05-24-2014, 05:27 PM | #21 | |
| Re: Broken Subaru Quote:
Car is clean though wingless trunk is where it's at | |
05-24-2014, 11:01 PM | #22 |
Pebble Pounder Join Date: Jan 2014 Location: upstate NY
| Re: Broken Subaru My clutch is starting to slip now under full load. And that trunk was a pain. Was an STI trunk so it had the 17 holes in the top to fill and the keyhole as well. Took me a couple days of welding and sanding to get it all filled and painted up.
05-25-2014, 12:26 AM | #23 | |
If you do a clutch I would stay OEM and don't do an exedy stage 1 HD unless you like serious pedal pressure. I switched to an exedy twin disk this time around | |
05-25-2014, 11:25 AM | #24 | |
05-25-2014, 12:06 PM | #25 |
| Re: Broken Subaru |
05-25-2014, 09:05 PM | #26 |
Rock Crawler Join Date: Jul 2013 Location: Manchester
Cosworth Sti block built Wrx heads 5 speed ppg gear helical cut .. Godspeed intake manifold with 70mm tb. Tgv deletes . Agency power fuel rail dual Walbro 255.. Agency power equal length Perrin divorced dp . Bpm exhaust catless Perrin up pipe Perrin intake ..comp clutch 6 puck with lightened flywheel deutchworks 850 injectors maxed out buying 1100's soon Godspeed 38mm external gate .. Turboxs bov.. Go fast bits boost control .. Miles of heat wrap Dei turbo sock .. Hand tigged stainless fmic pipes .. Godspeed fmic.. Hose and wire tuck/delete... Isc coil overs Perrin 25mm sways f/r with end links and stout mounts ... Oswald performance subframe .. Urethane bushings .. Gtspec trailing arms .. Godspeed lateral links ... Willwood 12.5 rotors with 4 pots up front stainless lines .. Full cage .. Seats.. Short throw .. 18/9.75 xxr.. Stretched 215/40 kumho ... 6 gauges ... Carbon hood and trunk and vane wing .. Soon to be carbon roof and doors .. Vis racing body kit .. House of kolor Pavo purple with ppg flat clear ... Painted and built by me and my buddy joe who works for the newengland rally team ... I put down 442 with 431 ft lbs on 93 octane using a FP 68hta .... At 22psi ... Going rotated when this motor is broken in doing a 62/62 turbo Sent from my iPhone using Tapatalk |
05-26-2014, 08:36 AM | #27 |
| Re: Broken Subaru
Man I miss having a build list like that and over 400 hp. One reason I really miss my evo, that thing was a beast.
05-26-2014, 09:43 PM | #28 | |
The EJ motors suck IMO unless you sleeve them and build them with real goodies. Between the shitass cast pistons with ring lands that snap like tooth picks and the shitty cylinder walls the fracture they are junk lol What made you go from the Evo to the subi ? | |
05-26-2014, 11:35 PM | #29 | |
05-27-2014, 03:52 PM | #30 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Broken Subaru
Nice rex, makes me miss mine. Mine was actually a monster truck, compared to all you guys. And I don't want to be rude, but that Miata is horrible. I don't get the whole VIP, stretch/poke/flush business. It's not even safe to run tires and wheels like that and has to handle like a trash can. |
05-27-2014, 08:24 PM | #31 |
| Re: Broken Subaru Lol yea, im not a huge fan of crazy camber and big stretch. But the car is a head turner. He said it doesnt handle that bad. But I mean its a Miata its pretty much a street legal go kart to begin with.
06-14-2014, 05:32 PM | #32 |
Quarry Creeper Join Date: May 2008 Location: Lafayette, Indiana
| Re: Broken Subaru
Good looking car man! I swear I have seen pics of that white fozzy before. And that miata is gangsta.
06-18-2014, 06:50 PM | #33 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Re: Broken Subaru
Very nice looking ride, I've always been a suby fan. I was surprised to read you are running stock clutch setup that's usually one of the first upgrade. Anyway keep the pics coming. --Dan |
06-25-2014, 08:59 PM | #34 |
| Re: Broken Subaru
Havent really been doing much with the car besides driving it. Let me dig around and see what kinds of pics I have.
06-25-2014, 09:03 PM | #35 |
| Re: Broken Subaru |
Broken Subaru - Similar Threads | ||||
Subaru Impreza | Blown Thunder | Rally | 12 | 11-29-2013 07:55 PM |
See the new Subaru BRZ? | EeePee | Chit Chat | 47 | 12-06-2011 10:48 AM |
Subaru Legacy | 2JSC | Chit Chat | 15 | 01-08-2010 01:18 PM |
