08-15-2017, 02:28 PM | #1 |
RCC Addict Join Date: Jan 2011 Location: Wheat Ridge
| Crawl Space TJ aka Twerp Jerp
Starting my attempt at a short wheel base rig ready for competition. Most of this build started with leftover parts so it will be cobble together, like most of my personal trucks Had a leftover boom racing short wheelbase chassis rails that i chopped about an inch or so out of the middle. Welded and mounted to a Vader flat skid. Then I started work on the front shock hoops and mounting plates for the transmission, yes they look like shit, I was having issues with my the gauges for the argon tank and finally figured it out after getting everything tacked together. The plan was to keep the drive train as simple as possible and try a few ideas I've had rumbling around my head recently. I cut the top portion off a AX10 trans mission and used it as a carrier for the spur gear shaft and have some thing to also bolt the motor plate to. I turned down and tapped a piece of aluminum tube to mount the drive shaft yoke to directly off the spur gear shaft to go to the Hammer T-case. I plan to run an over drive from the t-case to the front axle to get a little better ascent power and turning radius. Had to tweak out the trans mounting plates for a better drive line angle, now that I have my welder dialed in with the gas I'll re-tack the motor plate brackets. Working on getting some AR44 axles together and try a 45-55t motor to get the low creep out of this simple start of a drive train. |
08-15-2017, 03:12 PM | #2 |
| Re: Crawl Space TJ aka Twerp Jerp
People still build crawlers these days?! Nice work! |
08-15-2017, 03:29 PM | #3 |
| Re: Crawl Space TJ aka Twerp Jerp |
08-15-2017, 03:32 PM | #4 |
08-16-2017, 10:07 AM | #5 |
Welp, the simple trans mod worked well for low end creep but no guts for crawling up and over obstacles over center tire height. I'm going to cop out and go with a standard AX trans mounted to a cross plated welded to the chassis. Added a simple styrene tray to mount running gear and keep everything low. Chopped the output on the front facing side the get the trans as far forward as possible. Dealing with more gauge issues for some reason but got through tacking up a quick roll cage. The B pillar came later, it was a long night. Fortunately I have enough of this cheap spray on bedliner to cover up the crap welds. A tig machine is in my near future. Quick mock up of the body so far. Last edited by The Crawl Space; 08-16-2017 at 10:10 AM. |
08-16-2017, 10:10 AM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Looking good! I really like those bodies, I'm excited to see where you go with this!
08-17-2017, 09:30 PM | #7 |
Newbie Join Date: Aug 2017 Location: Boulder
Lookin good.
08-18-2017, 06:20 AM | #8 |
I look forward to stealing some ideas from this build since I'm currently helping my cousin build nearly the same truck. |
08-18-2017, 12:27 PM | #9 |
Quick tack on the rear shock mounts, more like shock nubs and ran the short ECX shocks someone recommended for drop bed builds. I used some RCBros comp springs cut to size and refilled the shocks with some 45wt oil to slow everything down in the rear. Tossed up between the new Pitbull Rock Beast XS or RC4WD 1.7 MT/R tires Pushing forward slightly since I'm terrible at taking pics while I'm building this truck on top of customer trucks. Holmes Hobbies servo installed, and running gear laid out low to clear the body and interior. Little 3s lipo needs to stand up to clear the interior firewall but shouldn't effect weight distribution too much. |
08-18-2017, 12:32 PM | #10 |
Pebble Pounder Join Date: Sep 2014 Location: Hamilton Montana
Make sure you get Rubicon Stickers for the Hood. Not cool unless it has Rubicon stickers. Then you can crawl any speed bump at your local mall like a boss. Otherwise excellent work and carry on. |
08-29-2017, 12:06 PM | #11 |
Quarry Creeper Join Date: Jan 2005 Location: Seymour, Tn
Seen this rig at his store/shop. First rate throughout. Pics do not do it justice.
08-31-2017, 08:50 AM | #12 |
12-18-2017, 06:57 AM | #13 |
Rock Crawler Join Date: Feb 2013 Location: Casper
Any up dates?
12-23-2017, 12:20 PM | #14 |
Alrighty, so my old desktop dumped and I lost a bunch of build pics. I did snap some finished pics. Did some quick fender wells with craft foam , scored a sweet river and weathered the whole truck to go with the driver vibe. |
12-23-2017, 12:21 PM | #15 |
Quick video before Logan took the wheel and upgraded to some 1.55 SSD beadlocks |
12-23-2017, 06:31 PM | #16 |
The Jerp is only getting better. Wayne |
12-30-2017, 10:19 AM | #17 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Nice!!! Whats the wheelbase? My son wants a tj for his barrage and this looks awesome. Great job in the figure! Im a huge marvel legends collector and it never occurred to me that old man logan is a PERFECT driver figure! Although he is actually 1:12 scale but that jerp blurrs between 1:10 and 1:12 anyway. Great work! And your worst welds are better than my best any day haha |
12-30-2017, 04:21 PM | #18 |
Quarry Creeper Join Date: Dec 2016 Location: Womelsdorf
Looks like it works really well. Balanced.
12-30-2017, 06:11 PM | #19 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Nicely build |
12-31-2017, 07:46 AM | #20 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Nice build Ikaika |
Crawl Space TJ aka Twerp Jerp - Similar Threads | ||||
crawl space | metalking | Pennsylvania | 5 | 03-29-2014 12:36 PM |
The Crawl Space? | DSchulten88 | Colorado | 10 | 05-08-2013 02:01 PM |
