Need some help deciding Here is the 1/10 CXT I picked up and need some suitable rims/tires that would look good under it.Right now I have this cxt http://i73.photobucket.com/albums/i2...SC_0001-32.jpg and will be doing it up to look similar to the F650 like this one http://i73.photobucket.com/albums/i2...utback11-1.jpg Its going to be mounted on extended high-lift rails. Have everything needed to start,just need some suitable rims with tires.My problem is do I run the 1.55 or are there 1.9's that would look better under it without lifting it too high,because most of the 1.9 rims/tires I have look a tad too big under the wheel wells and I dont want to have to cut into them,the front bumper is already done and its heavy duty.I really want this to look as close as possible to the F650 just as a CXT,may do a topper as well.Any suggestions from the tire gods? Would semi rims work on this or too small? |
I'm thinking the new 1.9 Dick cepeks would look killer: http://rc4wdstore.com/2/product_info...9322e43d11be95 |
Also thought about one of these 2 rigs http://i73.photobucket.com/albums/i210/kuatto/f650.jpg I was planning on doing but all black like the first,just the same topper. http://i73.photobucket.com/albums/i2...tto/north2.jpg I need to find another 1/10 CXT....:ror: |
Re: Need some help deciding Did you ever finish this build? I would like to see how it turned out. |
