Re: BlueBronco budget build very nice work on the axial trans with trasefercase. Ive been wanting to do that for awhile now, but couldnt figure out how too. Im not a ford fan but that bronco looks great. "thumbsup" J. |
Re: BlueBronco budget build Quote:
Matt |
Re: BlueBronco budget build More styrene, more glue, lots of measuring, eyeballing, taking it all apart and tryin over last night got me to this point. http://img.photobucket.com/albums/v1...psdc7c9795.jpg http://img.photobucket.com/albums/v1...psc49fc9ea.jpg http://img.photobucket.com/albums/v1...psdd6c6b6f.jpg Got the firewall roughed in inside and out to clear the trans, spur and pinion. I still need to smooth some stuff out and then itll be good. It clears everything juuuuust barely at the moment but it does clear. I also trimmed the rear "bed" walls due to them bein about 1/4" too tall (which was annoying). Ide like to move on to smoothing it all up, sealing it (shoe goo for strength) and then look at putting a dash together. Then I gotta figure out what I wanna do to mount it all together with the body/frame. Matt |
Sent from my EVO using Tapatalk |
Re: BlueBronco budget build Good to hear man!!! Sent these pics to a couple people this weekend...figured Ide share em here this morning. I think Ive lost my mind. Started small http://img.photobucket.com/albums/v1...psdd844261.jpg And then spread like crazy http://img.photobucket.com/albums/v1...psc5657bc4.jpg I did alot of work this weekend sealing up the rear tub, getting it ready to mate with the rear fenders and tailgate and putting together some LEDs in the rear before i seal it all up. While waiting for some of that to dry I got to work on the dashboard in an attempt to try and get this thing ready for finishing touches and paint. What a mess. http://img.photobucket.com/albums/v1...psffbe1089.jpg Heres the only shot I got of the dash. I have made some progress since this shot but forgot to snap a pic. http://img.photobucket.com/albums/v1...ps60a3a096.jpg Matt |
Re: BlueBronco budget build I have been playing around with doing this to the enclosed body i got for mine. with out the whole splitting it all up. was thinking about making the top removable though. |
Re: BlueBronco budget build Another evening, another little bit of progress LOL. I found some slightly larger aluminum tubing the other day while on a Styrene run so I put together some tips for the Bronco. I wasnt super happy with the size of the other tubing I was using so this is perfect. I dont like flashy exhaust tips so Ill keep it looking like your standard exhaust pipe. http://img.photobucket.com/albums/v1...psb75cdfef.jpg Heres a shot of the complete exhaust. Just a couple tweaks here and there when the body comes together and Itll be set. http://img.photobucket.com/albums/v1...ps16f2d376.jpg FINALLY got the parts in I needed (after 2 weeks of waiting for USPS to walk them to me from AZ) to complete the stub shaft between the trans and transfer. I brazed it together with safety silv and then tried my damndest to get it to break and its held up so far. Only trail abuse will tell if itll hold but Im happy for now. http://img.photobucket.com/albums/v1...ps32548b93.jpg She's a runner! Runs pretty decent too. Now Ive got it pretty much 100% mechanically running, just need to get the body/tub together and mounted then I can start running electronics a little better. http://img.photobucket.com/albums/v1...psaa7ad814.jpg I also got some work done on the dash and tub. I added alot of silly little details to the underside of the tub just because. Ive got to figure out how I plan to mount it to the frame and then smooth some stuff out, paint it and move on. As for the dash, I got everything where I want it and just need to paint it so I can add final details then attach it to the tub later. I also had a fun idea for my lighting setup but more on that later! LEDs are finished gluing into the rear body panels so now I can move on to attaching it to the tub and priming and painting it all! Matt |
Re: BlueBronco budget build I see you chose to mount the t-case as so you will have an overdriven frontend |
Matt |
Re: BlueBronco budget build Even with a tf2 or g2 trans and coupling, it'd still look more like a divorced case setup than a stock 1:1 would look. Bout the only way to get the stock look would be to runa fracture v8, then your front chunk would be on the wrong side for a stock 1:1 ford Just my $0.02"thumbsup" |
