Go Back   RCCrawler Forums > Miscellaneous > 1:1 Full Size Vehicles
Thread: Bender's 1:1 JK Build - Project Getaway
Old 10-16-2013, 10:40 AM   #81
Default Re: Bender's 1:1 JK Build
Originally Posted by BENDER View Post
It's a 2012 auto with stock 3:73 gears.
What gears are you going to?
The Doc is offline   Reply With Quote
Old 10-16-2013, 12:39 PM   #82
2006 2.2 National Champ
BENDER's Avatar
Not sure yet, really depends on a number of things that still have to be sorted.
BENDER is offline   Reply With Quote
Old 10-16-2013, 05:51 PM   #83
Just wondering, 4.56 are very good all around gear with 35''
Old 10-17-2013, 10:12 AM   #84
BENDER's Avatar
Yeah, I bet that would be a good combo. We are still on the fence about putting too much money in our Dana 30.
Decisions!
Old 10-17-2013, 02:56 PM   #85
If you just just gusset up the c"s and tube it, it will hold up pretty decent. Or if you have the money do a dynatrac and not have any problems. Don't get the rubicon 44 because it's not all 44, the housing is still weak!! It all depends on how much your going to hammer it.
Old 10-24-2013, 01:45 PM   #86
We are working on the lift. We are looking at the 2.5 Flex System from Rock Krawler. It's going to be more of an overland build than full on rock crawler. So, we may make a few upgrades to the axles but nothing over the top. This is our DD too.
You'll like that lift. I run the 2.5" Stock Mod with Bilstein 5100s on my 2011 JKUR and it netted me just a hair over 3" of lift. So yeah, RK advertises their lifts conservatively. Gonna' look sick with those PB's on there!
I'd say 4.56s, too. 4.88's seem to the happy place on the 2012+ auto with 37s, so 4.56 shold put you just right. Some people are happy with 4.10s and even 3.73s, but I think you'll see much better performance with a regear. One of the best things I did to my very anemic 2011 3.8L for sure. I went to 5.13s, though.
If you don't want to sleeve it, you could always go for the Artec truss kit, too. Great addition to the front axle and really beefs it up quite a bit. Plus, if you've tweaked the tubes at all, it'll be an easier install. And it of course looks cool as shit! Definitely on my short list......along with everything else. I've run a stock D44 with just upper c-gussets for over two years and been fine so far.
Sh0rtBus is offline   Reply With Quote
Old 10-24-2013, 11:51 PM   #87
5th D Owner/Driver
cboggs's Avatar
Despite what everyone thinks the tubes on the 30 and 44 do not bend that easy. If you are into high speed runs through wash board in the desert then yes you will more than likely bend them. Sleeves are overkill and a waste of money to put into a stock jk axle. Gussets are recommended for the C's though. If you need anything more than that, the stock axles are not for you and you should start saving for a prorock 44 or 60.
cboggs is offline   Reply With Quote
Old 10-25-2013, 08:58 AM   #88
Looks good Bender! I'm just getting ready to lift my '08 2" tomorrow, but still staying on the 33's for now. I might go 35's and 4.56s later on, but it will be awhile since we just bought the Commander and had to put wheels/tires on it immediately.
Ty@Tekin is offline   Reply With Quote
Old 10-25-2013, 10:02 AM   #89
BENDER's Avatar
Gussets is probably all we will do. Maybe a gear change from the 3:73's to 4:56's, but pretty sure I will need to change the carrier as well to make that jump. At that point the whole "add lockers while you are in there" debate comes into play.
We will see how it does after the tires and wheels are installed.
Thanks. We are actually looking at the 2.5 Max Travel kit now. Decisions, decisions!
We would like to do gears as I mentioned before, but we will see how performance is with the stock set-up.
Exactly. The tubes and C's on the Dana 30 and Dana 44 are the same. The biggest difference in strength between the two is the ring and pinion. We are not locked, or into high speed running, so gussets for the C's should be sufficient. And I only say that because of the weight of the tires.
