Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: Scale cj7 class 1
Old 12-17-2015, 07:52 PM   #21
Default Re: Scale cj7 class 1
Originally Posted by mudweaver View Post
personally I think leafs all the way around would be killer!!
I'm still thinking about it but maybe for another rig ;)
Sent from my SM-G900T using Tapatalk
donnielovett is offline   Reply With Quote
Old 12-17-2015, 07:53 PM   #22
Originally Posted by Big Daddy View Post
Looks great, I like it.
Going to take a whole lot of fender flare to cover half the tires.
Yes I've come to realize that I don't meet class 1 spec anymore and love the look too much lol
Old 12-18-2015, 03:39 PM   #23
Class 1 rules are tight. I'm just building what I like and if it fits in a class I can be competitive in that's great otherwise it was fun either way
Sent from my SM-G920R4 using Tapatalk
LamChop is offline   Reply With Quote
Old 12-18-2015, 11:08 PM   #24
I feel ya man I feel it's way over kill for class 1 but I like it so much I won't change but hey if they let It compete I'll run it, or just a more scale class 2!
Old 12-22-2015, 11:06 PM   #25
Decided to comp cut the rear fenders and hopefully brown santa comes tomorrow with the rest of my steering parts and front engine mount so I can figure out tcase and link mounts.
Old 12-24-2015, 07:51 PM   #26
Put in the gcm front motor mount and put on the steering
Old 12-25-2015, 10:21 PM   #27
Finished trimming the rear of the body out for the stretched look
Old 01-05-2016, 11:35 PM   #28
My tcase came in tonight so I was able to mount it to the scx10 skid and get my links on so now it's a roller! I still have some spring mounting issues for the rear (I made my first set wrong) and planning on running the gcm 3 Link kit with their pan hard bar setup
Old 01-06-2016, 03:31 PM   #29
Would u mind posting a few more pics of how u mounted the t-case as I am using the same t-case on the SCX skid and haven't figured out how to mount it. Thanks
Di_Spencer is offline   Reply With Quote
Old 01-06-2016, 06:21 PM   #30
I took a Dremel, and removed all the ribs on the inside and the 4 holes that originally mount the Trans Dremel that completely down flat so the tcase lays flat, the. Measure how far apart the mounting holes in the tf2 case are (I used dial calipers) then drill them out to 3mm. Really just sand all the ribs in the skit down and flat.
Old 01-06-2016, 11:06 PM   #31
I was fighting pinion angles so I'm re mounting the front of the spring to help, lot os trial and error with this build and having to shim the axle as well.
Old 01-12-2016, 11:53 PM   #32
Since I have posted progress in a bit thought I'd share the class 2 beater I just finished for the first Comp of the year that's coming up, and then I'll be back on the cj/yj jeep!
Old 01-23-2016, 06:36 PM   #33
Finally back the the jeep, I had these trex 60 axles laying in a box for a few years and finally decided to use them on this build since getting scx10 axles to work was proving to be more of a pain. Next week I'll order new spring mounts for the front since I decided to do leafs front and rear
Old 01-23-2016, 07:41 PM   #34
Yea, glad u went with more scale axles. Starting to turn out nice.
Jeepfixer1 is offline   Reply With Quote
Old 01-30-2016, 07:10 PM   #35
Pretty much mounted the body the other night and finished all the drive shafts, now comes a game of where to mount electronics
Old 01-31-2016, 10:59 AM   #36
That rear driveshaft looks just like a real jeep as far as length. May have lo lower your transfer case ��
Old 02-04-2016, 08:27 PM   #37
She's coming along!
Old 02-04-2016, 09:28 PM   #38
As much as I wish it sat lower, the short wheel base stuff was really messing with it so I needed as much length as possible without making it look stupid, but no more binding!
Old 02-04-2016, 09:30 PM   #39
Been a minute since I've posted, got a little time to work on it again, I mounted the body pretty much permanently and kinda getting a feel for how I want the chop top to look I might have to move my thread to the class 2 forums now!
Old 02-05-2016, 07:51 PM   #40
Got one of the doors chopped, along with the hard top to, and letting the glue sit all night before I start on the other door along with filling in the gaps on the top with styrene
Scale cj7 class 1 - Similar Threads
Wrangler to cj7 parts or cj7 body? lynxer Tamiya XC/CC01 2 06-09-2015 06:23 PM
scale jeep cj7 (functional mode) twissted Scale Videos! 4 09-02-2014 08:23 PM
scale jeep cj7 (functional mode) twissted Videos! 0 09-02-2014 12:22 AM
