05-22-2017, 09:51 PM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| The Scaler from Down Under!
So I'm starting a new 1.5 build and thought I would share the build as I go along. This project will be using a Crocodile Hunter hard body that will be mated to an SCX10 chassis. I've seen a few builds using these body's. Most of them have been tall rigs placing the body well above the chassis. That's always been a look I hate, that body lifted look. I'm thinking to fully pull this off I'm going to need a front motor mount setup and possibly a flat transfercase of some type. Items I currently have: o body set o frame rails o driveline (SCX10 components) o RC4WD wheels and tires The first picture is with the truck complete and the RC4WD wheels next to it. And the last is all the pieces I'm going to use. Sent from my Pixel XL using Tapatalk |
05-23-2017, 02:07 AM | #2 |
Newbie Join Date: May 2017 Location: 3420 E. Georgia Pines Lane, Mead
| Re: The Scaler from Down Under!
Why not "Crocodile Dundee"? Sent from my SM-G930VL using Tapatalk |
05-23-2017, 02:08 AM | #3 |
It's really trick, I dig it. Sent from my SM-G930VL using Tapatalk |
05-26-2017, 04:41 PM | #4 |
Scale goodies have arrived! Also have a set of axles that just came in as well. Hoping to have links built tonight! Then it's on to figuring out body mounting. Sent from my Pixel XL using Tapatalk |
05-27-2017, 11:12 AM | #5 |
Some progress today! o cut small posts off underside of bed o picked out chassis o working on moving the skid plate/transmission forward so I can fit a motor inside the cab Unfortunately for now I won't be able to run the full interior. My goal is to eventually have a Toyzuki V1 motor mount/transfer case. Sent from my Pixel XL using Tapatalk |
05-27-2017, 11:15 AM | #6 |
Unsure if I'm going to drill the front of the hood and go body posts or figure out a velcro setup. Definitely using Velcro for the rear. Sent from my Pixel XL using Tapatalk |
05-27-2017, 12:56 PM | #7 |
Pebble Pounder Join Date: Jan 2016 Location: Port Huron
I like to cut the top of the body post flat. Drill holes at the end and run and aluminum plate between them. Stick some Velcro on the plate. It allows you to still adjust with the post but no holes. Sent from my iPhone using Tapatalk |
05-27-2017, 08:53 PM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: Kaufman
Go to ebay they have magnetic posts for like 8.00 I have never seen one of these done and would hate to see the body drilled. Cant wait to see where this goes though. Also if you check out my chevy build I did front motor set up sing scx10 chassis and skid. |
05-28-2017, 07:03 PM | #9 | ||
| Re: The Scaler from Down Under! Quote:
Sent from my Pixel XL using Tapatalk | ||
05-28-2017, 07:23 PM | #10 |
Newbie Join Date: Oct 2008 Location: Wausau,wi
Nice!
05-28-2017, 07:38 PM | #11 | |
Sent from my SM-N910V using Tapatalk | |
06-10-2017, 07:48 AM | #12 |
Assembled the SCX axles, put my lil 1.5s on and their to wide. Instead of messing with narrowing the SCX axles I'm gonna go with MRC axles. I've seen about two builds with these bodies and both had 1.9s stick way out and looked like monster trucks. I want this to look almost stock. Also picked up a Dinky RC cantilever kit for the rear. I don't have it in my heart to chop up the bed for an ugly shock tower. Sent from my Pixel XL using Tapatalk |
06-26-2017, 12:56 PM | #13 |
Small update. Have my Dinky RC cantilever mounted up. Now contemplating whether I should spend $90 for narrow SCX10 axle housings or attempt to narrow a set myself. The stock SCX10 axles are about 1/4" to wide on each side.
07-20-2017, 04:49 PM | #14 |
| Re: The Scaler from Down Under! Narrowed Ascender axles would fit nicely, great build start! |
