04-10-2016, 06:49 AM | #1 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| The Blazer/Charger or I May Be Nuts?
Ok, so call me crazy but I do have another Gasser project in mind, and I still have a few loose ends with the Willys, but here is where you guys may think that I've gone off the rails a bit. I REALLY like the RC4wd K5 Blazer kit. BUT I REALLY REALLY like the Dodge Ramcharger too. But no one makes the hard body version, so, here I go, my next build - I am going thru some pre-planning, and I mentioned elsewhere that my next build would be a Mopar, so I am going to attempt to take a perfectly good K5 and try to morph it into a Ramcharger, the early '90's version. Of course there is the numerous issues, top doesn't come off, tailgate is one piece, wheel well, body lines, bulges HOLY CRAP, maybe I should re-think it? NAH!!!!! So here I go begins with it sitting on it's chassis, just a SCX10 with some goodies, on with the inspiration! So here's the plastic surgery list..... Trim/remove wheel opening flares Trim/reduce the stock character lines, fade them mid doors and before "Dodge" rear quarter panel bumps Trim K5 door locks Fill front marker lights Fill lower sill plate/rocker panel TF2 mounting holes Remove/relocate rear tailgate handle Combine rear hatch/tailgate, expand rear cap opening Raise cap side glass openings to match Ramcharger's Trim hood, leading edge to match Ramcharger's Add rear quarter "bump outs" Raise upper character lines Add '70 'Cuda AAR hood scoop Increase taillight opening size Add material to leading edge of front fenders, Dodge is more vertical – K5 had a slight cant Inspiration pic... Sit'in stock.... Let the surgery begin! Trimming back the leading edge of the hood.... |
04-10-2016, 02:22 PM | #2 |
| Re: The Blazer/Charger or I May Be Nuts? |
04-10-2016, 03:39 PM | #3 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
Nice looking hood scoop.
04-10-2016, 04:08 PM | #4 |
MODERATOR Join Date: Oct 2010 Location: RC Land
Looking good. Not sure what your plans are for the doors, but to get the mopar look instead of the GM, you might need to cut the top of the doors off a bit and lower the tops and fill the opening a bit as part of the roof. GM doors seem to go to roofline Mopar roofs seem to roll over the edge some resulting in some of the roof being seen over door opening. Which would also help with the rear window when extended larger in height to be more Mopar-ish. Looking good, great idea Last edited by THX_138; 04-10-2016 at 04:11 PM. |
04-10-2016, 04:41 PM | #5 |
WooHoo!!, another killer fabrication |
04-11-2016, 07:45 PM | #6 |
Reminds me of an past builder from scale4x4, she used to convert the Clod bodies into dudge turks. Can't remember her screen name. It looks like you're on the right track! |
04-11-2016, 09:59 PM | #7 |
Quarry Creeper Join Date: Jan 2014 Location: el paso
Can't wait to see this one done Sent from my SM-G920T using Tapatalk |
04-13-2016, 07:24 PM | #8 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
Ohh my, if I hadn't seen your progress, I'd of said your nuts. You do some sweet work! Can't wait to see how this turns out.
04-16-2016, 11:37 AM | #9 |
Thanks for the comments and advice guys! Here's a quick Blazer/Charger update. Body work is a little further along. Added the roof drip rail, raised the cap side glass openings, revamped the grill, smoothed most of the body side details, smoothed the tailgate, removed the K5 details, made the rear tailgate a one piece unit with lifts.. And the tough part, deciding what to do with the cap. So far I do not want to "weld it" like the '93 would have been. I am using dowel pins to locate it and will be adding magnets to secure it. Problem is the RC4WD cap expands a bit where it meets the bed and doesn't look as smooth as the real deal. |
04-21-2016, 06:17 PM | #10 |
Time for a Blazer/Charger update. I hid a couple magnets in the upper sides of the bed, couldn't recess them as far as I wanted so there is a very small cap that covers them. The at the rear of the top/cap there's a couple hidden as well. The "flip upside down" test so far works, between the dowel pins and the magnets its pretty secure. Filled a couple of unwanted holes in the bed by the tailgate. Added the front grill inserts, framed the rear taillight openings and gave it the first coat of primer. Now for lots of block sanding, filler and more primer. |
04-21-2016, 06:51 PM | #11 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Hey Joe, for no longer than you have been doing styrene your skills and imagination are amazing. I would never have thought to try this conversion let alone be able to do it! You are a true artist, and a huge asset to this form. Keep up the good work!!! Ernie, |
04-21-2016, 07:15 PM | #12 |
| Re: The Blazer/Charger or I May Be Nuts? Ernie, wow man greatly appreciate the kind words. I't truly a hobby I enjoy. And as you may have read, I really thought I was crazy to attempt this. It's not in color yet so there's a long way to go. BTW your builds a freaking awesome as well!
04-24-2016, 12:35 PM | #13 |
04-25-2016, 04:22 PM | #14 |
04-26-2016, 08:38 AM | #15 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
holy craftsmanship! not even 3d printed! wow. your really making me miss my ramcharger...
04-26-2016, 06:16 PM | #16 |
04-26-2016, 07:15 PM | #17 |
Loving the ramcharger joe, can't wait to see it finished! |
04-26-2016, 07:45 PM | #18 |
You always see chevy engines go into everything it is nice to see a mopar engine going into a chevy. Nice work on the detail on the engine. Love six paks.
04-27-2016, 08:46 AM | #19 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Wow, all around coolness. Keep up the great work !
04-27-2016, 12:16 PM | #20 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
This is freaking awesome! |
The Blazer/Charger or I May Be Nuts? - Similar Threads | ||||
Barrel nuts !!!!!!!!!!!!!I'm going nuts | mydoddy69 | Losi Micro-Rock Crawler | 10 | 09-12-2011 05:32 PM |
Using a Blazer CGR interior inside a 'full top' PLR Blazer body-Has anyone done this? | BeeRC | Paint and Body | 4 | 10-31-2009 03:37 PM |
Nascarkeith's Proline Blazer CGR Bodied Blazer Wheely King | nascarkeith | HPI Wheely King | 6 | 10-30-2009 02:49 AM |
