Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: Szczerba's Montero
Old 11-18-2014, 10:59 AM   #21
Default Szczerba's Montero
Originally Posted by STANG KILLA SS View Post
very nice kit
Loops Model makes alot of cool parts. They have a Facebook page in Czech/English but you'll have to translate their webpage.
The dash parts are thick, kinda heavyweight plastic while the bumper and bumper topper is thinner, lighter plastic with a rubber coating of sort.
Szczerba is offline   Reply With Quote
Old 11-18-2014, 07:19 PM   #22
Default Re: Szczerba's Montero
Nothing fancy here. Just bolting on a Loops Model front bumper.
Backend again
Old 11-18-2014, 07:22 PM   #23
It looks awesome, Shane! Who knew I would like a Mitsubishi!!
Lentsnh2012 is offline   Reply With Quote
Old 11-23-2014, 05:11 AM   #24
So what part do you leave for the front bumper to install? Just a chunk of the stock one?
canadianbacon is offline   Reply With Quote
Old 11-23-2014, 11:09 AM   #25
Same here. Ill be starting on the interior after the thanksgiving break.
See first picture in post #22
Old 11-23-2014, 12:04 PM   #26
That is one hell of a nice truck
dubfreak is offline   Reply With Quote
Old 11-25-2014, 03:14 PM   #27
Thanks.
While out in the Reno area, I stopped by CKRC and picked up some Dinky RC goodies. And I just placed an order with Dinky for a few more interior items.
Old 11-30-2014, 05:25 PM   #28
Looking good! Liking those RC4WD BFG's & wheels with the body. Excited to see where this goes
Crawl Space is offline   Reply With Quote
Old 12-09-2014, 07:08 PM   #29
Thanks.
Installed the Dinky RC rear cantilever setup.
Welded some tabs to the Dinky R/C TLT 4 Link mount. Ill have to play around with shock to 4-link turnbuckle lengths.
Is flexy, will need some limiting straps.
Old 12-17-2014, 06:23 PM   #30
I really have no idea why Tamiya didn't make a Montero body as well as the Pajero. That's absolutely killer! I'll be following this!
Hpi-guy is offline   Reply With Quote
Old 12-19-2014, 06:09 PM   #31
If someone were to nitpick it, they could say that those wheels are the wrong bolt pattern since Paj's and Monty's used 6 lugs
It is going to be interesting though with that interior, can't wait to see what you come up with. What are your plans for clear windows, just sheet lexan?
Old 12-19-2014, 06:24 PM   #32
Body work goes to bonards29. See link in first post. Loops Models from the Czech sells the montero body based off the Pajero as well for a decent price n
I am not familiar with alot of 1:1 running gear, so I have no clue. Haha. I just like the look of the wheels on this rig.
Honestly, the swapping out the front glass with a clear piece is what us holding me up. That and my other 4 projects I am working on.
I am not sure what to use up front. Any suggestions, pics or links to what others have done? Ive searched a little bit but not alot.
Old 12-19-2014, 07:40 PM   #33
You could use this:
TowerHobbies.com | Plastruct Clear Sheet Styrene .010" (3)
It's thin enough to not have to use heat to shape it and you can still glue it to the body.
Old 12-19-2014, 07:43 PM   #34
You could use this:
Awesome. Thanks. The windshield isnt as curvy as I thought. That 0.010 looks like a good setup.
Old 12-20-2014, 06:07 AM   #35
Location: Taylors Falls just hanging with the MNRCRC crew.
Nice work Shane sitting in tha garage it looks like the real deal.
Stormin2u is offline   Reply With Quote
Old 12-20-2014, 08:07 AM   #36
This is coming along really well! Love scale builds like this!
Can't wait to see this finished interior. I had to do the same with my cabin cruiser windshield and my Audi Quattro which had quite an arch. A good hair dryer and patience is a virtue, it's not as difficult as one might think. They came out fantastic. The material in the link is prob. a better bet though.
tokdl is offline   Reply With Quote
Old 12-20-2014, 08:18 AM   #37
I probably should clean up the garage sometime too.
I am balancing this build with a jeep build, a TTC truck build and a brushless gimbal setup build for my iphone.
I'll probably hold off on the Montero work until I get in the windshield material so I'll know where ill need to mount the dash, etc.
I have been debating an interior cause it is going to add more weight with these molded interior pieces. But I guess I will do it for the sake of scaleness. Well, as scale I can build it.
Old 12-20-2014, 09:48 AM   #38
That's understandable, I'm in the middle of a JK build myself. Both my TF2's interiors added a noticeable amount of weight, thankfully it was more toward the front of the truck so I can use it to my advantage, to a point. Seeing as your Montero has such a scale 1:1 appearance, it's almost a crime not to show off a detailed interior . Either way I'm sure it will look fantastic.
Old 01-02-2015, 06:58 PM   #39
Ordered up some RC4WD Old Man Emu's and shock boots.
Fronts bolted in.
Old 01-02-2015, 09:36 PM   #40
New links.
McMaster-Carr 1/4" standoffs with ends threaded 8/32". About $1.50 each.
McMaster-Carr 8/32" threaded studs
Carter Fab and Machine metal fab tabs. Welded to chassis for rear upper link adjustment.
Will burn in fully later.
Tags
#trollinszczerba
Szczerba's Montero - Similar Threads
My Matzilla Montero sgtbham 1.9 Scale Rigs 46 04-07-2014 07:25 PM
95 Montero sgtbham Paint and Body 21 04-04-2014 04:04 PM
montero video ROLANDROCKSHOP Scale Videos! 2 01-19-2011 06:05 PM
Montero teaser ROLANDROCKSHOP Scale Videos! 0 01-15-2011 08:12 PM
