03-18-2008, 10:17 PM | #61 |
Newbie Join Date: Jan 2008 Location: Portland
| Steering Box
That's an interesting steering box setup. Frame is sweet too.
03-19-2008, 12:26 AM | #62 | |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Thanks for the compliments guys. Quote:
are two 5x11 bearings and a spacer. The shaft is a 5mm hardened socket head cap screw that's been cut flat on two sides to fit inside the Axial spur hub. I was going to use another Axial tranny shaft but figured I'd try this. If it spins true enough I'll stick with it. I considered using this RC4WD compact reduction I have but it is only 4:1, so not low enough. Their new Fracture-designed planetary reduction looks like a very cool possibility. Jay | |
03-19-2008, 12:28 AM | #63 |
Shot of the steering setup. This should be close to ride height. Jay |
03-19-2008, 12:48 AM | #64 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
So what is keeping you from bump steer over a "normal" setup? I've got a setup like most and I get a bit of bump steer. I have a spacer between draglink and the tierod. And the draglink is bent...
03-19-2008, 01:21 AM | #65 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
i'm assuming he's going to run a panhard... definitely looking forward to more progress on this. love the attention to detail and the scale mechanical touches (suspension, steering, etc.). |
03-19-2008, 01:22 AM | #66 | |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
He will still have some but his drag link is closer to parallel at ride height than most I've seen. It's impossible to eliminate bump steer completely unless your servo is on the axle or your front suspension is nonexistent. Great work on everything Jay! Edit: Track bar will help but the axle will need to be able to move off center as the suspension cycles. It will cause bind if a traditional 4 or 3 link is used. Last edited by chino63; 03-19-2008 at 01:26 AM. | |
03-19-2008, 08:49 AM | #67 | ||
A bent draglink does not affect geometry....only the angle where the rod end sits. Jay | ||
03-19-2008, 12:12 PM | #68 |
| S O A B..... And here I thought I was getting somewhere.. Atleast it's smooth when it steers.. |
03-22-2008, 12:31 AM | #69 |
Got the rear tow point on and started work on the front bumper. Jay |
03-22-2008, 12:58 AM | #70 |
RCC Addict Join Date: Mar 2005 Location: MESA, AZ.
This is looking real Nice Jay! Rick- |
03-22-2008, 11:15 AM | #71 |
SICK! I can't wait to see how this turns out |
03-22-2008, 11:54 AM | #72 |
Built, not bought Join Date: Oct 2004 Location: Gresham
Looking better all the time.I can't wait to see more. Pat |
03-24-2008, 11:11 PM | #73 |
Uh oh.....
03-24-2008, 11:14 PM | #74 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Oh no! Those dang things are falling off all the time! I hope to have that problem in the near future. Keep up the killer work! |
03-25-2008, 11:09 AM | #75 |
Now you've done it... |
03-25-2008, 02:22 PM | #76 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
03-25-2008, 02:49 PM | #77 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
03-25-2008, 11:50 PM | #78 | |
Hadn't seen the JP ones before.......those are quite nice and I like the bolt head. Jay | |
03-27-2008, 10:46 PM | #79 |
Couple more T-Rex pics..... Jay |
03-28-2008, 03:57 PM | #80 |
RCC Addict Join Date: May 2006 Location: Roseville
Well, don't those look pretty. Any issues with them going together like their Bruiser reproductions?
