09-22-2009, 12:58 AM | #1 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
| Loco FJ-01
This is my first CC-01 build, it is inspired by seeing locals like Charlie, IWARC and helbentrodder bash their capable little rigs and the UTRCRC scale adventure series. The body will come from my now defunct Loco FJ build that lost its' axles to my 1.9 Campbell XRRA rockracer. Was lucky to get a YJ Wrangler CC-01 before they offically went disco'd, love the packaging that Tamiya does for hard bodies Started of the build and just had to install ball bearings, got a bunch of all the weird sizes now for my collection... When I assembled the transmission and rear end I used some nice grease from Fast Eddie I assembled the rest of the chassis per the directions but was not impressed with the llink set up, the lowers were just super flexy and shouck mount was counter active...weird So I decided to fab up all kind of aluminun goodies to fix that and a couple other issues... |
09-22-2009, 01:11 AM | #2 |
With the axle all assembled... ...I realized that the longer WB position makes the rear drive shaft just way too long. To deal with that I decided to make a pilot bearing from a TLT knuckle, some aluminum box, a 5mm R2 trans output shaft cast-off and some pede shafts, also some metal Axial yokes. All assembled with MRC shocks... |
09-22-2009, 01:18 AM | #3 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
nice fab work. although it looks like your shock mount is same as original. What did you do differently? is it just that its got its own bracket now? Also, the peices connecting the short and long wb link mount locations (lowers to chassis), is the purpose of those to act as a skid? if so, brilliant! Nice work on the driveshaft too. I'm also using MRC shocks and they're about the same length but narrower overall so look more scale. |
09-22-2009, 01:27 AM | #4 |
When I assembled the front suspension I notched the axles-C for more travel and to mount the MRC shocks up front I made a small derin block to give them more preload. I also cut the front lower section of the chassis for better approach and then glued a piece of 80thou black styrene to the gaping hole Pantablo, to answer your question... At first I made those Al. shock brackets to run the shocks in the stock location but since the MRCs are softer than stock I had to flip the brackets around 180 deg ... ...you can also see the front Al. skid that came off the Loco FJ (no mod required) |
09-22-2009, 06:03 AM | #5 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
Looking great Erik. can't wait to see this in action.
09-22-2009, 09:52 AM | #6 |
Rock Stacker Join Date: Aug 2005 Location: Austin
| good work
I agree, excellent fabrication work. Since you have the fab skills, will you be fabbing up an aluminum steering crank replacement? The driveshaft work is outstanding, and so scale.
09-22-2009, 12:33 PM | #7 |
Pebble Pounder Join Date: Nov 2008 Location: Reno NV
I really like what you did on the rear, I tried to 3 link mine with no luck, Are you willing to fab another 4 link set and sell it to me? What body are you running? Thanks James |
09-22-2009, 01:17 PM | #8 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
You got some nice fab work there ,now we wait to see what youre going to do for the steering. Last edited by vipxj; 09-22-2009 at 01:19 PM. |
09-22-2009, 03:00 PM | #9 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
09-22-2009, 03:15 PM | #10 |
Quarry Creeper Join Date: Jan 2008 Location: san jose
very nice build. cant wait to see the rest
09-22-2009, 10:13 PM | #11 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
09-23-2009, 04:11 AM | #12 |
Rock Stacker Join Date: Dec 2007 Location: Morristown
What rods did you use to make the links or is it all custom?
09-24-2009, 07:14 PM | #13 |
09-24-2009, 10:57 PM | #14 | |||
links are all custom, i use K&S 3/16" aluminum tubing, the part number is 3060 http://www3.towerhobbies.com/cgi-bin...0&I=LXS020&P=K | |||
09-24-2009, 11:07 PM | #15 |
Couple quick pics of the 1.5" wheels and tires that i picked up Here is the stance, it sits pretty good with the MRC shocks and the black springs in front and the silver ones in the rear articulation is pretty nice for a CC-01, i think i'll like this little rig... Something cool i was working on is a Reign scale antena turned into a whip. First I shortened the antenna to 8 inches, then I wrapped some 24AWG copper wire around it last i applied some white 1/16" shrink tubing and a small red cap came out pretty nice, functional too |
09-24-2009, 11:27 PM | #16 |
that looks great! Nice work on the antenna.
09-25-2009, 12:57 PM | #17 |
slapped a winch mount on it using 64thou aluminum sheet quick mock of the body to make some mounts, rear is sitting a littlr high here but there is no battery or elctronics in it yet will look good with some bumpers on there... |
09-26-2009, 10:48 AM | #18 |
Pebble Pounder Join Date: Oct 2008 Location: Rohnert Park
| nice winch
Nice work Eric - the winch looks great. We should get all of the NBRCC CC-01s together and do a trail run! Put some scratches in that chassis |
09-30-2009, 10:18 PM | #19 |
Rock Crawler Join Date: May 2007 Location: Glendora
| on your fab skills. Nice & Clean. What are the specs on the aluminum you are using for the parts you fab'd? Thickness, finish, place of purchase, etc. Also, what are you using to cut and bend those piece so cleanly? Thanks.
10-01-2009, 04:24 PM | #20 | |
The aluminum sheet I usually use is 0.064" thick from K&S: http://www3.towerhobbies.com/cgi-bin...P?I=LXR912&P=8 for smaller brackets and stuff I use the 0.032" thick varity: http://www3.towerhobbies.com/cgi-bin...&I=LXR911&P=SM I cut the sheet with my band saw and finish the edges with a belt sander. I drill the holes with a drill press and then bend it using my bench vice. Normlly I finish all my aluminum stuff with a bead blaster for that matte satin look. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-5-scale-rigs/200854-loco-fj-01-a.html | ||||
ZONACRAWLING • Ver Tema - Tamiya Wrangler XC - por Skorpion_ | This thread | Refback | 10-05-2011 03:22 PM |
