02-25-2017, 01:23 PM | #21 |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
| Re: Rickleo's Chevy Crew Cab Dually: BIG BOY |
02-26-2017, 01:53 PM | #22 |
Only had time to make the rear cab wall and put another piece of styrene on the bed wall today. Busy, busy, busy... Sent from my SM-N900V using Tapatalk |
02-27-2017, 08:08 AM | #23 |
Rock Stacker Join Date: Mar 2010 Location: Long Island
This is coming out GREAT, especially for your first 'true' attempt!! I do have one small critique... The only thing catching my eye is the spacing between the crew cab window and the front window (I think your crew cab portion is a little too long), I've had to redo crew cab conversions a few times because of this problem. However, I'm sure this would be a rather simple fix compared to what you've already accomplished! |
02-27-2017, 11:05 AM | #24 | |
| Re: Rickleo's Chevy Crew Cab Dually: BIG BOY Quote:
Sent from my SM-N900V using Tapatalk | |
02-27-2017, 12:43 PM | #25 |
OK. Taking scalecrawler18's advice I went to work on the cab. Pulled out the dremel and cut out a 4mm section between the front and rear door. Them glued everything back together. Now just have to let the glue cure then more sanding and filling, sanding and filling, sanding and filling. Like I said before. Good eye scalecrawler18 .......lol just kidding. Thanks friend. After all this cutting, graphing,transplanting, gluing, filling and sanding I feel like a mad scientist. I think I'ma change the name of this beast to Frankenstein. Sent from my SM-N900V using Tapatalk Last edited by Rickleo; 02-27-2017 at 12:47 PM. |
03-02-2017, 09:03 PM | #26 |
| Re: Rickleo's Chevy Crew Cab Dually: Frankenstein
OK still got a lot of work to do on the body but put it aside for now to work on the axles. Finally got in my second set of Lesu semi wheels and hubs in the mail yesterday. Thanks semijoe. I purchased the set of Yota 2s used so I gave them a good check inside and out. Found one screw head stripped and when I to use a slightly bigger hex to get it out the screw head broke in half. It was a real pain to get it out. But once I was inside I found that everything was A+. Well greased and very little wear. I purchased a pair of 10 bolt diff covers for them too. The rear went on fine. But when I went to bolt the cover on the front I realized that the hole wasn't drilled all the way through the axle to except the threads from the bolt. Bummer. Here's how the axles look now. If you look closely you can see the new cover on the rear axle and the original on the front. Now I'm debating whether to run them like this. Pour the original cover back on the rear. Or order a whole new front axle housing and hope the holes in that one are drilled all the way through. Has anyone else ever dealt with that problem? Moving forward. I was planning on making my own frame from 1/2 inch brass tube but ended up purchasing TF2 frame rails off ebay. They're pretty nice. I've had leaf springs and screws laying around for a while so I started wrenching. After a few minutes and a tired, sore wrist I had this Then I wanted to see what it looked like with wheels and tires Went this far so I had to throw a body on This give me an idea for my next project. A topless, doorless K5 trail truck. I need something for the dually to tow. That's all for now. Thanks for looking. Sent from my SM-N900V using Tapatalk |
03-04-2017, 05:33 AM | #27 |
A little more progress on this beast. Decided it was time to cut this perfectly good brand new frame, so with one swift karate chop I did this. Propped up the two frame pieces up and put the body on to get the wheel base. Using the 1\2 inch square tube, I cut off a 8 inch piece and split it down the middle to extend the frame rails. Put the body back on to see if I got it right. I'm liking it. That's all for now. Thanks for looking. Sent from my VS995 using Tapatalk |
03-09-2017, 07:18 PM | #28 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
I'm more of a Ford fan, but my k5 is one of my favorite trucks. Great build you've got going and the fact that it's a crewcab dually just puts it over the top! Keep up the great work! |
03-09-2017, 07:46 PM | #29 |
| Re: Rickleo's Chevy Crew Cab Dually: Frankenstein |
03-10-2017, 08:19 AM | #30 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS
Add some tail fins and it a land yacht Cadillac, just kidding. Looks great man, is this your first time working with a hard body? If so your giving me hope for my project lol |
03-10-2017, 10:01 AM | #31 | |
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS Quote:
Sent from my VS995 using Tapatalk | |
03-10-2017, 01:20 PM | #32 |
I just got a tamyia body yesterday, found one for about half of what I was finding them for so I jumped on it and found a grill for a good price too. I've never worked with styrene about but used to build 1/24- 1/25 models most I loosely followed the directions lol.
03-10-2017, 01:45 PM | #33 |
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS This is the F350 body I was working on before I started my Chevy build. I actually have the roof section in now and I also have the hood and grill section almost like I want it. But it's been set aside for now. Chevy always comes first lol. Sent from my VS995 using Tapatalk |
03-18-2017, 11:50 PM | #34 |
Made a little progress. Didn't like the bed length so added another section Added RC4WD Lift blocks Finally attached the square tube section to the frame using Loctite metal epoxy I think the overall length is better now Before: After: That's all for now. So what do you think? Thanks for looking. Sent from my VS995 using Tapatalk Last edited by Rickleo; 04-13-2017 at 09:03 AM. |
03-19-2017, 01:38 PM | #35 |
Looks good and square, I liked it with the first bed extension, but it's your model, and if you're happy with it, that's what matters. The brass rail that you're using, I know you said previously that you split box tubing, it doesn't look very strong, and are you planning to drill some holes and use some nuts and bolts where you used the metal epoxy? for extra re-enforcement. I know you're going to put a skid between the rails, but you might also consider some extra frame bracing since you're using leafs, to keep the frame from twisting. |
03-19-2017, 07:33 PM | #36 | |
As for the frame cross members. I haven't started on those yet. I have to figure the layout of the drivetrain before I get started. One step at a time. Thanks for your input. Very much appreciated. Sent from my VS995 using Tapatalk | |
09-04-2017, 04:56 PM | #37 |
Newbie Join Date: Aug 2017 Location: Plain well,mi
Killer job!! This is one of my favorite builds I've seen absolutely amazing work👍👍 would love to see if you finished it? Hope to see more on this
09-05-2017, 03:56 AM | #38 | |
09-26-2017, 12:59 AM | #39 |
More progress on Bruticus. Wanted more beefy axles so I added Quiksteel to the yota axles for a more military look and added strength. I like the way it's coming along. What you think? Sent from my VS995 using Tapatalk |
09-26-2017, 01:05 AM | #40 |
Every strong truck need a strong engine and Bruticus is no exception. A Cummins 6bt! This is my first attempt at anything scratch built so ih hope it turns out like I want it. Sent from my VS995 using Tapatalk |
Rickleo's Chevy Crew Cab Dually: BRUTICUS - Similar Threads | ||||
K30 Chevy Crew Cab Dually Wrecker by Trailworx Garage | H2Micr0 | 1.5 Scale Rigs | 24 | 02-19-2017 08:47 PM |
chevy crew cab dually | S10XtremeSR | Micro Scale Rigs | 4 | 03-22-2015 05:18 PM |
Chevy Crew Cab Dually | makaveliks | 1.9 Scale Rigs | 222 | 11-17-2014 08:32 AM |