Re: BlueBronco budget build True, would look closer than what Ive got but not enough to make it worth foolin with so for now, divorced with a custom skid it is! Matt |
Re: BlueBronco budget build Last night was spent waiting for paint and ShoeGoo to dry mostly so I didnt get much of anything done. I got the tub in primer and ready for the rear panels to go on http://img.photobucket.com/albums/v1...psd28d128b.jpg I also went ahead and primed/painted the dash to get an idea on what Im lookin at and also allow me to start detailing it. http://img.photobucket.com/albums/v1...ps1b99f9ec.jpg http://img.photobucket.com/albums/v1...pscd462ec1.jpg Im debating on whether I want to keep it fresh and clean or weather it a bit as if the paint job is old. I will probably repaint the outside panels so it will look shiny and new for a bit but when the abuse catches up I would like the interior to match. Ill figure it out lol. I was also workin on the trans and transfer shifters and wasnt super happy with the axial parts so I started making my own. I then accidentally knocked my transfer shifter (modded axial piece) down the drain (dont ask, it was a hitch hiker when taking pics of the tub and I didnt realized it till it was gone LOL) which made me mad but now forces me to make my own which I shoulda done in the first place. Slowly but surely its starting to come together! Matt |
Re: BlueBronco budget build Looks real good man, I like it a lot. I've been following this one for a long time, and damn, she's had a rough life haha What are you using for the styrene joints, shoe-goo and a bonding agent (Tenax or similar)? |
Re: BlueBronco budget build Tenax mostly and shoegoo once its all together in certain areas for extra strength where it might need it. Works really well so far! Matt |
Re: BlueBronco budget build Between gettin the house ready for Christmas with the Family and shopping, spending time with everyone AND bein sick, I havnt had much time to work on the Bronco which is a slight bummer lol. I did get the dash sorted out and lookin pretty decent tho! http://img.photobucket.com/albums/v1...ps785eee38.jpg http://img.photobucket.com/albums/v1...ps3a47a3c3.jpg Been foolin with some shift levers and am tryin to figure out how I wanna make boots for them, then I can toss them on, add some small details here and there and get ready to glue the tub together!!! Merry Christmas everyone, hope yall have a great time with those you love and care for! Matt |
Re: BlueBronco budget build Very nice job with the dash"thumbsup", wish I had the motivation to work on mine :mrgreen: |
Re: BlueBronco budget build Shoot, yours and LoneRanger's 1.55 builds ARE my motivation to take this rig to the next level! I have untold number of pics of your rig printed off to use as reference and help keep me on track! Matt |
Re: BlueBronco budget build Totally off the hook dude. Can't wait for more progress... |
Re: BlueBronco budget build Got a little work on the dash done, gonna show off one of a few little tricks that I thought of...tinkered with then said "Hell...why NOT!?!?" In 1:1 world, I would have moved the light switch down to where the dual tank switch is but in scale terms, this was the best place I could put this and be able to get at it easily. Lights Off http://img.photobucket.com/albums/v1...psfdbeacae.jpg Lights On http://img.photobucket.com/albums/v1...ps3f41c8da.jpg Heres how I did it. http://img.photobucket.com/albums/v1...ps85525a61.jpg Put a panel behind the dash for the switch to mount to, drilled the switch for the nail to go through, cut the nail to length and groved it to grab the switch and then JBwelded it together. All I need to do now is finish up the lighting on the body and then solder it all together. Im thinkin I will put the battery to run the lights behind the other side of the dash and make the dash removeable for easy access. Im excited to see it all in action when its all together! I also started completely over on my transmission shifter and should have it done shortly. Ide like to move on to the front fenders of the inner tub and get the rear body mounted soon so I can paint it. After all that I can finally have some fun adding little details but I dont wanna rush just yet. Matt |
Re: BlueBronco budget build Awesome switch! "thumbsup" ...and rest of truck! haha |
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
