02-20-2017, 04:35 PM | #381 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| Re: BlueBronco budget build
PERFECT solution for hiding the battery!~ L.R. |
02-20-2017, 06:55 PM | #382 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
Ha, thanks!!! I will be putting it to the test this coming Sat and look forward to seeing how all my latest work holds up. If I can hit the trails all day without touching the tools too often, Ill be happy as can be!!! Matt |
02-27-2017, 09:07 AM | #383 |
Weeellll...the BlueBronco wasnt all that happy to be out and about this past weekend. The suspension was a bit off (I was noticing some issues with the front shocks while trying to get it ready to go) and it was really low on power plus it was cogging alot when trying to just lean into it lightly which threw it off of some tight lines. At the end of the day we determined that all of my OLD LiPos are junk which probably caused those issues. Eventually it snapped the new pin on the short stub shaft between the trans and the transfer case ending its day...but not before she posed for the camera on a couple obstacles. Gonna put some better trans guts in it, rebuild that shaft and try to change some things to make the angle a little better for it. Im also thinking some shorter shocks up front will do it good as well. Matt |
02-27-2017, 12:05 PM | #384 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
All that scale awesomeness but no driver? Sent from my LGMS210 using Tapatalk |
02-27-2017, 01:23 PM | #385 |
Nope, driver hoped out to take pics of his rig LOL IF I ever were to find a good enough looking driver figure Ide happily add it to the rig, but I cant see putting any wrestlers or similar in there. I would have to find something more real. Matt |
02-27-2017, 01:28 PM | #386 |
I looked for a long time too. I recently found a perfectly sized terminator arnold and a cop from the same movie. The rig he is driving has windows so its hard to notice who he is. Id rather have just a random guy but he does look good. Sent from my LGMS210 using Tapatalk Last edited by Jcplante; 02-27-2017 at 05:43 PM. |
