Go Back   RCCrawler Forums > Miscellaneous > 1:1 Full Size Vehicles
Thread: The money pits; Jeep JK & XK
Old 10-28-2013, 08:32 AM   #21
Default Re: The money pits; Jeep JK & XK
Originally Posted by 88RRC View Post
Normally death wobble is caused by bad bushings. That's what it was on my Range Rover, panhard bushings were shot and caused the truck to death wobble at speeds higher than 20mph. If it does it check bushings first. Oh, and you just lost major cool points by using spacers, lol. The whole concept of a 2 inch thick puck of Nylon holding up the weight of the chassis gives me the heebie jeebies. It does look good even though it has a mall lift. Please tell me those things are temporary?
Ben
For now, they were $20. I hope to one day do a 2.5" coil lift and go 35's.
Ty@Tekin is offline   Reply With Quote
Old 10-28-2013, 10:51 PM   #22
Originally Posted by greenjk View Post
Waste of time doing an alignment as the only thing adjustable is the toe in/out and that will be the same as before.
Ben
If any of the original XJ design carried over to the JK, there should be the ability to adjust caster too. Worn parts can cause cause DW, but not adjusting caster post lift or rolling the axle forward to reduce the front u-joint angles. I've noticed it on videos of Super Duties and sfa Rams too, almost all were using a puck lift kit or leveling kit.
BJoe is offline   Reply With Quote
Old 10-28-2013, 11:16 PM   #23
No caster adjustment is available standard.
greenjk is offline   Reply With Quote
Old 10-29-2013, 08:56 AM   #24
Stock you can't change it, you either need adjustable LCA's, caster bolts or AEV brackets. I've actually read that the brackets are better and adjustable LCA's are often thought of as the only way to adjust caster. The brackets do more than adjust the castor angle.
I took it out on the highway and it was fine up to 75, so I don't feel the 2" spacers did anything negative in any way. I don't care if people hate on my budget boost, I couldn't pass it up for how cheap it was.
Old 11-12-2013, 09:41 AM   #25
2006 2.2 National Champ
BENDER's Avatar
Really digging the way the Commander looks with the lift.
As far as the JK lift goes, do what you got to do and go have fun.
BENDER is offline   Reply With Quote
Old 11-12-2013, 12:35 PM   #26
Thanks! I was really stoked to find it already lifted and it actually drives really nice! That's kind of how I saw the lift too, why not! I'm going to have to save up a lot more money to do what I want as the end goal. Maybe sometime next year and after I do all the other things I have planned first...
Old 11-12-2013, 08:16 PM   #27
Not just bushings,loose hardware,ball joints will cause DW
JK Krawler is offline   Reply With Quote
Old 01-20-2014, 03:50 PM   #28
Here's my project this week. Already tore it apart, just waiting on a new shaft.
Old 01-20-2014, 06:20 PM   #29
So far I'm about 25 minutes into getting the axle shaft out. Getting the bearing hub off the knuckle took the longest, the BFH came in handy.
Now I just have to wait for my new axle to show up....*twiddles thumbs*
Old 01-20-2014, 06:39 PM   #30
Just jump it!
rottenbelly's Avatar
Make sure you take a coat hanger and pull the little plastic rings that center the axle in the tube while installing them out before installing the new one.
Will cause a axle seal leak.
( you probably know this but just making sure!)
Oh and how did you manage to do that?!
rottenbelly is offline   Reply With Quote
Old 01-20-2014, 09:12 PM   #31
Yep I took that guy out, only found one but I think that's normal. Did it the other day, got stuck pretty good but didn't expect to pop a shaft, it must have been fatigued already..
Old 01-22-2014, 08:41 AM   #32
New shaft is here at work, should be all back together tonight!
Old 01-23-2014, 09:00 AM   #33
Well, some bad news. The new axle shaft is an upgraded OEM, 25% larger than stock. Ok, no problem, just have to take the edge off the three hub bearing bolts so it clears nicely. During re-assembly, I found out the ball joints are toasted. :( I don't have the tools to do ball joints, so it got dropped off at the Dr's office this morning.
Old 04-15-2014, 03:56 PM   #34
Got some goodies for my birthday! Warn VR-8000 winch and a sick Pioneer 7" double din from the wifey. Got that all wired in with my 10" sub, sounds amazeballs!
Then gave them both a nice wash and detail this Sunday.
Old 04-22-2014, 01:34 PM   #35
Just jump it!
I heard the 12 and newers used the Dana 44 u joint even in the Dana 30.
Which would be nice to keep that from hopefully happening again!!
Looking good. I've been out giving mine a bath and shining up the new race line beadlocks.
Which ball joints did you go with? My stockers went quick so I went with the synergy.
Old 04-22-2014, 04:14 PM   #36
Moog HD's, should last a bit longer and have a warranty!
Old 04-22-2014, 08:36 PM   #37
Best way to get the hubs out is to stack up a short socket and extension on the hub bolt. Un-thread the bolt most of the way, start the jeep and crank the wheel until the extension hits the c-hub. This will press the hub out using the jeeps power steering, you may need a helper to do this but it works awesome.
BLKXJ 96 is offline   Reply With Quote
Old 05-08-2014, 02:06 PM   #38
One of the short trails by my house is finally clear of snow, so went for a little solo trip up and back.
Also have Rough Country N2.0 shocks, 2.2 steering stabilizer, front skid plate and Smitty Bilt CRES on the way!
Old 05-09-2014, 01:52 PM   #39
New shocks and stabilizer showed up today, will be going on tonight.
Old 05-09-2014, 02:59 PM   #40
Just jump it!
Nice! I've heard those new shocks are alot better than the older ones!
The money pits; Jeep JK & XK - Similar Threads
Yes,,,Another Jeep Jk money pit Eljuan187 1.9 Scale Rigs 4 03-02-2013 06:40 AM
Money pits! zjguy721 Chit Chat 19 03-03-2011 07:39 PM
