01-30-2017, 08:32 AM | #21 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Old Kaiser Custom build by an I.D.10.T
Lots of custom awesomeness |
02-01-2017, 11:17 AM | #22 |
Rock Crawler Join Date: Apr 2012 Location: Bella Vista
| Re: Old Kaiser Custom build by an I.D.10.T |
02-01-2017, 11:58 AM | #23 |
Rock Crawler Join Date: Oct 2010 Location: pickens county
Suspension looks like it works well Sent from my SM-G935V using Tapatalk |
02-01-2017, 12:19 PM | #24 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
^^ yeah very well. i have heard of people saying leafs dont flex well but im going to do a leaf rig next and i dont care how bad flex is.. 1:1.. and will figure it out.. LOL killer job.. fyi my 1:1 had a rear winch in between the frame rails. mount is there but sold the winch... |
02-01-2017, 12:53 PM | #25 | ||
| Re: Old Kaiser Custom build by an I.D.10.T Quote:
Yes, it will flex some. I found a really neat thread by Chino63 on how to get more flex from your springs. He tapered the loop on the shackle side so that the leaf springs would flex more. I tried that on this too. I works nicely. As for my next build, after I finish the Raptor, I am going to do another leaf spring truck. I'm gathering parts now. Look for it in the 2.2 section. I think I will hopefully start on it in March. | ||
02-06-2017, 07:43 PM | #26 |
I learned something about my axles today when I was able to drive this truck a bit. It already had over and under gears. i fell like I won a prize in the 'claw' machine.
02-09-2017, 04:33 AM | #27 |
Sweet. You need to look at m energy's xr10 axle mod. He converted his losi axles to use xr10 hubs, knuckles, and axles for the front. Sent from my SM-G935V using Tapatalk |
02-09-2017, 09:11 AM | #28 |
This is a super rad build! Awesome work.
02-12-2017, 06:45 PM | #29 |
02-12-2017, 06:47 PM | #30 |
02-12-2017, 06:47 PM | #31 |
Yes sir. I'm throwing money at the one I got off you lol. Sent from my SM-G935V using Tapatalk |
02-14-2017, 07:19 AM | #32 |
02-17-2017, 08:11 AM | #33 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
Love the build man. I especially like that inventiveness with the winch, very cool!
02-17-2017, 08:29 AM | #34 |
Quarry Creeper Join Date: Apr 2013 Location: Oroville
I wouldn't mind having a 6x6 flat bed version of this. Sent from my SAMSUNG-SGH-I337 using Tapatalk |
02-17-2017, 10:15 PM | #35 |
Newbie Join Date: Feb 2017 Location: Kennewick
Awesome job rig looks amazing. Sent from my iPhone using Tapatalk |
03-20-2017, 05:19 PM | #36 |
I ran this in our first comp of the season. I learned a lot about it quickly. I need some wheel weights or low end weight. Two, I need different driveshafts. The comp had two courses. On the first course, my front shaft slipped out twice. The first cost me a repair. The second cost me a timeout. I was a foot from the final gate on an uphill slick rock and trying to winch up it, but the front axle was locked in place, remember those Losi Comp Crawler axles, and it wouldn't pull over a small bump in the rock. It did fine on the second course. Steel shafts should help give it a little more low end weight. Next I'll check the wheels and axles for options. Suggestions? |
03-25-2017, 06:38 AM | #37 |
03-25-2017, 11:21 AM | #38 |
That really turned out nice |
03-26-2017, 07:37 AM | #39 |
I went forth on making myself some custom CI foams for this thing. It was set up on some stock foams, which would fold completely in the right situation. I took some 4.25 dense foams for 1.9 rims and cut them diagonally, grooved them for the wheel weights from the inside of the foams, and then taped them on for a snug fit. Outer foams were also cut to the correct diameter and glued before placing inside of the wheel. I used the red short course foams in the rear to have a more firm rear tire. I had to trim a little from each side for these to fit the tires. I did have to put the inner CI foam in to fill the space. I'll be testing them later today. Last edited by I.D.10.T; 03-26-2017 at 10:29 AM. |
03-26-2017, 04:30 PM | #40 |
Old Kaiser Custom build by an I.D.10.T - Similar Threads | ||||
TT Kaiser XS | The Crawl Space | General Crawlers | 58 | 07-02-2017 12:37 PM |
1974 Kaiser | Mechanicalbob | Chit Chat | 1 | 02-09-2007 04:15 AM |
