand. Shouldn't be too hard to check for a cracked head or if it's blown a gasket. |
09-17-2012, 12:27 AM | #42 |
Rock Stacker Join Date: Dec 2009 Location: Kansas City
even though it seems uve made up ur mind on a jeep, what civic were u thinking about? if u said 92-95 they are awesome. i had a 93 hatch. i loved it until someone did a hit and run on it and my wife blew the engine.... :/
09-17-2012, 01:17 AM | #43 |
RCC Addict Join Date: Oct 2007 Location: gervais
| re: I got a 97' cherokee, now what lol |
09-17-2012, 07:08 AM | #44 |
RCC Addict Join Date: Jan 2010 Location: Vermont
I agree the red XJ looks pretty good, and like THX mentioned.... don't worry about milage! These inline 6's run forever! The red one is cool, looks like it already has a mild lift and 31s. 31s are fine for 90% of what you sound like you should be doing. If you go bigger then 31s you need a bigger lift and should probably regear (which is $$$). For me the 2inch and 31s is perfect for trailing around Vermont's class 4 roads. Got it through some pretty nasty stuff mountain biking last week as well. As mentioned earlier DO NOT BUY THE FRST ONE YOU DRIVE. Cherokees always come up on CL, and especially if you widen your search to neighboring states. You can find 97-99s for 1500-4000 depending on miles and rot. Take your time. Would hate to have you make a few thousand dollar mistake... Get the cleanest, newest, lowest milage you can afford (you will be surprised). Also, think about one with a mild lift and 31s already on it (there's almost another 1000 right there). Good luck. |
09-17-2012, 08:24 AM | #45 | |
| re: I got a 97' cherokee, now what lol Quote:
There are also some grand cherokees available in a manual trans, but those are hard to find. Also,not ALL XJ's have a vac. disconnect front axle so you have to physically look. I had a '99 sport XJ w/ the 'select trac' transfer case that did not have a vac. disconnect. My personal experience w/ the jeep was that it was too small for me, the 4.0 was a gas hog and the cost of properly modifying the suspension to clear a 31" tire was ridiculous. The Jeep got around 15 mpg in the city and 17 mpg on the highway. Last edited by BigSki; 09-17-2012 at 08:42 AM. | |
09-17-2012, 09:20 AM | #46 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
if your going for the jeep, don't go picking up something that has been lifted already and has a million miles on it. here's my list of the things to look for when purchasing a used cherocar... 1. pre - 1998 i don't know about your state but here Massholeachusetts we need to plug in cars that are made after 1998 to check OBD emissions values and run diagnostics. basically, you got a check engine light on, you fail. 2. stock everything i don't want to be buying some trail beater or puddle jumper unless the price reflected as such. 3. don't buy the first one you see jeep made a million and one cherokees and just when you think you found the gem, there was another gem parked four streets over. 4. wood grain sides generally the older population purchased this model, old folks take care things usually. plus it just looks hot when lifted. 5. solid floors and rockers with no fresh undercoating or rhino liner small holes can easily be patched, but you don't want a yabba dabba do rig. you also don't want to go buying anything that might smell of fresh undercoating. there just may be a tar paper repair under that. 6. manual roll up windows this is huge to me, it makes it easier if you ever want to take the doors off, and cherokees are known to have window problems. 7. tow package better rear end, bigger brakes and generally better gearing. 8. NP231 better aftermarket support and it was known to be the stronger of the factory offered cases. a close second would be the NP242 only because it's versatility for the street when using in wet, snowy or icy conditions. downfall of the NP242 was the shortcoming of aftermarket support. if you plan on building something and lifting it go for the NP231 simply because there are cheaper options available to do a slip yoke eliminator. 9. under 150,000 miles although jeeps are known to run forever you want to have something that is going to have the least amount of wear and tear possible. 