Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: 1984 Toyota 4Runner
Old 05-12-2013, 04:07 PM   #1
Default 1984 Toyota 4Runner
I never thought I'd do this again...
Mutilated Tamiya Hilux body with some extra styrene glued to it.
It started out as a Trail Finder 2. I swapped the 2 speed for an Axial transmission, flipped the front spring hangers and shackles, stuck the steering servo on the correct side, raised the transfer case and narrowed the yota axles.
pardonmyn00b is offline   Reply With Quote
Old 05-12-2013, 04:20 PM   #2
Sub'd the first one was frickin awesome!
xigtc is offline   Reply With Quote
Old 05-12-2013, 04:21 PM   #3
Default Re: 1984 Toyota 4Runner
You have a sickness noob
boosted4lyf is offline   Reply With Quote
Old 05-12-2013, 04:40 PM   #4
LOVE the narrowed axles man, dang you always do what I wish I could!!! Lookin forward to seein this sucker come along!
Matt
66sprint6 is offline   Reply With Quote
Old 05-12-2013, 04:54 PM   #5
yeah..cant wait for this one!!
briang is offline   Reply With Quote
Old 05-12-2013, 07:27 PM   #6
Nice truck.
imthatguy is offline   Reply With Quote
Old 05-12-2013, 07:29 PM   #7
subscribed :thumbsup:
mitchr97 is offline   Reply With Quote
Old 05-12-2013, 08:44 PM   #8
sweeeeeeeeeet.
Illeagle is offline   Reply With Quote
Old 05-12-2013, 09:24 PM   #9
The new track width looks perfect.
BigSki is offline   Reply With Quote
Old 05-12-2013, 09:41 PM   #10
You and these power wagons;).
2.slowduo is offline   Reply With Quote
Old 05-12-2013, 11:57 PM   #11
Really nice body work, love the mod on those axles!
Do you have closeups on the axial transmission fix?
Sqbiedoo is offline   Reply With Quote
Old 05-13-2013, 04:42 AM   #12
Wow Noob! your styrene skills know no bounds do they?!!!
Metal Masher is offline   Reply With Quote
Old 05-13-2013, 07:06 PM   #13
Looking forward to it. Looking good so far
gueroaero is offline   Reply With Quote
Old 05-17-2013, 01:54 PM   #14
Sinking with the ship
1BadJeepBruiser's Avatar
More details on axle narrowing please!
Was wondering when you were gonna start on your mini me
Old 05-17-2013, 03:27 PM   #15
Thank you!
I think it's terminal
Matt
Thanks Matt!
Right on!
Originally Posted by imthatguy View Post
Nice truck.
I like Jeeps.
Originally Posted by Illeagle View Post
sweeeeeeeeeet.
Yay!
Thanks
I do and it couldn't be easier. The holes are already in the chassis and line up with the Axial transmission. I added a strip of aluminum on the bottom to help keep the transmission closed since it wasn't attached. If you like to run big power you could add a plate to cover the whole thing.
I like to see how far I can go. Sometimes it's successful, but other times...
Thank you
Well, you cut the axle and take some stuff out and put it back together. Pretty complicated stuff and junk.
Actually, I don't have many pictures of the process since I was experimenting and didn't know if it would work. I removed 10mm from each side of the axles. I drilled the housing out to accept some aluminum tubing I had laying around. Then I cut a section out of the housing and used JB Weld to stick it back together. I figured out a way to make the axles come apart for service if they needed it. The axle shafts were just cut and brazed back together. I have no idea if this is going to hold up to actual use, but I'm going to take it easy on this truck anyway.
Little update. This is how it's going to sit.
Old 05-17-2013, 04:54 PM   #16
wow im lost for words youu work is always top notch
dzb dirty is offline   Reply With Quote
Old 05-17-2013, 09:36 PM   #17
It looks like the perches and shock mounts are moved around...very slick work. I might have to skinny up the axles under the bronco a tad. Top notch work as usual man keep it up!!!
Matt
Old 05-18-2013, 06:26 PM   #18
Thank you very much
Matt
That is correct. It's a simple and free mod and makes the front suspension more accurate. Let me test these axles out before you go and cut into yours! Thanks.
Quick diversion from bodywork. The spare.
New.
Under a truck for 28 years.
Old 05-19-2013, 05:27 AM   #19
Damn.
N00b, that weathering detail
So this 4runner is going to be open air? I'm sure your interior will be masterful! Sub'd on this build
Cheers,
Doc
doc.hamilton is offline   Reply With Quote
Old 05-19-2013, 12:55 PM   #20
Originally Posted by doc.hamilton View Post
Damn.
Cheers,
Doc
There will be a removable hardtop like a proper 4Runner should have. Speaking of which...
I made a lot of dust today.
1984 Toyota 4Runner - Similar Threads
1984 toyota truck body built by noob lappdogg 1.9 Scale Rigs 10 10-12-2012 01:46 PM
Toyota 4Runner markturbo Scale Videos! 2 05-16-2012 09:07 PM
1984-1988 Toyota Hilux body Icer.One 1.9 Scale Rigs 3 07-13-2011 08:41 PM
