12-09-2008, 12:24 PM | #81 |
RCC Addict Join Date: Jun 2008 Location: Monroe, NC
Looks great Pablo. You gonna keep the mini wheels and trail doctors as the final combo? Justin |
12-09-2008, 04:13 PM | #82 |
Pebble Pounder Join Date: Jul 2007 Location: SinCity
wow... wow... wow... speachless!!!
12-09-2008, 04:29 PM | #83 | ||
I wanna be Dave Join Date: Aug 2007 Location: santa monica
I appreciate that always, but especially from you, as I respect your work tremendously. Quote:
[edit, reread what you said. thought you meant the 1.5 with regular TD's on the table. not likely to keep the 1.5 mini cooper wheels and XL's like on the front wheel but I like how big and bulgy the tire looks reduced that much. and those wheels wouldnt be out of place on this either...long term I think I'm just waiting for MSD to produce one of their scale wheels they have in the pipeline. ] thanks! Last edited by pantablo; 12-09-2008 at 05:15 PM. | ||
12-10-2008, 01:07 PM | #84 |
Newbie Join Date: Sep 2008 Location: Andorra
Another pantablo awesome job ! |
12-11-2008, 12:04 AM | #85 |
Thank you. well, I may have to reconsider reduced trail doc XL's on 1.5's... I bought these for myself since I'd been looking for them for ages...mini cooper aftermarket wheels. Stu first used them, that I saw... |
12-11-2008, 04:13 PM | #86 |
RCC Addict Join Date: Oct 2007 Location: Long Island-Land of one batch of rocks in Sag Harbor and at least one fellow crawler
Coming along great! Looks like you found your wheel! Looks like a cool "steelie" Keep it that color or paint it flat black, either way it looks the part I think!
12-12-2008, 02:55 PM | #87 |
thanks. little update. its amazing what one can make with just a dremel. I cut this bracket out of 1"alu angle for the chassis mounted servo. servo isnt final one here, just for mock up. also got motor and gru installed as well as transfer case. all mocked up. I'll take it back apart to set the correct screw type and length as well as paint the alu parts. will make a skid later. Transfer case is mounted to only one side of chassis currently. not sure if thats going to be enough. now I'll take a look at the interior to settle on the t-case and any other clearance issues. |
12-12-2008, 05:09 PM | #88 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
That looks really good man, glad to see the proceeds will be going to a good charity since it effects my family as well considering my mom has diabetes.
12-13-2008, 12:50 AM | #89 |
Thanks. I may be getting a proper transfer case...stay tuned... turns out, the 1/8 scale 4dr JK interior fits with minimal trimming (1/4" each side). its still got some interference with the chassis components so will take a little finessing but should be pretty painless... outdoor shots coming this weekend, lol... |
12-17-2008, 09:37 AM | #90 |
It coming along good Pablo. I vote for the Mini steelies with the XLs. Justin |
12-17-2008, 11:24 AM | #91 |
thanks Justin. I like the 1.5 wheels too but I think I need to keep it as standard as possible. Whoever wins the raffle may or may not be able to reduce tires themselves so I think I should stick to 1.9's to keep it simple for the new owner. On another note, I got a package from rc4wd the other day...mmm.. Mud Thrasher tires. VERY sticky and soft...I likey. they sit nice and scale under the fender flare they'll tuck nicely. after these were taken I adjusted the chassis length (it wasnt letting me get the body positioned properly), modified the interior to allow the body to sit lower on chassis, installed new 80mm dual rate rc4wd shocks and set the final body height. I dont have pictures of that but the rear tire tucks INTO the fender...mmm, I likey that too. |
12-17-2008, 11:29 AM | #92 |
Those tires look great on there. Justin |
12-17-2008, 01:52 PM | #93 |
Quarry Creeper Join Date: Mar 2005 Location: The 2one7
how did you mount the GD Reduction?
12-17-2008, 04:07 PM | #94 |
| at the top of the gd unit there is a cross member holding the front and back together. either side of this on the far plate of the gd are two holes, the left one is slotted and the right one is round with a raised boss. There are two similar holes at the bottom. I drilled through the chassis crossmember and screwed the gd to that. it seems pretty solid. I can try to get a close up from the other ange so you can see it better if you need it. |
12-17-2008, 05:13 PM | #95 |
Those new tires look sweet, just like the BFG's.
12-17-2008, 09:36 PM | #96 |
Rock Crawler Join Date: Jul 2007 Location: los angeles
how about a side picture with those sweet tires and that new stance pablo |
12-17-2008, 09:49 PM | #97 |
Pebble Pounder Join Date: Oct 2006 Location: Maple Valley
Nice work Pablo I cant wait to see it at the MSD nats.Those 3 Racing shocks work great for any build. |
12-17-2008, 11:20 PM | #98 |
man this charity build is getting sweeter as completion gets closer.... could you hookup a above shot of the gear reduction? also good thinking on keeping the wheels and tires standard. :thumbs:
12-18-2008, 12:52 AM | #99 | ||
tuck gd unit | ||
12-18-2008, 06:36 AM | #100 |
WOW, that think looks huge. Unless its the camera angle, would you mind posting up a picture of it next to a 2 liter or ruler? Justin |
