Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: 1.9 LR3 build
Old 06-03-2008, 01:44 PM   #1
Default 1.9 LR3 build
Hey all this is my first build up. It has all the basics. Anyways here are the specs.
ebay LR3 hardbody
Custom built frame out of 1/2" square tube
locked pede tranny
locked tlt axles
rc4wd straight axle adapters
tamiya hummer wheels
rc4wd rock crushers
645mg servo
XRS esc
cheapo reciever
custom sliders and bumpers made out of solid rod
Future plans
flat belly skid
scale items
led lights
here are some pics
Custom Built stuff
Obligatory Flex shot
ZJman is offline   Reply With Quote
Old 06-04-2008, 12:58 AM   #2
a little update if anyone cares:-(
got my plate from the dmv
Old 06-04-2008, 01:05 AM   #3
Axial Team Driver
Brandon's Avatar
Looks good. I would lower the back a little though
Brandon is offline   Reply With Quote
Old 06-04-2008, 01:08 AM   #4
I am a Liar!
pantablo's Avatar
wb looks a little off at the front but looks really good. this is th eLR3 body that is stock looking when you buy it, isnt it? Has opening doors, hood and rear hatch...which looks great missing!
pantablo is offline   Reply With Quote
Old 06-04-2008, 01:17 AM   #5
It was lower before I put a thicker weight shock oil in the back shocks. I will probably just change the mount.
ya I know thats what im fixing next. It is the body that has the opening doors and all that. As for the back hatch Im going to build some sort of pre-runner type cage for the back thats why the back hatch isnt there.
Old 06-04-2008, 01:49 AM   #6
where the hell do you people get those land rover bodies all we got here in hawaii is high lift bodies and the other hpi and axial stuff that body is pretty dope
eh bumbai is offline   Reply With Quote
Old 06-04-2008, 01:55 AM   #7
I am a Liar!
pantablo's Avatar
ebay. $30-$40
http://toys.search.ebay.com/LR3_Radi...Z1QQsofocusZbs
amazon.
http://www.amazon.com/Radio-Remote-C...2562535&sr=1-2
http://www.amazon.com/Remote-Control...2562535&sr=1-3
Old 06-04-2008, 10:22 PM   #8
nice build..
jaymillz517 is offline   Reply With Quote
Old 06-04-2008, 11:25 PM   #9
A little update....shortened the wheelbase.
Lowered the rear
Moved the servo to the frame
Old 06-04-2008, 11:38 PM   #10
I am a Liar!
pantablo's Avatar
looks a ton better. now that you've moved the servo to the chassis won't you need a panhard bar to keep the axle from pushing to the side?
Old 06-04-2008, 11:54 PM   #11
you will still need a panhard pablo...........
luis is offline   Reply With Quote
Old 06-05-2008, 12:03 AM   #12
31st place in 2006 Nats!!
toyofast's Avatar
What? If he has a good 4-link or even a 3-link setup he doesn't.
toyofast is offline   Reply With Quote
Old 06-05-2008, 12:18 AM   #13
nice dude but damn you i thought i was going to be one of a kind.
oh well, at least Ill be one of a kind in my area.
i bought one of these hard body trucks too same as yours but mine is silver, just got it today and got the chassis apart and stuff..
still need a loooottttt of work to build my truck though
naossoan is offline   Reply With Quote
Old 06-05-2008, 12:47 AM   #14
well with the short time i got to run it, there was no pushing side to side. I will know more tomorrow when i take it for longer. Thanks for the compliments.
naossoan this body still is somewhat uncommon, i love it. good luck on your build.
Old 06-05-2008, 01:50 PM   #15
ok so I have a problem now my steering is acting wired, it steers all the way over to the left and when i steer right it hardly turns at all. I have tried moving the linkage around but that didnt helped anything. I was thinking of changing my mount but i wanted to see what other people would have to say. any help would be appriciated.
Old 06-05-2008, 02:10 PM   #16
I am a Liar!
pantablo's Avatar
check that the servo is centered and that the steering trim on your radio is centered also.
Old 06-05-2008, 02:13 PM   #17
im loving it
RustyCrawler is offline   Reply With Quote
Old 06-06-2008, 01:48 AM   #18
I'm glad that the inner part of this body, the interior and what-not is pretty soft, pliable plastic. I've been cutting it to bits! I just grab my heat gun - heat up the area and my exacto cuts through it like butter! woohoo!!
I might actually be able to fit all my electronics under here somehow!!! lGonna be tight though.
Old 06-06-2008, 09:47 AM   #19
Hey zjman, that truck looks alot like mine with the exeption of mine being a 2.2 scaler check it out!
edward87 is offline   Reply With Quote
Old 06-06-2008, 10:38 AM   #20
Looks good, Great wheel and tire combo btw
JBHardwear is offline   Reply With Quote
