![]() | #341 |
I wanna be Dave ![]() Join Date: Dec 2005 Location: Gold Bar
Got the rear brake lines ran along with the arb line and the line protected from heat and ran to where it will enter the cab.
![]() | #342 |
Making progress....
![]() | #343 |
Time to get the front of the car wired up....
![]() | #344 |
I got the whole front of the car fully wired up to the electrical center...
![]() | #345 |
More panels going on....
![]() | #346 |
I got the heater installed and holes popped thru the firewall and heater hoses ran. Its pretty tight but everything fits...
![]() | #347 |
I wanna be Dave Join Date: Feb 2009 Location: Seattle, Wa
How did I miss this thread, looking great bud! Let me know when I can take some photos and video of this beast in action. ![]() |
![]() | #348 |
I got the electrical center finalized and added mounts for the circuit breakers that will be used for the high output stuff.
![]() | #349 |
![]() | #350 |
I got the dome light and light bar installed and wired.
![]() | #351 |
I got the center console installed and the vent ran from the heater to the outlets....
![]() | #352 |
Everything starts with a mess with me,lol...
![]() | #353 |
So it took a bit of work and was certainly in a pretty confined area but I got the electrical center done. I did forget one circuit that I will add in this weekend but its pretty much done in here. I always build and then add fiuses per each system to test and verify.....
![]() | #354 |
So I got a bunch of stuff put into the car--center console/dash/switch pod and shifter. The shifter took a bit of work. I first found the backup lamp switch brackets on the shifter housing was binding up the shift cable. Once I got that fixed up it was a matter of figuring out the needed process to get the shifter into place--should be easier next time. With those items in I was able to start throwing voltage and was happy with the interior lighting... |
![]() | #355 |
So I got the sub box all done(wire pass thru installed) and installed and the center console storage and the wiring all hooked up.
![]() | #356 |
I got the air system all plumed and finished. I ran the pump and found a damn leak. Well low and behold both the arb solenoids were leaking. I suspect they had been leaking for some time as my old york seemed to come on too often. Got them both replaced and the system fully functions nicely.
![]() | #357 |
Got both seats and belts installed. Taking shape...
![]() | #358 |
Nobody ![]() Join Date: Sep 2008 Location: Maine
Man, what a thread to read from start to now. Your abilities are really admirable.
![]() | #359 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
First time in forever that I got sucked into a thread. I read this from start to finish this morning. Awesome Job! ![]() |
![]() | #360 |
Newbie Join Date: Apr 2016 Location: Chile
Impressive I think your next proyect must be a ford cobra clone or something like that |
Time to change it up!! Pic heavy | mudbeast2 | Axial SCX-10 | 18 | 05-23-2015 11:27 PM |
Time for a change | kookie31 | Axial SCX-10 | 2 | 04-17-2015 11:24 AM |
Time for a change | ManiacMagoo | Paint and Body | 1 | 07-10-2010 05:25 PM |
