![]() | #101 |
I wanna be Dave ![]() Join Date: Dec 2005 Location: Gold Bar
Time for some interior stuff. Since I want my heater mounted on the firewall I added some support tubes and will also be a mounting point for all the tin.. Got both tubes mounted, heater mount and first piece of tin cut/mounted... |
![]() | #102 |
Time to start the front section of the tranny tunnel. I am slowly getting better with my sheet metal brake. So I learned how to tig over 30 years ago and I have not done it since. So one thing I knew I would need--is a tig for doing aluminum since I hate my spool gun I have for my mig. So I bought a new CK unit and spent a few hours playing with it. So all the welds you will see from now on is simply me learning how to tig,lol... |
![]() | #103 |
So I built up a nice stash of cardboard and I will be chewing thru allot of it thru the build...
![]() | #104 |
So like I stated earlier this is being built more for trail use--and I love having a stereo. All my stereo goodies came in.. It will be a simplified system with my ipod and a simple volume knob. |
![]() | #105 |
I got both outer floor pans cut and mounted...
![]() | #106 |
My driveshafts finally arrived. They were made by a guy named Brian in the portland area. Have a bunch of guys out here who have ran his shafts with great luck and looking them over top quality.....
![]() | #107 |
Time to play with cardboard again ![]() |
![]() | #108 |
So I got both pieces cut out and as you can see they are angled upward at the center. This served 2 purposes it gave clearance for the rear t-case output so I didn't have to build the tunnel longer and actually gives the floor some rigidity. Both pieces are welded at the back seam to form a single piece.... |
![]() | #109 |
Rear driveshaft fits like a glove......
![]() | #110 |
I threw the front shaft in and I gotta build the center support brackets but I will bounce back to that later..
![]() | #111 |
Started trimming down the first part of the tranny tunnel I made and playing with cardboard. For the record I have nothing down on paper and been pretty much doing this by the seat of my pants---how I seem to roll the best.... ![]() |
![]() | #112 |
Started cutting alum. and make it evolve into something....
![]() | #113 |
I got the floor pan cut back to match the tunnel cover and threaded inserts installed...
![]() | #114 |
And there is the finished product. I still need to widen the holes for the t-case shifters and actually get the linkage where it needs to be--that will be for later. Crazy just how stiff the floor gets once thats bolted into place... |
![]() | #115 |
Like I said the only thing I am not happy with to this point is my tig work but at this point I only have like 5 hours using it.....
![]() | #116 |
So one thing I wanted was as much enclosure as possible since I will see allot of trail miles with this thing.. So next to do is the back wall. Here is the tool I made to hold the tabs I am using in place to weld them on. It lets me lay them on a flat plane and worked out really well..... |
![]() | #117 |
I tried many different methods to enclose the back and still keep the tin as close to the tube as possible... The only way I could pull it off was to build it in 3 pieces and weld it up.... But the fitment was nice and I tapped the tubework on the outer edges to hold the ends... |
![]() | #118 |
Now the last part of the floor was the tough one. It took multiple pieces but I was able to tie it into all portions of the floor and back wall. Interior turned out pretty decent and would have been better with nicer welds... ![]() |
![]() | #119 |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
Looks great! You CAD (cardboard aided design) skills are on point. ![]() |
![]() | #120 |
Ton of work getting accomplished from basically Jan. ![]() The shop looks great, well laid out and functional. The last car build thread I remember reading of yours, you were showing how to do a 4.3 conversion into a 'Yoter. |
Time to change it up!! Pic heavy | mudbeast2 | Axial SCX-10 | 18 | 05-23-2015 11:27 PM |
Time for a change | kookie31 | Axial SCX-10 | 2 | 04-17-2015 11:24 AM |
Time for a change | ManiacMagoo | Paint and Body | 1 | 07-10-2010 05:25 PM |
