02-07-2016, 12:36 PM | #101 |
Pebble Pounder Join Date: Dec 2015 Location: Essex
| Re: Scale EB Build
On to the rear fender wells. I started with making a form out of some scrap maple. I then measured up the dimensions so I could figure out the best way to wrap the metal without getting bad folds. I started with a paper template and that worked out well so I moved on to the metal version. I was happy with the detail I was able to get once I soldered the seams. A bit of filler prior to paint should hide them completely. I also started on the filler neck panels that go on both sides of the drivers side wheel well. They need a bit more fitting to close the gaps but that should be pretty easy compared to the rest of it. |
02-08-2016, 06:20 PM | #102 |
| Re: Scale EB Build |
02-08-2016, 07:09 PM | #103 |
Quarry Creeper Join Date: Feb 2008 Location: The Schwa
| Re: Scale EB Build
Woah! Fricken excellent. Love the steel. |
02-09-2016, 03:39 AM | #104 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| Re: Scale EB Build
Just amazing fab skills.....very cool!
02-09-2016, 05:09 AM | #105 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
| Re: Scale EB Build
Truly outstanding work! The level of detail is fantastic.
02-09-2016, 11:27 AM | #106 |
| Re: Scale EB Build
thanks for all the comments guys! Nowhere near the amount of detail Metal Masher gets with his aluminum but i'm giving it my best Last edited by 802Bronco; 02-09-2016 at 03:20 PM. |
02-11-2016, 09:45 PM | #107 |
Newbie Join Date: Jul 2015 Location: Northern Illinois
| Re: Scale EB Build
That bed is amazing! This things gonna be heavy!
02-13-2016, 07:10 AM | #108 |
02-13-2016, 07:51 AM | #109 |
Newbie Join Date: May 2008 Location: Birmingham, AL
| Re: Scale EB Build
Hold on this was discussed in the past. Weight is not simply divided by 10 to scale it down 10 times. Something to do with the equation of mass and the 3 dimensions of length, width & height. Sent from my SAMSUNG-SM-G850A using Tapatalk |
02-13-2016, 08:31 AM | #110 |
| Re: Scale EB Build http://www.rccrawler.com/forum/showt...sible numbers? As discussed in this thread it is concluded that weight is 3 dimensional and so must be divided by 10 3 times. A 5000 lbs rig would weigh 5 lbs. Sent from my SAMSUNG-SM-G850A using Tapatalk |
02-15-2016, 01:34 PM | #111 | |
| Re: Scale EB Build Quote:
but thanks for the link. that is actually really cool to know and i impressed my physics/science geek son with my new found knowlege | |
02-16-2016, 03:10 PM | #112 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
02-16-2016, 04:03 PM | #113 | |
Has anyone ever figured a way to do scale window regulators for roll up windows? | |
02-16-2016, 04:07 PM | #114 |
02-22-2016, 07:54 AM | #115 |
Pebble Pounder Join Date: Jan 2015 Location: lebanon
| Re: Scale EB Build
This thing is super bad ass cant wait to see more of if |
02-23-2016, 07:03 AM | #116 |
02-23-2016, 07:27 AM | #117 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
| Re: Scale EB Build
Marvelous work on this build Sir!! How are you Making the indentations in the metal? are you creating press molds or just pounding them into the metal with hammers and metal shapes? I se a few pages back you used a chisel did you just make a grove in the metal beneath the part and then place the chisel above that and strike it?
02-23-2016, 10:03 PM | #118 | |
02-24-2016, 07:39 AM | #119 |
| Re: Scale EB Build
Here is the work so far on the gate. Made the measured drawing and cut out the ford lettering from some 14 guage sheet steel. I had to redo the letter O twice because i dropped it on the shop floor and it vanished GRRRRRRRR! After about 15 minutes on my hands and knees with a welding magnet and wisk broom I gave up and made another one. I kind of rushed these a bit so nothing show quality here, just proof of concept and I snapped of the drill bit I used to drill out the counters in the letters. 3M spray mount them to the template that is already glued to the sheet. Placed in the vise with a piece of wood on the receiving side and vise jaw directly against the letters results in this. Attempting to hand work around the letters from the front side got a bit more detail but also dinged up the sheet a bit too much for my liking. Think this might require a male and female die set to get the crisp edge I want. Moving along... The start of shaping and fitting. Last edited by 802Bronco; 02-24-2016 at 07:42 AM. |
02-24-2016, 02:29 PM | #120 |
Quarry Creeper Join Date: Apr 2013 Location: Oroville
| Re: Scale EB Build
Ok I'm not much of a Ford guy but this is lookin bad ass. I'm goin to watch this one.
Scale EB Build - Similar Threads | ||||
~The Scale Shop~ 2008 Scale Nationals Rubicon 2.2 Tuber Build | STANG KILLA SS | 2.2 Scale Rigs | 103 | 12-10-2010 05:49 PM |
