Go Back   RCCrawler Forums > Miscellaneous > 1:1 Full Size Vehicles
Thread: Post Your Cherokee xj Here
Old 02-28-2015, 04:25 PM   #41
Default Re: Post Your Cherokee xj Here
there are tons of write ups on naxja and jeepfourm as well but super easy mod its the redneck ac lol
87Matchief is offline   Reply With Quote
Old 03-01-2015, 07:53 AM   #42
It's easier to cut them in the door than it is to get those damn torx bolts out imo. Especially if you have an air hammer because you can cut most the way through then knock the bottom off with it and you won't break as many disks.
Motorcharge is offline   Reply With Quote
Old 03-23-2015, 11:01 AM   #43
96 xj 6" lift cut the hell out of the fenders got some homemade rockers cut the roof off and putting an interior cage in it. Rolling on some 35s other than tires/wheels I've got all of 400 into the entire thing lift vehicle and all!
bonosxr is offline   Reply With Quote
Old 03-25-2015, 08:27 PM   #44
nice man not bad! i love the wheel choice ive thought about doing those how do you like them?
Old 08-24-2015, 11:33 AM   #45
My 1st xj was running 4.5ish on 33" Baja claws
2nd was running 4.5 on 33" boggers
3rd was small, 3" on 31's
4th was also small 3" on 31's
I've had two others that i don't have pictures of but they were nothing to call home about. Now I'm xj less
XJrob is offline   Reply With Quote
Old 08-26-2015, 05:52 AM   #46
First one, 89 XJ about 4" on 33" Mall Terrains, 89 converted to a 98 with full wiring, ecu, doors n dash. Also converted from auto to manual.
Second one the day I purchased it, had thrown a rod so it was cheap! Tossed in my 4.0 after first XJ got totalled by drunk driver the sunday before christmas, installed my wheels, and moved across the country!
JBcustoms is offline   Reply With Quote
Old 09-14-2015, 08:39 PM   #47
Picked this one up on Friday and upgraded the system in it while I decide what to do first, thinking about rusty's metal flat fender setup with 32x10.50's and bumpers from LMP with JCR sliders.
halfcab is offline   Reply With Quote
Old 09-20-2015, 09:19 PM   #48
dang that xj is clean.. id like to find another one as clean as that.
Old 10-01-2015, 10:39 PM   #49
Got the rear bumper on it today
Logan's metal products...nice departure angle too
Old 10-06-2015, 09:57 PM   #50
Got the front LMP winch bumper primed/ painted and mounted today. Got one of the rusty's off-road steel flares mounted up also.
Old 10-07-2015, 12:24 PM   #51
'99 4.0 auto np231, hp30 spartan locker, 8.25 factory limited slip, solid axle ind diff covers, rustys engine and tcase skidplate, lower control arm skidplates, steering box brace,
TNT unibody stiffener, front suspension is 3" zone offroad coils, rough country bent lower short arms, generic sway bar disconnects, rear suspension is rough country shackle relocators,
zone offroad curved shackles, and rancho 1.5" full leaf packs all on zone offroad shocks, rod louvers hood kit, homemade rock sliders, 32x11.50 mtr's
it's low, nimble, and fun
hd44blazer is offline   Reply With Quote
Old 06-11-2016, 05:26 PM   #52
Started my XJ for the first time since August of 2015, all we did was make sure it had some water in it, bumped the ignition over a few times and it fired! No fresh oil or fuel, same plugs, wires, cap, and rotor as it had before it was parked too!
BJoe is offline   Reply With Quote
Old 07-07-2016, 05:58 PM   #53
My little piece of Jeep. 93 2 door, 4.0, AW4, 231. No lift other than the stock Up Country springs on 33x12.50 tires.
struhall is offline   Reply With Quote
Old 06-23-2018, 11:26 PM   #54
Well, it lives, again...........
My XJ developed a fuel leak last year that we finally fixed, a week before the end of the month and just need to get it in for emissions testing so we can get it registered for the next year.
Dad found the leak, turns out quick disconnect at the bottom of the firewall had rotted out and then broke when we moved it into the spot we did the repair!
Got the new line in from the dealer and installed it today, quick disconnects don't disconnect quickly after 20 years of Midwestern winters, luckily the replacement clicked right in once we cut the old disco's off and it started fairly quick.
Once this was done, lunch was acquired and eaten and I then went and picked up an oil filter and catch tub so I could put fresh oil in it. I also aired up the tires and rear air shocks the rest of the way, topped off the radiator, checked to make sure all the lights were functioning as intended, Dad and I sacrificed some blood to the Jeep Gods, and it is ready to put some miles on tomorrow......including stopping at a parts store to pick up a bag of oil dry to clean up the mess I made changing the oil
It definitely will need new tires before winter, if not Labor Day, the reflectors in the headlights have started to lose the plating and have gotten moisture in them, so I will need to get new headlights before winter.
Old 10-05-2018, 11:57 PM   #55
anybody in Northern Nevada around Reno and Lake Tahoe need a 242J transfer case out of a XJ, its dated 1997 on the badge, I don't need it and could use the cash
kgb424 is offline   Reply With Quote
Post Your Cherokee xj Here - Similar Threads
Jeep Cherokee never to late to post. DezertFox Axial SCX-10 7 04-29-2013 05:01 PM
Post your cherokee!!!!! rcjeeplover11 1.9 Scale Rigs 11 03-12-2011 08:06 AM
