12-14-2017, 06:02 PM | #101 |
Pebble Pounder Join Date: Feb 2015 Location: Kansas city
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS |
12-15-2017, 06:22 AM | #102 | |
Quarry Creeper Join Date: Apr 2012 Location: Harrisburg
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS Quote:
Sent from my HTC Desire 626 using Tapatalk | |
12-15-2017, 06:57 AM | #103 | |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
Sent from my VS995 using Tapatalk | |
12-16-2017, 08:30 AM | #104 |
Very little progress. Fabbed up some simple motor mounts. Then I decided to try to install the electronics to get this thing moving. Not so lucky. Couldn't get the throttle to work correctly. Kept starting and stopping. The steering servo worked good. Too good. It had so much torque it broke the welds on the leaf spring mounts. Quick fix tho. Reinforced them with a brass plate and screws. Last edited by Rickleo; 12-16-2017 at 08:48 AM. |
12-20-2017, 02:34 PM | #105 |
Changes are coming........
12-26-2017, 10:17 AM | #106 |
Update: Realized the thin brass chassis was too weak so................. I made a new chassis from steel! I'll let the pics do the talking. |
12-26-2017, 10:25 AM | #107 |
More pics... |
12-26-2017, 10:34 AM | #108 |
Have to shorten the bed... |
12-30-2017, 05:36 AM | #109 |
Progress update: Added a crossmember at the rear shackle mounts for added strength. Fabricated a engine mount crossmember for the Cummins to rest. Still might add some more bracing for strength AND still need to build a rear crossmember for the trans. Removed the carrier bearing from the rear of that trans and attracted the trans shaft straight to the transfer case. Just like most 1:1. Cummins diesel looks right at home between the new frame rails doesn't it? Now I'm at the point where I was before I decided to make the new chassis. Everything from here on is real progress. Till next time. Thanks for looking...... |
01-02-2018, 10:00 AM | #110 |
Rebuild: After staring at the engine mount crossmember for a while, I just wasn't feeling it. The wasn't beefy enough compared to the rest of the frame. So I rebuilt it. Bigger. Stronger. I'm extremely proud of how the crossmember turned out. Now the Cummins sits in between the frame rails under it's own weight for the first time. |
01-02-2018, 05:04 PM | #111 |
Nice fab work. Looking good.
01-03-2018, 04:43 AM | #112 |
01-05-2018, 04:43 AM | #113 |
Update: Got the bed cut to fit the truck. Think I like this shorter version better. Found these scale hubs in my parts bin. Forgot I had them. Thought they would look good on Bruticus. Whatcha think? |
01-05-2018, 04:55 PM | #114 |
01-05-2018, 07:27 PM | #115 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
This thing is awesome. |
01-05-2018, 09:36 PM | #116 |
01-05-2018, 09:39 PM | #117 |
01-06-2018, 08:42 AM | #118 |
Update: I know most of you liked what I did with the axles but for months I've been debating whether I was going to keep it or not. Decided it has to go....... Shout out to Quiksteel for making an awesome product. When they say permenant bond they mean it. I actually had to chisel this stuff off the axle it was so strong. Took me, it seem, hours to get the axle all cleaned up. I used the same Quiksteel on the axle housing cover to round the cover to look like a military axle housing cover. Might use it to make the axle tubes square also. (like in the first pic) Still have ti compete the same process on the rear axle. Uhhh! Watcha think? Thanks for looking |
01-08-2018, 04:26 PM | #119 | |
01-08-2018, 07:04 PM | #120 |
Rickleo's Chevy Crew Cab Dually: BRUTICUS - Similar Threads | ||||
K30 Chevy Crew Cab Dually Wrecker by Trailworx Garage | H2Micr0 | 1.5 Scale Rigs | 24 | 02-19-2017 08:47 PM |
chevy crew cab dually | S10XtremeSR | Micro Scale Rigs | 4 | 03-22-2015 05:18 PM |
Chevy Crew Cab Dually | makaveliks | 1.9 Scale Rigs | 222 | 11-17-2014 08:32 AM |
