Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: Toy zuki 4Runner build.
Old 01-27-2019, 01:28 PM   #1
Default Toy zuki 4Runner build.
Iím so lost as to where to put this but Iím pretty sure this will be on 1.5ís so I figure hereís not a bad place to set it. I wanted to build another small tire rig and well I figured the toy zuki chassis would be a good starting point. I also knew I wanted the tires to tuck in as far as possible with any body I was going to use so I strapped a pair of mst axles under it. Then rc4wd made an announcement of the 4Runner body so here we are. A toy zuki mst 4Runner. Far from finished but decided I should at least get a post going about it.
Had some links laying around so it got mocked up to about 12.5 wheelbase.
Then the 4Runner arrived. I am going to have to shorten the links a bit to fit the body since the 4Runner shell is tf2 wheel base. But hereís some pictures during my body build process.
Thatís where Iím at currently. Working on mounts for the chassis currently. Once I get it mounted where I feel itís good I can work on making links to get the axles in the right spot. Rc4wd did a great job on this as far as I can tell. The interior is amazing. Will definitely try and post up pictures as I get farther along.
lilws6 is offline   Reply With Quote
Old 01-27-2019, 02:31 PM   #2
Default Re: Toy zuki 4Runner build.
Man, I have Got to get one of these bodies. Lookin' killer. The zuk setup looks right at home already.
quinn_thercdude is offline   Reply With Quote
Old 01-27-2019, 05:23 PM   #3
Thanks dude!
Old 01-27-2019, 06:21 PM   #4
First attempted body mount/slider. Modified a version I found on thingiverse for the hilux. Unfortunately I didnít take into account the rake of the chassis so Iím reprinting another with a tweak should fit up better. Then I can do the other side.
Old 01-27-2019, 09:13 PM   #5
Got the correct angle on the slider/mount. Now to print solid versions so I can mount it
Old 01-30-2019, 07:58 AM   #6
Got one mount done last night. Warped a little on the printer so Iíll have to see if it fits after work tonight before doing the other side.
Old 02-01-2019, 09:20 PM   #7
Decent update. Got both body mount/sliders on the chassis. Fitted the body where Iíd like and got links mocked up. Had to move the pan hard bar on the front of the axle mount to help line it up a little better. Itís not perfect but with the wheelbase and position itíll have to do for now. On to the pictures.
Old 02-08-2019, 01:54 PM   #8
Got my Holmes motor today and installed my hobby wing 1080. Need a drop down servo horn and I can install the servo and make a steering link.
Old 02-10-2019, 10:05 AM   #9
With the shorter wheelbase came alignment issues. I had to move the pan hard mount back on the frame rail a little bit. So it hurt just a little to drill into this frame but everything lines up nicely now.
Old 02-10-2019, 11:41 AM   #10
Still pondering not thinking I can get any type of engine in here that would look scale with the servo in the way but I think Iíll at least have to make up some inner fenders. Still might see what I can do with a engine might just cut it around the servo weíll see
Old 02-10-2019, 07:15 PM   #11
Great looking build, hows the turning radius with those axles ?
17dean is offline   Reply With Quote
Old 02-10-2019, 09:26 PM   #12
Not actually sure Iíve never used these axles before but they seem to turn a decent amount.
Old 02-12-2019, 11:01 AM   #13
Looking good, can't wait to see the end result.
joeyf is offline   Reply With Quote
Old 02-13-2019, 12:32 PM   #14
Got some used rc4wd shocks from a tf2 90mm rear 100mm fronts. Seems to sit alright. Itíll probably drop a little bit as well when I get some weight on it as well.
Old 02-14-2019, 06:29 AM   #15
Made my new pan hard bar yesterday Iíd say it fits pretty well
Old 02-20-2019, 09:31 AM   #16
Very cool build..... Anything to report?
Bananaclip is offline   Reply With Quote
Old 02-20-2019, 12:18 PM   #17
Still waiting on building materials to finish the links. Then I can hopefully get my battery mount finished and maybe get a small indoor test drive out of it.
Old 02-20-2019, 06:04 PM   #18
Steering link materials came in today so I made those up quick.
Also noticed my pinion angles are off as well now that everything is bolted up. Will have to shorten the upper links a little.
Old 02-24-2019, 05:58 PM   #19
I guess I can call the chassis completed. Finished all the links today all the electronics wired up and work well. Battery tray is mounted. Think I need to go one step shorter on the shocks. Just driving in my basement all that weight of the body just flops around a bunch. Might have to scrap the rc4wd shock idea all together to have it perform like I want weíll see after I can actually get it out for a drive. Next is to disassemble the body and paint. That might be a while yet as Iím still trying to find the right color to paint it and I want this one to be painted right. So I asked my body shop painter if he would paint it when he has time.
Old 03-09-2019, 12:59 PM   #20
Not much progression finally got around to 3D printing some engine stuff. Started cutting to make it fit. So far so good also got a co pilot made as well.
Toy zuki 4Runner build. - Similar Threads
4Runner Build 4X4 Freak Axial SCX10 II 6 08-20-2018 04:34 PM
4Runner build pardonmyn00b Axial SCX-10 125 07-12-2017 09:34 AM
Little Stub - SCX zuki build schiesz 1.9 Scale Rigs 7 03-07-2012 01:06 PM
Owen RaCing's SCX10 Zuki Build Owen RaCing Axial SCX-10 8 03-04-2009 05:20 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
