Go Back   RCCrawler Forums > Miscellaneous > 1:1 Full Size Vehicles
Thread: The old girl is wore out--time for a change.
Old 07-31-2017, 10:19 PM   #121
Default Re: The old girl is wore out--time for a change.
Originally Posted by clm View Post
Looks great! You CAD (cardboard aided design) skills are on point.
Thanks. It just takes patience and you haven't seen anything yet
Originally Posted by BigSki View Post
Ton of work getting accomplished from basically Jan.
The shop looks great, well laid out and functional. The last car build thread I remember reading of yours, you were showing how to do a 4.3 conversion into a 'Yoter.
There is allot more done just gotta get it posted
Ya I love my new shop and our new place on 5 acres... I can pee in my driveway and shoot at the damn coyotes.. Ya did many 4.3 conversions in the toys,,,,
crash is offline   Reply With Quote
Old 08-01-2017, 12:24 AM   #122
So onto the fuel cell. I got the chassis prepped and built a bucket for the tank to sit down into...
Old 08-01-2017, 12:26 AM   #123
I made sure to really try my best to secure it to the chassis....
Old 08-01-2017, 12:27 AM   #124
So I started by making templates and then again cutting some aluminum....
Old 08-01-2017, 12:29 AM   #125
So I added a center support/ splash shield. It should help keep the tank from coming apart and keep the fuel from sloshing around too bad...
Old 08-01-2017, 12:33 AM   #126
So I added a rollover valve. Now the down side to this is the fact all the ones I found were 2 piece jobies. Now with this comes an issue with if the valve should come loose what do you do. Well I came up with this idea. I cut the hole in the top of the tank and fits the lower portion of the valve and will lock it into place keeping it from turning on the inside. I then cut a plate for the top side of the tank and welded it to the top so the valve sandwiches between that plate and seals against it...
Old 08-01-2017, 12:35 AM   #127
The fill for the tank. It has a rubber o-ring that seals it against the tank. I cut a ring that goes on the inside of the tank so I had more meat for the threads I tapped to hold onto.
Old 08-01-2017, 01:00 AM   #128
I fluid tested it for leaks and I was pretty proud of myself--just one seep at a corner... Easy fix...
Old 08-01-2017, 01:02 AM   #129
So I made the drop for the feed/return and then welded it to the tank. After that I air tested it and zero leaks.....
Old 08-01-2017, 01:04 AM   #130
So got the tank into the rig to double check fitment before building the hold down parts for the cell...
Old 08-01-2017, 01:07 AM   #131
So this is what I came up with. The mounts totally lock the tank and they also serve another purpose....
Old 08-01-2017, 01:08 AM   #132
So whats a good trail rig without a highlift jack....
Old 08-01-2017, 01:11 AM   #133
After every big part is done I just gotta clean my shop and reboot...
Old 08-01-2017, 01:12 AM   #134
All of my exhaust parts finally showed up...
Old 08-01-2017, 08:52 AM   #135
Awesome build.
You got great skills.
Cheers
Adakar is offline   Reply With Quote
Old 08-01-2017, 10:28 AM   #136
Moderator
JatoTheRipper's Avatar
I am in awe of this extremely detailed thread, your amazing fab skills, and your awesome shop! One of the best threads on this site.
I love the Chevy 4.3. Great motor. I find it funny it's powering your "Toyota". Hehe.
And those shocks are artwork.
Great work!
Old 08-01-2017, 03:38 PM   #137
Great thread! I'm really enjoying this - what a great quality build.
Highmark is online now   Reply With Quote
Old 08-01-2017, 05:28 PM   #138
Originally Posted by Adakar View Post
Awesome build.
Cheers
Great work!
Thanks guys--crazy to think what one guy can do and yes----all toyota's should have 4.3's......
Ya love my new shop--I made sure to change what I wanted and what I learned from my other shop for sure...
Old 08-01-2017, 05:33 PM   #139
So time for the front shaft. I started by roughing in the pillow block mount and I hugged the tranny as best as I could. If you look closely I built it with a shim to give me some adjustment and the only tight clearance is the starter bolt and thats a thick headed bolt so I can add clearance if need be.
Old 08-01-2017, 05:36 PM   #140
So of course I double checked clearance to mainly the links. I had a pretty small window between the upper/lower links on axle rotation side to side but just enough to make it all work....
The old girl is wore out--time for a change. - Similar Threads
Time to change it up!! Pic heavy mudbeast2 Axial SCX-10 18 05-23-2015 11:27 PM
Time for a change kookie31 Axial SCX-10 2 04-17-2015 11:24 AM
Time for a change ManiacMagoo Paint and Body 1 07-10-2010 05:25 PM
