04-07-2011, 10:27 PM | #41 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
04-08-2011, 12:54 AM | #42 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Man that's a swell looking Toyota! Chino like. |
04-08-2011, 07:02 AM | #43 |
04-08-2011, 11:33 AM | #44 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Very nice paint job. What did you for the silver trim? |
04-08-2011, 11:41 AM | #45 |
04-08-2011, 04:46 PM | #46 |
The blue looks amazing as does the decal set. I hope you are using metal cross members on the chassis, that z9100t is going to bend the frame! I use the same servo in my 15 lb. Willys.
04-10-2011, 10:30 AM | #47 |
Rock Crawler Join Date: Apr 2008 Location: Albany
Well Tommy you are building another awesome rig. Nice job. I had 1979 Toy 4x4 with grafix that look the same. My was yellow () and the grafix where two shades of tan. YUCK. Yours looks amazing. Evan (ORCRC) |
04-10-2011, 09:44 PM | #48 | ||
- I want the body sitting low on the frame (no body lift) and the rear-facing spur gear locknut it hitting the front of the bed. Not a problem, but the body needs to come farther forward. I'll likely clearance the bed and cover it with a small toolbox or something. - It's going to be tough to have a clean looking bumper with winch fairlead attached to the chassis with the front fascia of the truck extending so far. I may trim it all off, but it may take on more of a "hardcore crawler" appearance and I want this one to look mild. We'll see... I've been waiting on the new RC Bros. leaf spring kit. I definitely want leafs in the rear and may consider them for the front, too, but the release keeps getting delayed. Soon I'll have to cut my losses and fall back to plan B: Use stock SCX10 links and scrap the plan to use leafs. | ||
04-11-2011, 12:47 PM | #49 |
MMP all sealed up and waterproofed. I barely got it to fit back in it's original case! The brushless connectors will get some silicon. I'm going to put the rx in a balloon. I may waterproof the servo similar to the ESC, but I'll add dielectric grease to the splined output, as well. To better explain an issue I'm having, I took a few pics. You'll see in this pic, the front axle is a little too far forward in the fender opening....just barely. So the body needs to slide forward just a bit. Here's the issue I've got. The shaft of the tranny hits the bed, preventing the body from sliding farther forward. I could raise the body and then it could slide forward, but I want the body slammed on the chassis so that's out. I could slide the front axle back with shorter links, but I like the relationship between the steering servo, track bar, tie rod, etc. so I won't change that. I could flip the tranny around, but then the spur gear would prevent my interior from going in. So really, the only viable option is to clearance the bed a little bit so the body can slide forward ~1/4". I hate to cut into the bed at all, but I think I'll just build a small toolbox for the bed to hide the hole. Any other thoughts? |
04-11-2011, 12:57 PM | #50 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
i would cut a nice little circle hole.man your paint is awesome |
04-11-2011, 02:15 PM | #51 |
Pebble Pounder Join Date: Jan 2010 Location: flatland
Ditto on the small hole. That is an awesome job on the body and paint.
04-11-2011, 03:19 PM | #52 |
Rock Stacker Join Date: Nov 2007 Location: Austin
Hey Tommy, I have an idea! A few months back I fabbed a delrin piece for Ric's honcho that moves the tranny forward. I can do the same for you if you like to try it before you go ahead and cut the bed. If I remember correctly it moves the tranny forward 1/2" but up 1/4" LMK |
04-11-2011, 05:08 PM | #53 | |
What this dude said...make a custom cross member that is offset to the front. I had a similiar issue with my yellow hilux after I did the drop bed. I simply re drilled the holes in the cross member because it was a simple delrin block. | |
04-11-2011, 05:27 PM | #54 | ||
Wally, I appreciate the offer, but I think I'll just make an adapter plate from aluminum. Thanks, though!! | ||
04-11-2011, 07:53 PM | #55 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
I like the Tool box idea What if you removed the slipper? Is there a shorter spur axle ( I'm not sure the tech name for it ) I know I've seen guys remove their slipper clutch before. Me personally I would add a full tool box to the bed. I'm really likeing this build by the way, youv'e done a great job |
04-11-2011, 08:00 PM | #56 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
ditch the slipper....it will get ya bout a 1/4inch looks to be bout what ya need Drail the axial drive gear shaft #AX30197..5x43.5 and get a venom gear adaptor #VEN-4017 Last edited by Drail; 04-11-2011 at 08:07 PM. |
04-11-2011, 08:29 PM | #57 | |
04-11-2011, 08:48 PM | #58 |
| happy to help brotha. I ran into the same problume the last scaler build Drail |
04-12-2011, 09:03 AM | #59 |
DRAIL beat me too it. i ran in to the same problem on my clod. the non slipper version saved me about 3/8" i think the spur plate axial tree number is AX8009 |
04-12-2011, 09:08 AM | #60 |
Yeah, definitely seems to be the way to go, especially since I didn't really want to use a slipper anyway. Woo hoo! No cutting of the bed! |
