01-15-2016, 07:36 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: St John, IN
| Spots GMC Topkick Dually tow pig
It been quite a while since I have posted. Life has been busy and I haven't had much time for crawling. My kids are old enough now to get into crawling, so each of them got a SCX10 for Christmas. After building those over the past few weeks, I have the itch again. I am starting with a Proline Topkick body. I picked up a used highlift that was 4 linked over a year ago that I have done nothing with. I plan to use this as the base for the build. I will need to extend the wheelbase to fit the longer body. I like the idea of the 3 speed trans for a tow pig although this will not allow for any type of interior since this setup takes up TONS of room. If I don't like how it turns out, I may swap it out for a CC01 Chassis that will also need a length adjustment. I am going with 1.7 tractor truck rims, but I am putting 1.55 MTZ's on them to get the correct look. The wheels and tires should arrive tomorrow so look for pics then. Last edited by spot me 2; 01-15-2016 at 07:46 PM. |
01-16-2016, 04:24 PM | #2 |
| Re: Spots GMC Topkick Dually tow pig
Let me start by saying the rim/tire combo is exactly what I was going for. I think they look great and fit this body well. I lengthened the WB on the highlift last night and got it close. It would still need a little tweaking to get it just right. But running the highlift isn't going to work. The wheels stick out a little farther than I would like them to. I had a few idea's on how to bring them in a little, but the back tires already rub on the hubs, so there is no room to move them in. Looks like the highlift will head back to the shelf for a future project. Now its time to start lengthening the CR01. I mounted the back rims on just to test fit, and the width is almost perfect. Now, do I hack up the new one, or one of the old ones... |
01-16-2016, 07:19 PM | #3 |
I have the WB worked out on the CC01 chassis. I really like how the wheels almost completely tuck under the body. That is a scale look I was going for. There is nowhere to connect the shocks yet so I set a tire under the frame to hold it up. I need to work out lengthening the frame. I may use an SCX10 frame I have laying around and cut off what I need. I will work out the ride height from there. I will also need to add a center carrier for the rear drive shaft at it is waaaaaaay too long to function properly now. |
01-16-2016, 07:49 PM | #4 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
can you install rear straight axles in the rear so it won't rub?
01-16-2016, 07:59 PM | #5 |
| Re: Spots GMC Topkick Dually tow pig I thought about that. I still don't think I could bring the wheels in enough for my liking. I am really going for a scale look. On most of these trucks the wheels and tries completely tuck under the body. I realize the Topkick has a solid axle under the front, and using the CC01 will give it IFS, but its close enough for my taste....at least for now. Can always do a solid axle swap down the road.
01-16-2016, 08:12 PM | #6 |
Rock Crawler Join Date: May 2013 Location: Dallas
Man, that cc01 setup looks perfect. Can you run slightly narrower hexes in the back to bring it in line with the fender?
01-16-2016, 09:10 PM | #7 |
Rig looks great. Love the wheel and tire combo.
01-17-2016, 08:14 AM | #8 |
| Re: Spots GMC Topkick Dually tow pig |
01-17-2016, 12:25 PM | #9 |
Got the extended frame worked out, now I just need to change the location of the upper links. There is not enough triangulation and the rear end has a lot of side to side play. I thought about a panhard bar, but this rear axle just doesn't have anywhere to even mount one.
01-18-2016, 04:17 PM | #10 |
So here are a few shots of how I extended the frame along with how I mounted the shocks. I may change how the shocks are mounted. The frame is now just long enough for the back bumper to rest on the frame. This will work out perfect once I am able to find the correct bumpers for this thing. I would love some that look like the Road Armor bumpers of the full size, but can't find anything close. Any ideas on what bumpers would look good? Here is how I worked out better triangulation with the back links. I will smooth this out and use the same hardware when finished. Just wanted to see if it would help. It got rid of 95% of the side to side motion. I can live with that. And one of how close to the ride height it will be. I know the back is sitting up a little high, but when I hooked up the trailer, it sat down to the perfect height. Since it will always have a trailer behind it with either a truck or boat in tow, it worked out well. don't forget to add your $.02 about what bumpers to use. I may take a stab at making some out of polystyrene of I can't find some. |
01-20-2016, 01:32 PM | #11 |
I cut the bumpers off the body so I could have a blank slate to look at to help decide which way to go. I took some teaser pics of it hooked up to one of my boats, but Photobucket is down for maintenance...so you will have to weight.
01-21-2016, 07:51 AM | #12 |
Alright Photobucket is back up. I adjusted the ride height in the rear. It just sat to high before. I think its almost perfect now with and without a trailer hooked up. and of coarse, one of the Cat. She isn't finished yet. I still need to wrap the hatch and mount the scoop, but you can see where the design is going. Last edited by spot me 2; 01-21-2016 at 08:02 AM. |
01-21-2016, 08:38 AM | #13 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Love it !!!! I am building my own tow rig/hauler right now.... Do you have a link to those wheels ? How deep is the offset in the rear ? If the wheels are mounted on equal width front and rear axles, how much wider is the rear, if any wider ? |
01-21-2016, 01:09 PM | #14 | |
| Re: Spots GMC Topkick Dually tow pig Quote:
Tamiya 1 14 Tractor Truck Aluminum Rear Wheels Silver 2 x Spede TTR114R08 | eBay Don't know the offset as they don't have specs listed. I believe with narrow hex's on the back it would be very close. I ordered a set so I can let you know when they arrive. You have to modify the fronts to work. I will do a post on this also, but I am waiting on parts for this too. | |
01-23-2016, 06:41 AM | #15 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
I love top kicks. My buddies shop uses one to tow their trailer to races. I've driven it, and it's one hell of a truck.
01-28-2016, 01:14 PM | #16 | |
I have a scale version of his boat. I still need to build a trailer for it. | |
Spots GMC Topkick Dually tow pig - Similar Threads | ||||
Gmc topkick | mmatthews | 1.9 Scale Rigs | 55 | 02-04-2013 06:51 PM |
Another GMC Topkick | trucker bob | 1.9 Scale Rigs | 41 | 06-29-2011 06:27 PM |
Proline GMC Topkick | GR1MM18 | Paint and Body | 4 | 07-20-2010 10:29 AM |
