01-29-2018, 01:20 AM | #141 |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS
Update: Work continued on this massive bumper. Added some scrap metal plates on the bottom corners and metal round stock to make the lower portion of the bumper. That is all. |
01-29-2018, 07:01 PM | #142 |
Pebble Pounder Join Date: Feb 2015 Location: Kansas city
That thing is massive. Will the bumper tuck in anymore?
01-29-2018, 07:24 PM | #143 |
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS |
01-29-2018, 07:51 PM | #144 |
01-29-2018, 07:59 PM | #145 |
01-29-2018, 08:01 PM | #146 |
01-29-2018, 08:03 PM | #147 |
02-01-2018, 10:52 PM | #148 |
Update: After looking at the massive front boomer for a while it wasn't in line with the theme I wanted for Bruticus. The bumper looked more apocalypse than military lol. So I built a new one and kept it simple. Like the old military boomers it's just one piece of steel bent slightly on each end. I used round bar stock to make the grill guard then welded it to the bumper. I like the look better than the old bumper. It looks like a bumper someone threw together on Friday so they could hit the trails on Saturday. Simply yet effective. Still had a problem with the tire slightly rubbing the servo arm under suspension compression, had to come up with a solution. Purchased some Hot Racing 15mm wheel hub extensions. After having to file down the extensions to get the pin screw to fit and boring out the hole in the wheel 1mm or so to get the thread sleeve in the new wheel nut to pass though, everything came together nicely. Like the wider stance of the front. Looks more aggressive. So watcha think? That's all for now. Til next time. |
02-03-2018, 04:03 AM | #149 |
Update: With all the air being rammed into the Cummins engine I needed a way to cool it. An intercooler. But I wasn't sure I had the space for one. Searching Google for ideas I came across the perfect intercooler on a Cummins diesel that was transplanted into a Suburban. It was exactly what I was looking for. So styrene cutting began. The end results was a nice engine to mounted intercooler. Now the diesel can get the cold dense air it need to create all the power I'm going to put to it. That's all for now. Til next time. Thanks for looking. |
02-06-2018, 09:28 AM | #150 |
Rock Stacker Join Date: Jan 2017 Location: Kennesaw
That is some sweet chassis! What a beast! What Planetary Gearbox did you use? What Ratio is it? |
02-06-2018, 09:54 AM | #151 |
02-06-2018, 01:31 PM | #152 |
Awesome, thanks for the response. I can't wait to see video of this monster rolling (or lumbering) along.
02-08-2018, 12:07 PM | #153 |
Update: Finally got the drivetrain in installed. The transfer case is now connected to the transmission like on most 1:1s. Also figured out how to make a crossmember to support it. That created another problem. The distance from the transfer case to the rear end was almost 260mm! Way to long for the driveshaft I had purchased. Lucky I had some shafts laying around from another project that never got off the ground. So I decided to add another crossmember that will hold a carrier bearing. I cut the extra driveshaft down to connect the t case to the carrier bearing. Hope all these shafts hold up under the stress of pulling this heavy behemoth around. Only time will tell. Bruticus is coming along slowly but surely. And I most say my boy is looking mean! I'd like to thank everyone for following, commenting, complimenting, and giving advice. Very much appreciated. But...the journey is far from over. Still got a helluva lot more to do. So thanks for looking. Til next time. |
02-08-2018, 07:24 PM | #154 | |
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS Quote:
02-08-2018, 08:10 PM | #155 |
02-09-2018, 02:52 AM | #156 |
Got the electronics of Bruticus finally half way working. (Not too good at wiring but I'll figure it out). But I did get it moving under it in power. Did a little test drive and light pull. I hooked it up to my son's wooden toddler chair. I know that's not much weight but I was only pulling with front wheel drive. The rear drive shaft pin screws kept loosening and the shaft flying off because I haven't put thread locker on them yet because I still have to disassemble. Made a little video of it and the noise you hear at the end is Bruticus having his first wreck. I accidentally drive it straight into a metal box fan I had on the floor. Hopefully this is not a prelude of things to come. Think I'm going to purchase a new transmitter and receiver. The one I have is meant for rc airplanes and helicopters. Can't get it to function right. Only goes in reverse 50% of the time. Goes forward fine cause planes don't have reserve lol. https://youtu.be/CHCR__mgcJM |
02-09-2018, 10:40 AM | #157 |
Lol. Hey atleast its moving now. I crash into stuff all the time, don't feel bad.
02-09-2018, 06:14 PM | #158 |
| Re: Rickleo's Chevy Crew Cab Dually: BRUTICUS Naw I don't feel bad. Thought it was funny actually. The one thing on the floor and I run head on into it. That's what I get for taking a vid in one hand and trying to drive with the other. Broke the tabs I put on front of the body to keep it level til I get th he body mounts made. But they are temporary. So no big deal.
Rickleo's Chevy Crew Cab Dually: BRUTICUS - Similar Threads | ||||
K30 Chevy Crew Cab Dually Wrecker by Trailworx Garage | H2Micr0 | 1.5 Scale Rigs | 24 | 02-19-2017 08:47 PM |
chevy crew cab dually | S10XtremeSR | Micro Scale Rigs | 4 | 03-22-2015 05:18 PM |
Chevy Crew Cab Dually | makaveliks | 1.9 Scale Rigs | 222 | 11-17-2014 08:32 AM |