10. no major oil leaks jeeps mark their territory often, so a little drip here or there isn't the end of the world. they are known to develop a leak at the two-piece rear main seal, the back of the valve cover gasket, the harmonic balancer seal, or any combination of those listed. bonuses for me A. two door B. flip out vent windows on the doors. C. older cherokees with the "off-highway vehicle" package consisted of tow hooks, tranny cooler, skid plates plus a 1 inch lift. i think they also call this country version, except country didn't get the lift and tranny cooler ( i think tranny cooler came with tow package don't quote me there ) the 2.5L cherokees came through with the 4.10 gearing in the axles. i would swap a 4.0 in. D. no visor on the windshield although i actually do like the look of a lifted cherocar on 35's, bushwacker flares, hood louvers, and a visor, it will get your jeep pissed on. that's all i can think of for now, happy hunting ! |
09-17-2012, 01:29 PM | #47 | |
09-17-2012, 04:29 PM | #48 | |
As far as the manual Grands, I've seen one on Craigslist. One. Could have been custom, though claimed all original. There isn't even really any documentation online, and is rare enough that it's considered a rumor in most parts. The vacuum disconnect ended in the early 90's... I believe 91 or 92. 31's can fit stock with slight trimming or with a budget boost lift. Had them on an 89. Fit 32's and 33's on 3-3.5" lift (don't remember which). | |
09-17-2012, 06:37 PM | #49 | ||
Read more: Is a NP242 Transfer case better then a NP231 Quote:
09-18-2012, 01:55 AM | #50 |
MODERATOR Join Date: Oct 2010 Location: RC Land
Helpful budget tip: On the Cherokees with coil spring rear suspension you can remove the rear springs and put them in the front and receive 2 inches of lift basically for free! You will only need to buy or make 2 inch extenders for the front shocks, or buy longer shocks. And then simply buy 2 inch longer springs for the rear and the same deal with the shocks back there. Cheap way to grab 2 inches of lift . |
09-18-2012, 01:58 AM | #51 | |
09-18-2012, 06:23 AM | #52 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
for your question regarding manual vs auto offroad... Manual allows you to use the starter to bump the motor, it also gives a little better control of the power. With that being said, when your offroad you have enough to do between throtlle control, wheel control, watching obsticles etc. Its real nice being able to put it in D and go. No shifting on hill climbs, no clutch getting wet in deep holes etc.
09-18-2012, 09:32 AM | #53 |
09-18-2012, 09:34 AM | #54 |
09-18-2012, 01:38 PM | #55 |
09-18-2012, 01:43 PM | #56 | |
Personally, I'd like to get a CJ but for practical reasons I'm looking for a TJ. | |
09-18-2012, 01:51 PM | #57 |
09-18-2012, 05:48 PM | #58 |
forester screams lezbaru... i like subi, but not the girl cars. stick with the jeep. they made a million jeeps and parts are a dime a dozen. you won't find a vehicle with better aftermarket support because everyone makes something for jeep. |
09-18-2012, 06:45 PM | #59 | |
| re: I got a 97' cherokee, now what lol Quote: I would offer $2,200 and hopefully end up with a deal somewhere in the middle around $2,400. Unless it has some hidden issue it seems a good deal. NADA book value on it is around $2,000 trade-in and $3,800 retail. Wife had a 96 just like that for a few years that we bought brand new. Had it for 4 years and did NOTHING but change the oil and one set of tires. Was a great ride . | |
09-26-2012, 09:34 AM | #60 |
so it looks like they wont fix it so im posting here again for feedback on jeeps. found this: 95 Jeep Grand Cherokee miles are fairly high, would it still be fine or should i look for around 100k miles range? or this? http://corvallis.craigslist.org/cto/3281288174.html hows laredos? are they something to stay away from? Last edited by demonoid369; 09-26-2012 at 09:38 AM. |
I got a 97' cherokee, now what lol - Similar Threads | ||||
Lol | demonoid369 | Chit Chat | 5 | 04-06-2011 07:46 AM |
Wheel Chinamans..lol had Carnage..lol | UPNOVER | General Crawlers | 0 | 02-27-2006 08:03 AM |