Thanks Ty. Post some pics after you lift it. We are getting excited to get our build underway, just need to finish gathering parts!
Old 10-25-2013, 12:43 PM   #90
5th D Owner/Driver
cboggs's Avatar
I think you'll be surprised how livable the 3.73's are with 35's, I ran those gears for a year in my '12 Rubicon auto with 37" Toyos just fine. Rigs gonna look good!
Old 10-25-2013, 06:26 PM   #91
BENDER's Avatar
Good to hear. I drove my old 4.0 TJ with 3:73 gears and 33's for almost 10 years, it wasn't ideal but it worked. I have a feeling with the new motor, 3:73 gears and 35's this 2012 will be a lot better than that.
Old 11-08-2013, 03:56 PM   #92
BENDER's Avatar
Default Re: Bender's 1:1 JK Build - Project Getaway
Well we pulled the trigger on the Rock Krawler Suspension 2.5 Max Travel lift kit, with their 2.0 RRD Emulsion Shocks. I am very impressed with the quality of all the components, as I am still rifling through the boxes! The shocks themselves are works of art! The aluminum bodies are fluted for better cooling, and the overall weight of each shock is surprisingly low.
A couple cellphone teaser shots......
Old 11-11-2013, 09:41 AM   #93
Boxes of awesome. Love those shocks, they look nice!
Old 11-13-2013, 07:52 PM   #94
BENDER's Avatar
Lots of awesome!
A few better photos of the RK lift kit components.
Old 11-14-2013, 09:35 AM   #95
Yup.....I remember that sight. Word of advice...even though I haven't done it myself....but get that rear track bar bracket burned onto the axle housing. And be careful drilling the hole for it. I damn near took off a toe with a 1/2" drill doing it.
I promise, though, you'll be plenty happy with that kit. Don't need any more than 2.5" of lift, either. I have yet to need any more. I would eventually like to get the control arms, though, to make mine the Max Travel kit. Just haven't yet found justification.
Old 11-14-2013, 11:54 AM   #96
BENDER's Avatar
Thanks for the heads up. We are going to weld the bracket.
Glad to hear you are happy with yours.
Old 11-14-2013, 12:26 PM   #97
Moderator Rule Breaker
eric113's Avatar
So when does the goodies go on ?
eric113 is offline   Reply With Quote
Old 11-14-2013, 12:46 PM   #98
BENDER's Avatar
Soon hopefully! I still need a ProCal to re-program the computer for the change in tire size, since it is an automatic. And we still need wheels. So, little by little we are getting there.
Old 11-14-2013, 02:49 PM   #99
Spend the extra coin and get a tuner. I only picked up a ProCal because there weren't any tuners available for the '11 due to the reconfig'd security coding in the ECM. There are a couple now, but I've got other priorities.
Old 11-15-2013, 11:51 AM   #100
Oppan Gangnam Style
chino63's Avatar
How excelent, looks to be some really nice stuff. I hope you will be doing a step by step on these mods? Don't know why but I enjoy reading step by step builds.
chino63 is offline   Reply With Quote
Tags
2.5 max travel, bender, bender customs, jeep, jeep jk, monster 893, pit bull tires, project getaway, raceline monster, raceline wheels, rock krawler suspension, trek armor
Bender's 1:1 JK Build - Project Getaway - Similar Threads
Bender's Wraith Kit Build BENDER Axial Wraith 104 03-03-2019 09:11 PM
Bender's XR10 BENDER Axial XR10 149 03-12-2013 06:11 PM
Bender's latest FOFF Build BENDER Formula Offroad 105 12-23-2012 11:40 AM
Bender's 6x6 SCX10 BENDER Scale Videos! 25 11-12-2010 09:12 AM
Bender Customs SW3 Build/Bender's whereabouts? ken_eg_307 Chit Chat 3 02-15-2008 02:11 PM
