09-03-2009, 02:40 AM | #1 |
Official Scale Nazi Join Date: Sep 2004 Location: Monticello, IL
| PFB's YJ
Funny how I've have a couple CC-01s and never have ran them much. To me 1.9s just look way too large on them. And the stock plastic tires are of course worthless. So once RC4WD released their 1.55s it was time to get busy. Built the re-release kit in about 4 hours and had the body painted and mounted in one more. I built it bone stock (even with bushings) just to get a feel for how it performs without modification. I used a Novak Rooster Crawler with a 70t Integy motor. Took it out last weekend for the first test run. There was an interesting mix of rigs on the trail. I did need to be strapped up a couple obstacles but it drove well for the most part. The 1.55 Mud Thrashers worked great. They perform just like the 1.9s. (Can't wait for the 1.55 Rock Stompers, they're going to look killer on this rig.) I dig the wheels as well. You just have to clearance the rear axle housing a bit to make them fit. I do not like the wheel nuts. I'm notching them at the ends so I can use a standard screwdriver blade to tighten them properly. I recommend using loctite on all the wheel hardware. I'm going to be modifying the hell out of it. I started by changing out the 70t motor to an 80t. The 70t running with a 7.2v 6-cell NIMH was just too wimpy in the torque department. I was stalling it out quite a bit. We'll see how the 80t works out. I'll try 70t & 3-Cell A123 if I don't have any luck. Hacked off the fender flares and side steps. I like the look of the full fendered YJs but I dig them cut more. I'll flat fender the fronts as soon as I unbury my dremel. I'll make some sliders and a rear tire carrier too. The spare tire needs to be mounted higher for better departure angle. Next up will be the brick wall mod. |
09-03-2009, 02:47 AM | #2 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
those wheels are perfect on that. Nice detail drawing in the panel joints.
09-03-2009, 02:49 AM | #3 |
Rock Crawler Join Date: Nov 2007 Location: San Bernardino
It are purdy....mmmmmm soo scaley.
09-03-2009, 02:56 AM | #4 |
RCC Addict Join Date: May 2005 Location: the land of the midnight sun
Love those wheels and tires on that Jeep,,a perfect match. |
09-03-2009, 03:35 AM | #5 |
2:30am I should be packing not Hacking! Didn't turn out quite as nice as Brett's but any clearance is better than having that garbage there. |
09-03-2009, 03:40 PM | #6 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
Awesome looking Jeep indeed. Looks real.
09-03-2009, 03:47 PM | #7 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
Those 1.5s look awesome on there! Great job!
09-03-2009, 03:51 PM | #8 |
Nice work PFB, looking good. I am loving brett's old YJ, I drive it almost daily. |
09-03-2009, 05:01 PM | #9 | |
-Got more work done before hitting the sack last night. I notched the 1.55 wheel nuts so that I can better tighten them. Then I finished up the "brick wall" reshaping. Still not as much clearance as I wanted but again anything is better than the stock piece. Now I have to reshape those inner fender wells that stick out. Next will be more steering angle. These things definitely need more. | |
09-03-2009, 05:57 PM | #10 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
09-03-2009, 07:16 PM | #11 |
Too late she's all glued up. (L-A-Z-Y) Your way looks much easier though. I think all my metal was packed up. Just happened to find a sheet of abs lucky enough last night that wasn't packed yet.
09-03-2009, 09:03 PM | #12 |
your jeep looks great though. i'm also waiting for the 1.55 stompers. its taking way too long for these to be released
09-06-2009, 06:17 PM | #13 |
| is there any scale rig you can't build in a bad ass way Nathan? seriously, I am loving my CC-01 as well, nice work on the front and fenders. |
09-07-2009, 12:05 AM | #14 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Yj
Thats a great looking Jeep my friend. Nice trail run pics. |
09-07-2009, 12:28 AM | #15 | |
Put some aluminum sheet so the ABS wouldn't be destroyed so much. Got the fenders and side molding all shaped up. Needs sliders bad. Profile I'm still not happy after I changed from the 70t to the 80t motor. Think I'll go back to the 70t and stick another esc in it so I can run 3s lipo. The gearbox is just too tall for the high traction rocks out here. It'd be fine in loose stuff because you'd need the wheelspeed. | |
09-07-2009, 04:01 AM | #16 |
Rock Crawler Join Date: Oct 2006 Location: Germany
Looking awesome ! This is exactly how I would do a jeep, I love the white colour with the black grille. Great wheels also ! Pete |
09-09-2009, 01:07 AM | #17 |
Doubled the steering throw of the stock kit. The front arms drop a little lower now too. No more stalling issues. (Even the 80t wasn't suited for my style of driving) HPI GRU. 55t motor is too slow but it should crawl alot more controlled now. Some hacking is required to fit the GRU. You do lose the stock 6-cell location. I'm just going to use a slimer 4S2P Lipo. Thanks to Romulus for the idea. I steal! |
09-09-2009, 02:29 PM | #18 |
| for the battery just make a plate and mount it up front. i made mine from an upper deck of an HPI rally. can mount any battery you want up there |
09-09-2009, 10:28 PM | #19 |
WILE E. CYOTE, super genius.... |
09-09-2009, 11:17 PM | #20 |
you need a better license plate.
