11-16-2008, 04:14 AM | #1 |
Newbie Join Date: Nov 2008 Location: Netherlands
| Hilux Crew cab build
Hello a few pict, of my Hilux crew cab i started to build, some weeks ago. I am from the Netherlands so my English is not the best (sorry for that) staeted whit 2 front body's try toget tem together The chassis is the trailfinder Ooops needs some work on the chasi stretched te chassis wat do i do build it whitout bed top or whit a top on? |
11-16-2008, 04:48 AM | #2 |
Quarry Creeper Join Date: Jan 2005 Location: GUAM
looks good cant believe you cut the chassis. good luck on the build |
11-16-2008, 07:58 AM | #3 |
Rock Crawler Join Date: Oct 2007 Location: Miami
Looks awesome. Great job. |
11-16-2008, 06:00 PM | #4 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
looks great! I love that you also cut the bed short. for a second I thought this was my build thread, lol. I thought about a cab for the bed of mine too but decided against it. I think the dual cab reads better without it. here's mine. |
11-16-2008, 06:03 PM | #5 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
no top, otherwise its looking excellent. good work on the cabs, you cant even tell its in two pieces.
11-16-2008, 07:13 PM | #6 |
Rock Crawler Join Date: Nov 2007 Location: San Bernardino
looks great! NO TOP! |
11-22-2008, 08:11 AM | #7 |
Rock Stacker Join Date: Mar 2008 Location: socal rock garden
looking great NO TOP also...
11-23-2008, 03:12 PM | #8 |
Thanks for the reply good idea to do it whitout the top some more steps I made a new speaker box under the rear bed. a box for the MFC-02 unitto take away from the most dirt and reversed the transmission unit to give it space try of the cab would fit,whit evrything under it did today the first test run(only front driven becouse i need a longer rear shaft. i use a stock silver can from tamiya, and it is a bit to fast for my idea. the 2 speed came whit a 10 tooth motor pinion. is this the standard one ? i ordered a 8 one for trying to gear it down. i dont know if the mfc-02 unit will accept other than 27 turn,motors if the 8 motor pinion not works i can try a gear reduction unit mabey |
11-23-2008, 03:13 PM | #9 |
| found your's wow this is a greate build you did rims also are verry good
11-23-2008, 08:09 PM | #10 |
thanks. yours is looking very good too. ideas on color? also if you're interested in the stripes PM ElChupoCabra on here as he did the paint masks cut out of vinyl, so he could cut you some too for cheap. try a 55t with the 2-speed and 10t pinion. should be fine. |
12-06-2008, 06:07 PM | #11 |
I used a RLP Truck puller(dont know the turns off that motor? ) but after some longer testing i think it is way to slow now is use the stock 540 motor and the 7 toth pinion thad i ordered. did some modd's on the 2 speed tranny for that also got my rear shaft today, so dit the first outdoor test whit the chassie. its verry nice to drive, but i think i need te hilift springs in the shocks te spring that are in now are verry hard. also made a reiciever plate and cover it whit a balloon i think i need a black one. and also got my kamtec window glasses now wait for the repro interior ,so i can start whit the insite of the truck. I think it will be yellow, Last edited by MR-Design; 12-06-2008 at 06:10 PM. |
12-07-2008, 03:56 AM | #12 |
Quarry Creeper Join Date: Nov 2008 Location: 540 Mabuchi Motorola?
great build! looking good, keep the stock motor! they run forever! it takes awhile for them to start smoking, then catch firelol nice rims toooo. |
12-07-2008, 05:13 PM | #13 |
Rock Stacker Join Date: Nov 2008 Location: galena
lookin good!! what color are you thinking of painting this ???
12-07-2008, 10:52 PM | #14 |
nice work. good choice of tire. |
12-13-2008, 04:39 PM | #15 |
Thanks for the coments Yea those tires i love them. and the stock motor is running verry wel in there Today i did the first steps for the interior, it wil fit very wel whit the chassie i think i wil put 2 or 3 workers in the cab also ordered some paint ,and i will be yellow as i have a orange one and a red one it will have a flat clear coat Last edited by MR-Design; 12-13-2008 at 04:41 PM. |
12-13-2008, 04:55 PM | #16 |
Rock Stacker Join Date: Oct 2007 Location: Vancouver, BC
Looking very good. what about wheel color?
12-13-2008, 05:01 PM | #17 |
Pebble Pounder Join Date: Aug 2008 Location: socal
that is very cool looks like a factory job |
12-14-2008, 12:08 AM | #18 |
12-14-2008, 08:12 AM | #19 |
12-14-2008, 08:16 AM | #20 | |
vinding some 1/10 figures is not easy | |
