03-31-2014, 05:58 PM | #1 |
Rock Crawler Join Date: Jun 2010 Location: Forsyth County, Georgia
| Dana 50 Question
Recently I began looking into doing a axle swap on my WJ. A local shop has a D50 with 5.13s, a locker, and Chromos sitting there for 800. I have a East Coast Gear Supply D60 in the rear, but my concern is the width between the D50 and D60. I have not been able to find online anywhere the widths of the D50. Does anybody know?
03-31-2014, 07:30 PM | #2 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
| Re: Dana 50 Question
The 50s and 60s are identical width as far as I know. The only difference would be a 60 with spacers for a dual wheel application other than those they generally be the same width as your rear 60.
03-31-2014, 07:47 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Depends on what it came out of. F150's are like 65" wide. F250/350 are around 70" wide. Both of which are wider than a WJ which is around 60" wide. Isnt your ECGS D60 stock width?
03-31-2014, 08:27 PM | #4 |
50s were offered in 2 versions, TTB {twin Traction Beam} and solid axle. Now unless your 60 has been narrowed there should be very little to no difference in hub to hub width. The biggest problem with a dana50 is that it retains stock dana60 axleshaft diameter until necks down into the carrier which is 30 spline.
03-31-2014, 09:51 PM | #5 |
The 60 has been narrowed. It is only 3 inches wider than the D35/D44a that came stock in those. If it's a minute difference, say three inches total, then I can just run 1.5 inch spacers im the rear, but if it's a larger difference inwouldnt be comfortable running a larger spacer
04-01-2014, 08:06 AM | #6 |
I'll measure my front end and get you some numbers
04-01-2014, 08:10 AM | #7 |
Your looking at 71.5 inches roughly
04-01-2014, 08:18 AM | #8 |
Thank you sir! That's helps a lot
04-02-2014, 12:14 PM | #9 | |
| Re: Dana 50 Question Quote:
04-02-2014, 12:19 PM | #10 |
Like just about everything, I'm with white trash on this one. Buy a pre super duty D60 or go with one of the updated D60s in the newer super dutys. The D50 was a mistake that never should have happened.
04-02-2014, 12:28 PM | #11 | |
I believe it was '03 and later that the 60 was standard issue. Prior only the duallies got the 60 and the single wheel received the failed abortion. Unit bearings are still considered throw away consumable items and ball joints are where queers hang out not what I choose to run on anything considered heavy duty. | |
04-02-2014, 12:35 PM | #12 | |
04-02-2014, 01:03 PM | #13 |
Yea, everything was upgraded in '05 when the "new" suspension came out. When they came out with the 6.ohshititblewupagain in '03 they stopped screwing around with the 50 and went 60 in everything. The super 60's are much beefier but there are some 70's that came out in the kodiak trucks that were crazy big. Their issue is they are only available in 4.88 and 5.13 ratio's since they're high pinion 70 and that's the only application ever made.
Dana 50 Question - Similar Threads | ||||
Dana 80? | mud digger | 2.2 Scale Rigs | 14 | 02-12-2012 09:24 PM |
Dana 60 question | team savage | Chit Chat | 5 | 09-24-2010 04:37 PM |
