12-21-2015, 06:26 AM | #21 |
Pebble Pounder Join Date: Dec 2015 Location: Essex
| Re: Scale EB Build Thanks, I still need to get the mig dialed in. i keep blowing through the 16 guage steel towards the end because the part is so small it heats up too fast but when I dial back the amps, the bead just balls up. May need to try casting them like the real ones. |
12-21-2015, 08:41 AM | #22 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: Scale EB Build
Can you silver solder them? Seems like it might be the way to go.
12-21-2015, 09:14 AM | #23 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
| Re: Scale EB Build
Or brazing?
12-21-2015, 01:25 PM | #24 |
Pebble Pounder Join Date: Feb 2015 Location: Bay area
| Re: Scale EB Build Instead of turning down your juice, try turning up your wire speed. You'll have to weld a bit faster, but it will keep your heat from getting too localized.
12-21-2015, 01:41 PM | #25 |
| Re: Scale EB Build |
12-21-2015, 01:47 PM | #26 | |
| Re: Scale EB Build Quote:
HMMMMMM???? | |
12-22-2015, 10:39 AM | #27 | ||||
Great thread so far! | ||||
12-26-2015, 08:17 PM | #28 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| Re: Scale EB Build
Ok, I have kept quiet for a while- the radius arms look stellar. In my opinion however it isn't gonna cut it for a tiny truck! (It will looks epic, but perform horrible!) No worries though! Keep after it! Your metal bits look much better than mine did! You should absolutely run the R4 trans along with the LRTcase in this rig. And as such I would suggest you get those NOW as you can base a lot of your bracing and what not off of them. Narrow GCM terramod axles would be my choice, and that too directly interfaces with the radius arm setup. Choose your body NOW as well, my guess would be for either the vattera bronco or the HPI version. Wait, are you building a full styrene hardbody? Just throwing that out there! :d When (or if) you get burned out, shelve it for a while and come back to the project fresh! L.R. |
12-28-2015, 08:30 AM | #29 |
| Re: Scale EB Build
Thanks LoneRanger for the compliment and advise on what to run. I love the look of the R4 but haven't really done enough homework on motors, esc's and axles. Open to any and all input there. I like the look of the rear toyota axle (looks close to a ford 9) and there look to be lots of options for the front. I kind of need to decide soon in order to get the correct axle tube thickness for finishing the radius arms, motor mounts and transfer case. On that subject, I was thinking about doing the wristed arm modification to get the articulation a bit better. I will also scale up the rubber C bushings for a bit more play. My wife also ordered the Tamiya bronco body for me for Christmas. I will be using it as a mold for an all metal body. I've already started bending up the floor support channels, inner rockers and floor pans. Need to figure out how to make a mini bead roller now or a way to press the beads into the floor pans.
12-28-2015, 12:24 PM | #30 |
| Re: Scale EB Build
RC4WD K44 axles would look awesome under that.
12-28-2015, 04:38 PM | #31 |
12-28-2015, 06:12 PM | #32 |
| Re: Scale EB Build
just found this... looks perfect. too bad i can't afford it :( GCM Racing WebStore-2015 - R4 Married LRT-Case Pre-Order |
12-29-2015, 04:32 AM | #33 |
| Re: Scale EB Build
^THAT is what I was referring to. Forget what you can't afford, and buy what you NEED to have on this build! :-) I used k44's on mine and hated them. Cheaply built, pot metal, etc.... Results may vary. L.R. |
12-30-2015, 09:18 AM | #34 |
12-30-2015, 10:09 AM | #35 |
| Re: Scale EB Build
Looks awesome! I'm running the k44's on mine, they do look nice and seem to be plenty strong, but there isn't any options as far as gearing is concerned.
12-30-2015, 10:28 AM | #36 | ||
Quote: | ||
01-02-2016, 04:55 AM | #37 |
| Re: Scale EB Build
Wow, that floor is looking fabulous! Dig up an image of a 1:1 bronco floor pan to show them how nice it really looks! L.R. |
01-03-2016, 01:46 PM | #38 | |
Test fit: | |
01-04-2016, 12:00 AM | #39 |
Rock Stacker Join Date: Oct 2010 Location: At my work bench.
| Re: Scale EB Build
This is an amazing build so far. I am also building a 1.5 bronco but not quite to this detail. The best part is I have a 1:1 68 eb and even time you post I go and look at the part. You are right on. Great job.
01-04-2016, 08:06 AM | #40 | |
Thanks a bunch! I'm trying to keep it as scale as possible (within reason-whatever that is) | |
Scale EB Build - Similar Threads | ||||
~The Scale Shop~ 2008 Scale Nationals Rubicon 2.2 Tuber Build | STANG KILLA SS | 2.2 Scale Rigs | 103 | 12-10-2010 05:49 PM |
