Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: King Kong RC ca10
Old 02-09-2018, 09:59 AM   #21
Default Re: King Kong RC ca10
Did a little running now I got to try to find a scale engine for it
Sent from my SM-S903VL using Tapatalk
neon9 is offline   Reply With Quote
Old 02-09-2018, 10:51 AM   #22
I'm still blown away by the scale details of this kit. Did this brand just come out of nowhere or do they also make other vehicles?
TooOldForThis is offline   Reply With Quote
Old 02-09-2018, 10:56 AM   #23
Where'd you end up putting your battery, Rx, and ESC?
JennyC6 is offline   Reply With Quote
Old 03-12-2018, 12:29 PM   #24
Change the truck up a bit I saw a Old Gulf gas station truck that look like this now I just have to do a little bit of weathering
Old 03-13-2018, 11:55 AM   #25
The weathering is done
Old 03-13-2018, 12:11 PM   #26
Lookin' pretty sweet!
Old 03-14-2018, 05:54 AM   #27
Lookin' good! What do you use to make rust?
Old 03-15-2018, 01:18 PM   #28
This is what I use to make the rust it's actually real rust
Old 03-16-2018, 08:19 AM   #29
This is awesome! I'm using the same paint for the rust on my CA10. ket up the good work.
Sdhamm02 is offline   Reply With Quote
Old 04-19-2018, 07:00 PM   #30
Went trailing with mine and it did well
Had to make a battery box in the bed
Sent from my SAMSUNG-SM-G891A using Tapatalk
stevetate12 is offline   Reply With Quote
Old 04-19-2018, 07:01 PM   #31
Some more trail pics ..
Old 06-18-2018, 07:03 AM   #32
Hi guys,
Nice builds
Here are some pics of mine:
Replaced the cargo bed by oak strips since I did not like the plastic bed and added some detail by printing this kit:
https://pinshape.com/items/45797-3d-...-10-detail-kit
Cheers
OldTree
OldTree is offline   Reply With Quote
Old 07-19-2018, 01:29 AM   #33
Bernhard is offline   Reply With Quote
Old 07-25-2018, 05:57 PM   #34
Natedog's Avatar
Love these old round fendered trucks, the blue with black fenders was very nice, Gulf colors are good too. Would be nice to see an option 4x4 front axle to fit too.
Old 07-26-2018, 10:33 AM   #35
i agree... maybe cross rc front axles would fit? seeing as they are both 1:12...
these are crazy detailed! tons of 1:12 accessories available too. ahhh another thing on my "someday" build list.
Shinchu is offline   Reply With Quote
Old 07-28-2018, 09:14 AM   #36
Mine's coming along nicely too! Lovin' all these CA-10s, everyone's ends up a different sort of beaten and battered. Hehe.
Nah. You want 1/14 semi truck axles. These are actually closer to 1/14 scale(I found this out the hard way when I bought 6" scale Duke Nukem and Gordon Freeman figures to drive mine only for neither of them to be even close to fitting, which they would have slid right in if the truck was truly 1/12) and the rear axle, wheel, tire dimensions are all pretty much directly ripped from a Tamiya semi. In fact that's where you look for tires and wheels on these.
I put a LESU drive axle in mine(Mostly 'cause I stripped two ring gears doing donuts with Castle brushless power in the front ), but if you were looking for an AWD conversion, you'd go with LESU axles front and rear(Ring/pinion ratios are slightly different stock and LESU). Can also get cable lockers this way.
Old 07-29-2018, 03:37 AM   #37
Looks to be the perfect platform to use if I want to do a scale-ish build with my Tonka Winnebago.
alexleblanc is offline   Reply With Quote
Old 08-17-2018, 02:14 AM   #38
Wisit this side to how close the rc truck is to the real one,,
Red Iron Models - scale models of the Soviet construction and road machinery
here is a visit in a mini town,,
there is allso a facebook side for this rc truck
https://www.facebook.com/groups/2560...?ref=bookmarks
Old 09-20-2018, 04:11 PM   #39
I bought one, and I am not happy with it, the screw holes for the rims were not taped deep enough, so I had to go buy shorter bolts, and the rims are not the other holes not taped thru either, so I stopped building it,
oldman is offline   Reply With Quote
Old 09-26-2018, 07:12 AM   #40
King Kong RC ca10 - Similar Threads
King Kong D-links UTflyfisher Axial Wraith 1 11-20-2013 09:32 AM
king kong numbnutz Losi Micro-Rock Crawler 6 02-06-2013 08:53 PM
