12-15-2006, 07:45 AM | #21 |
Rock Stacker Join Date: Dec 2006 Location: Jacksonville
I ran a detroit locker in the rear and an arb up front,always did me great and I would also uggest unless you like changing birfields get ome good ones like the long fields or better.don't worry about the stockers they will break soon enough if you are locked in the front,but you can prolong the life by not getting on it with the wheels turned too far.remember most of the parts that you are gonna abuse initially may be 20 years or so aol and were designed for little tires.
12-15-2006, 07:48 AM | #22 |
heres a few pics... |
12-15-2006, 07:49 AM | #23 |
heres a sami I built with toyota xles... |
12-15-2006, 07:49 AM | #24 |
12-15-2006, 08:08 AM | #25 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
12-15-2006, 08:15 AM | #26 |
high angle is jam up,thats where I got my 1410 shafts built for my jeep. |
12-15-2006, 09:48 AM | #27 |
here is a couple shots of my 94' w/ 4" all-pro springs all around,5.29's, 4.7:1 dual cases, custom flat bed, 37" MTR's and beadlocks. Last edited by Unimoger; 12-15-2006 at 10:12 AM. |
12-15-2006, 10:08 AM | #28 |
RCC Addict Join Date: Nov 2006 Location: burlington
dont go with 5.79 will break use 4.88 or 5.29 or you can stay stock and put 4.70 in transfer case . other than that and you are going to have a sweet allround rig. here is a picture of my rig to give you an idea it has a 4 inch lift with 37 and a little fender triming with 5.29 gears a host of other mods. |
12-15-2006, 10:15 AM | #29 |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
We deal with Jesse at high angle driveline on almost a daily basis....great guy.
12-15-2006, 10:15 AM | #30 | |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
12-15-2006, 10:48 AM | #31 | |
yep at least 35"s and oh BTW anyone looking for a almost brand new set of 35 MTR's on 15 x 10 6 hole yota/chevy rims? all 5. only have been mounted and then placed on a rig to roll it about 4 miles. basically brand new | |
12-15-2006, 11:11 AM | #32 |
Rock Crawler Join Date: Mar 2006 Location: Holiday, FL
I have All Pro 5" springs with downey 2" shackles and a 3"body lift I'm running 37" Irocs All Pro crossover streering, All Pro shock hoops, All Pro long spline drive shaft kit, All Pro brake lines, 12" travel Pro Comp xtreme reservoir shock all the way around, Off Road Solutions rear shock hoop. 22r motor with a TRD stage 3 cam, LC header, 2 1/2" exhauts with 50 series flowmater and high flow cat. Downey super clutch2 all in a 84 4RUNNER AND 5.29 gears spool in rear open in front |
12-15-2006, 11:22 AM | #33 |
RCC Addict Join Date: Feb 2006 Location: Moku O Keawe
WOW thanks alot ALL YOU GUYS for shariing info abut your rigs and all the advice!!!! As far as the stats on the first thread...Everything i listed is already on my truck. I also forgot to mention that i have a centerforce, webber carb and the two inch pipe aswell. Thanks a bunch FiremanJim for all the useful pics, suggestions and advice. Why arent the 5:79's any good?...I figured theyd be hella good being that there geared really low. I enjoy camping and wheeing and it takes some wheeling to get to good spots so id like a pretty capable trail rig but not full blown ROCKCRAWLER. Im in no position to constantly be fixing, or buying new parts. Id like to be able to hit the trails and have fun doing it!!!!...What do you think?...
12-15-2006, 06:35 PM | #34 | |
RCC Addict Join Date: Apr 2004 Location: Santa Clara
Now what you do lose though is highway & off-road grunt because you are gearing up. The off-road part is easy because you can plop in a T-case gear set or dual transfer case. The freeway however is what it is though. So you run what your motor can handle. I had 35s and 4.37s and I noticed it chugg a bit. Hopefully if you come out this way, we can take you up on the RUbicon for some granite style crawling. -Sam | |
12-15-2006, 06:58 PM | #35 |
Quarry Creeper Join Date: Nov 2004 Location: Frayed ends of sanity
I had the automatic stock 4:35's in mine BUT I had a VORTEC 4.3L to lug it around,I kept the w56 in my truck with the stock case there are not alot of rocks here in NW Ohio so wheel speed is a premium!! And it was an 84 4RUNNER!! |
12-15-2006, 07:51 PM | #36 |
I wanna be Dave Join Date: Sep 2004
the tires you have do look large for 33's. i would still say go larger if you can.
12-15-2006, 09:02 PM | #37 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
aaaahhhhhhhhhh you guys suck.......... all these pics of Yotas.. YOu guys are making me want to build another one |
12-15-2006, 10:48 PM | #38 |
Pebble Pounder Join Date: Sep 2004 Location: Livermore, CA
Forget 33s and go BIG! Get 38s. *evil grin* |
12-16-2006, 12:20 AM | #39 | |
Ya sell out I'm running a 5" spring kit from All Pro with 37" Boggers. I'm pretty pleased with the springs. The rear springs were a little stiff at first,but after some beating on them,they've loosened up nicely. I'd say they've settled about an 1" from when I first installed them. I've got an 87 X-cab,but as far as your list of mods,you got alot of the same things I got. 5spd 22R 38mm Weber Centerforce III Doug Thorley header Flowmaster Jacobs ignition dual cases twin sticks full width axles OBA 15 gallon aluminum cell EXO Rockstomper hysteer and a good air freshener to help with the poop stain in the drivers seat. | |
12-16-2006, 05:34 AM | #40 |
HEll y eah id like to crawl with yall nut taht would be hella expansive!! Im thinking of getting the 7.5" kit and probably run 35's!!!...MAybe a larger set for the trails but i think 35s will do...It also has to be my DD!!
