10-22-2012, 06:07 PM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
| 05 f250 weird steering issue
I have an '05 f250 diesel 4x4 (94k miles) that I'm getting a weird situation. When turning (left or right) I get a wobble/feedback in the steering wheel. Its not a death wobble at all, just a hurky jerky feeling. Only happens on low speed turns, going straight, down the highway and on curves are just fine. I found and replaced: PS tie rod end drag link end drained and refilled the ps fluid (not a full flush just reservoir). I had my neighbor who is a mechanic and specialized in the Superduties until he got smart and left Ford. He thought for sure it was the tie rod and it was worn bad. He's scratching his head on it with me... (and yes, if I had the money I would sell it and get a cummins) |
10-22-2012, 06:39 PM | #2 |
Newbie Join Date: May 2012 Location: La Cresta Murrieta, CA
Probably the panhard rod bushing. Is it lifted? Happened in my 07.. started out as small shaking then got death wobble doing 75 down the freeway. Sent from UR ANUS using a Foreign object |
10-22-2012, 06:52 PM | #3 |
| Re: 05 f250 weird steering issue
overly grabby LS unit in the rear axle? I had a similar situation on my old F250. I changed the rear diffy oil and used a synthetic lube that claimed it didn't need a friction modifier. After a few days, the whole truck would shake/wobble while turning and it made a horrible 'popping' noise that sounded like the chain in the t-case was skipping. 1 small bottle of the friction modifier and the symptoms went away.
10-22-2012, 08:25 PM | #4 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
The PS gearboxes on those are junk and at nearly 100k it prob need rebuilt or replaced.. No issues outta the 6.0? Also check the pan hard bar for play..
10-22-2012, 08:36 PM | #5 |
Newbie Join Date: Sep 2012 Location: san antonio
Make sure your not stuck in 4x4..pull the driveshaft and see if it goes away..
10-22-2012, 09:18 PM | #6 |
Quarry Creeper Join Date: Jun 2011 Location: Salt lake city
if you had one worn tire rod then chances are everything else is worn too. check tire balance, wheel bearings, ball joints, track bar, drive shaft, axle u joints, all your steering joints. make sure every bolt is tight and every zerk is lubed. be sure to check the intermediate shaft too( shaft from steering column to steering box) like stated before check that rear end too the LS likes to act up and do all sorts of weird stuff. whatever you do DO NOT let someone tell you to slap a new steering stabilizer on there and call it a day. a proper functioning steering system does not even need one.
10-22-2012, 09:58 PM | #7 |
| Re: 05 f250 weird steering issue |
10-23-2012, 05:21 AM | #8 |
10-23-2012, 09:03 AM | #9 |
Bad ball joints?
10-23-2012, 12:12 PM | #10 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
Does it have that same wobble you get from bad u-joints by chance? If so, might not be an LSD issue, my XJ is doing the same when pushed as far as possible while turning tight at low speeds. I really need to grease that thing before winter come to think of it...........
10-23-2012, 03:05 PM | #11 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
10-24-2012, 07:27 AM | #12 |
And the winner is... stuck in 4wd. I cycled it between low and high and drove up and down the drive a few times until I could hear the tcase click when I turned the switch. Seems all good now except my steering wheel is off abou 15* from the parts replacement.... alignment here I come. Sent from my DROID RAZR using Tapatalk 2 |
10-24-2012, 09:24 AM | #13 |
Nailed it......glad it's fixed...L
05 f250 weird steering issue - Similar Threads | ||||
Weird issue with new HH brxl | LDogg | Electronics | 11 | 09-08-2011 08:02 PM |
weird issue with Dx3e... | R/CMaxximus5.0 | Electronics | 10 | 05-01-2010 06:56 PM |
Weird Steering Issue any Ideas? | Frank Rizzo | Losi Micro-Rock Crawler | 6 | 04-08-2010 04:13 PM |
Need help with weird DX3 & Steering Servo Issue | MtnBkr | Electronics | 6 | 03-21-2010 08:00 PM |
Weird Quark issue? | RXcrawler | Electronics | 3 | 05-07-2007 11:01 AM |
