10-27-2013, 09:48 PM | #1 |
| Need help finding a part...
2000 Mitsu Montero Sport 4wd 3.5l Long story short: a nice chunk of granite beat the ever-loving snot out of the underside of the truck, and punched/tore a hole in the transmission pan. Its patched back together, though I'd feel a whole lot better with a new/used one. But I can't find one... |
10-27-2013, 10:04 PM | #2 | |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
I'll check local places. | |
10-28-2013, 02:48 AM | #3 |
Pebble Pounder Join Date: Jul 2009 Location: Australia
| Re: Need help finding a part...
We call it a Mitsubishi challenger here,might have some luck on fleabay
10-28-2013, 05:53 AM | #4 |
Rock auto? Or a welder? |
10-28-2013, 09:12 AM | #5 |
| Re: Need help finding a part... |
10-28-2013, 06:25 PM | #6 |
10-28-2013, 06:40 PM | #7 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
Try this guy, it's wrecked but it's there, 706 441 0228
10-28-2013, 06:44 PM | #8 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Another alternative is that you could search (I'm searching as well) for the transmission model name and then search with the model name. A lot of those Japanese manufacturers buy from the same supplier, so most likely it could be a Nissan/Toyota/Honda transmission. If that's the case, you can then search the manufacturer's databases and might be able to track it down. Also, You can measure the oil pan and then take those measurements and compare to the other pans you find online. Most will work if it is a common shape. I'll be helping you look for one! |
10-28-2013, 06:47 PM | #9 | ||
| Re: Need help finding a part... Quote:
10-28-2013, 06:57 PM | #10 | |
Is your transmission a 4 speed or 5 speed tiptronic? Start serching with the name "INVECS-II". That may start to show better results. | |
10-28-2013, 06:59 PM | #11 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Just call up a local tranny shop or local machine shop... im sure someone can weld or they would know someone close by.
10-28-2013, 07:01 PM | #12 |
10-28-2013, 07:03 PM | #13 |
Quarry Creeper Join Date: Nov 2008 Location: riding in the cherokee...
car-parts.com hope it helps.
10-28-2013, 07:13 PM | #14 |
10-28-2013, 07:52 PM | #15 |
A little Googlefu says that the tranny is an Aisin Warner 30-40FL... seems like you might be able to rob the tranny pan off an early model Cherokee with an Auto. AKA AW4? http://www.4x4wire.com/forums/showfl...0&fpart=1&vc=1 Last edited by 2JSC; 10-28-2013 at 07:56 PM. |
10-28-2013, 08:09 PM | #16 |
Hmm, maybe not... its a V4A51/R4A51. Whichever is the 4spd. Sorry Duuuude
10-28-2013, 08:55 PM | #17 |
Pretty sure its a 4 spd. The most obvious difference between the two available choices is the bolt count on the pan is different. IIRC one has 19 and the other has 20. Last edited by Duuuuuuuude; 10-28-2013 at 08:58 PM. |
Need help finding a part... - Similar Threads | ||||
Need help finding a part!!!! | mtgrizzlymn | Axial Wraith | 12 | 12-10-2011 07:26 PM |
Help finding part #'s | tyerfryersc | Tamiya Clod Buster | 1 | 03-08-2008 07:11 PM |
need help finding a part | rockbound | Chit Chat | 0 | 01-27-2008 03:09 PM |
Help finding Kyosho USA-1 Nitro part | cheapjeep2 | Chit Chat | 1 | 09-12-2006 02:43 PM |
