Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Tamiya Light Armored Vehicle
Old 05-29-2005, 09:37 PM   #1
2006 2.2 National Champ
BENDER's Avatar
Default Tamiya Light Armored Vehicle
Finally got the trials rig up and running. So far I've only installed a 55t lathe motor. Upcoming mods will be Hitec 645mg turned into winch and full ball bearings. I dug these old Pro-line Dirt Hawg tires, for 1/10 scale buggies, out of the R/C pile and modified the rims to work on these outer axles. These tires work great, but aren't legal for comps.
BENDER is offline   Reply With Quote
Old 05-29-2005, 09:58 PM   #2
BENDER's Avatar
Here it is in comp form.
More pics here.
Old 05-29-2005, 10:05 PM   #3
cool but whats with the shoe lace?
Trike Kid is offline   Reply With Quote
Old 05-29-2005, 10:05 PM   #4
BENDER's Avatar
Tow strap.
Old 05-29-2005, 11:11 PM   #5
Ive got one too!!! I just havent posted any pics of it. I want to ocmplete it first.
Very sweet rig, I cant wait to see the winch.
sean_lv_crawler is offline   Reply With Quote
Old 05-30-2005, 12:26 AM   #6
Originally Posted by BENDER
Tow strap.
Ok, I'd get some flat laces for realism though.
Old 05-30-2005, 12:33 AM   #7
BENDER's Avatar
The military does use tow ropes.
Old 05-30-2005, 12:44 AM   #8
if you're set on the round material I'd use some light cable like bicycle brake cable.
Old 05-30-2005, 12:49 AM   #9
BENDER's Avatar
Have you ever seen the oversized tow ropes? They look exactly like the one I'm using.
Old 06-02-2005, 03:03 AM   #10
BENDER's Avatar
Took the LAV for a swim the other day and she didn't like it very much.
I figured I needed to make it a little more water/mud resistent. So, I modded one of the plastic cases that the digital Hitec servos come in. Everything tucks in nicely, I just need to seal it up a little better.
Old 06-02-2005, 01:39 PM   #11
so its basically the same thig as a hummer, but with a different body.
mike is offline   Reply With Quote
Old 06-02-2005, 02:44 PM   #12
i sooooooo wanna get a cc truck
crunk crawlin is offline   Reply With Quote
Old 06-02-2005, 03:26 PM   #13
BENDER's Avatar
It is the same chassis as the Hummer without the heavy plastic body. This body is lexan and arrives painted, just apply decals and go.
Old 06-02-2005, 03:36 PM   #14
Cool
cool but whats with the STUPID QUESTIONS? LOL J/P
LOOKs Good! Did you Lock the Diffs? Can we get a Closeup of the Front Bumper? Got any Plans for the Stock tires?
JakeTheAlligatorMan is offline   Reply With Quote
Old 06-02-2005, 03:46 PM   #15
BENDER's Avatar
The front diff is locked, the rear is still open. The tires will remain unmodified per the trials rules. I also have a set of the BFG's on HPI touring car rims to bash with. I'm going to narrow a different set of TC rims down to roughly a 1/2" maybe less, just to see if it helps.
The front bumper is just a 1/2" X 1" .062 thick strip of alum. I just drilled a hole to tie it to chassis and bent it up to hold the front lower A-arm "wire" in place.
Old 06-02-2005, 05:16 PM   #16
doesnt one of them companys make a hummer like the car you have above would that be a good truck to make a crawler out of ? how many motors do you guys have in these min crawlers 2 like the monsters or just one
dotson is offline   Reply With Quote
Old 06-02-2005, 06:44 PM   #17
what is it with you XC guys and water? Seems like every XC vid I see they are submerged at least once.
Old 06-02-2005, 08:55 PM   #18
i am getting this one like urs but the hummer how did you lock the diffs. if i wanted to lift it a lil bit and get some more articulation out of it what should i do
oh and i want to put 2 motors in it on on the front axle and on the rear like the monsters but keep it realistic like a heavilly modified trail truck ? im a newbie and need help
Old 06-02-2005, 09:10 PM   #19
BENDER's Avatar
I locked the front diff with JB Weld. When you assemble the diff(s) just fill them with JB Weld instead of grease.
As far as lifting it goes, you're limited by the stock dogbones. If you try to lift the vehicle it puts the dogbones at a bad angle in the drive cups, therefore it'll bind under acceleration.
I'm sure the 2 motor thing COULD work, there would be alot of fab work involved though. If you want 2 motors the Tamiya Wild Dagger is set-up like that.
Old 06-03-2005, 02:45 PM   #20
what are dogbones ? if i use axles off that dagger could i do it if even though i dont know what they ae if i mounted the motors on the axle would it make the dogbone prob go away ?
