01-23-2010, 09:29 PM | #201 |
Newbie Join Date: Nov 2009 Location: Houma, La
You're going to need to exo cage this thing to protest that piece of art.
01-23-2010, 09:51 PM | #202 |
Rock Stacker Join Date: Oct 2009 Location: Huntsville
that thing is awesome!!! |
01-24-2010, 09:13 AM | #203 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
Can you give me the info about where you sold your soul to the devil? That would be great, thanks.
01-24-2010, 09:51 AM | #204 | |
Quarry Creeper Join Date: Jun 2009 Location: The Netherlands
Great stuff masher! This thing is going to be awesome. It looks like the damage really will be compareable to the real thing. But then you would have to keep the weight of the rest to scale too. Like 2 kg for the whole thing. Maybe an exocage would be cool to keep it driveable longer. | |
01-24-2010, 09:54 AM | #205 |
Rock Crawler Join Date: Jul 2009 Location: boise
how much would you sell one of these bodys for i NEED one bad!!
01-24-2010, 12:42 PM | #206 |
Quarry Creeper Join Date: Aug 2006 Location: farmington
incredible aoto-artistry you can be officialy bumped to the level of the other masters on this site you have a knack for metal like microgoat has for styrene and other builder w/their media awesome work subscribed |
01-24-2010, 05:35 PM | #207 |
Newbie Join Date: Nov 2009 Location: Maura, Norway
real nice work, the job must have taken many hours both on modelling and shaping of different parts, i bow in the dust for this one..
01-24-2010, 05:42 PM | #208 |
Rock Stacker Join Date: Feb 2009 Location: portland
wow nice work r u going to drive it when its done or put it on display |
01-25-2010, 03:22 AM | #209 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
| WOW |
01-25-2010, 03:23 AM | #210 |
| Again: WOW |
01-25-2010, 10:46 PM | #211 | ||||||
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
as for the exo.. see above. Quote:
Well i got the chassis problem sorted out. I figured out the problem was that the hump over the front axle was back to far, so to remedy the issue i started by cutting off the front spring mounts Then welding the chassis to a bar to keep it strait and maintain the overall distance. next i cut out about 1/2" just behind the front cross member then i made a single cut on the flat section in the middle of the chassis then using a strait piece of tubing I tacked the chunk i cut out behind the hump Then i welded it all up including the hole for the shackle Once both sides were welded i cleaned it all up. it isn't perfect but this chassis is only temporary anyways. after it was all cleaned up i welded the front spring mounts back on and re-drilled the holes for the shackles adding boxing plates inside. In order to align the springs to the axle perches properly i bent the shackles to jog the springs over. and finally here is how the cab fits with the modified chassis I'm pretty happy with that. Don't mind that the cab and bed are not aligned, the cab is getting body mounts to level everything up. Now it's onto the cab mounts. | ||||||
01-25-2010, 11:07 PM | #212 |
Rock Crawler Join Date: Jul 2009 Location: Colorado Springs
Awesome
01-26-2010, 04:39 AM | #213 |
Pretty friggin sweet! BTW, a car with exocage can still get bodydamage |
01-26-2010, 04:44 AM | #214 |
Pebble Pounder Join Date: Nov 2009 Location: Kingsport, TN
Wo wa we wa, that is badass!!! Sooo many skilled people here on RCC, i'm impressed. |
01-26-2010, 05:08 AM | #215 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
very ;lookin great as usual always a pleasure to see your work |
01-26-2010, 05:32 AM | #216 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
I am so glad to see you fix that issue the right way!!! Mastery of the art!!
01-26-2010, 10:38 PM | #217 | ||
I got the cab mounted! I used the same technique as the bed mounts by making them out of thin sheet metal but the difference this time is i added tabs to the sides and top to allow me to weld them to the chassis verses brazing, why? because i can fuse the metal with the TIG for a cleaner, factory look... and i suck at brazing! you can see how clean the fusion can be. here is how the chassis sits right now with the mounts done i drilled the holes and affixed the cab The whole thing came out real clean inside for the bolts i decided to try small 2MM stuff. Considering the strength of the material i'm sure the body will fail long before the bolts will. plus the size it right. and here is a shot from the bottom the mounts are actually a bit out of scale but i had to take some creative liberties because of the shackle location. I am going to trim the ends down though, they stick out a bit too far for my taste. I'm more concerned about the body than the chassis right now. once the body is finalized and some testing is done i'm going to concentrate on a more scale accurate chassis, I mean REALLY accurate. | ||
01-28-2010, 07:01 PM | #218 |
Newbie Join Date: Dec 2009 Location: houma
| ugh
This is the shizznitt and it it is kick ass too The only thing missing is the truck nuts |
01-28-2010, 08:22 PM | #219 |
Pebble Pounder Join Date: Mar 2009 Location: St. George
thats freakin crazy awsome! how many hours do you have in to this! how are you goin fit drive lines under the cab?
01-28-2010, 09:00 PM | #220 |
Pebble Pounder Join Date: Oct 2006 Location: Ogden, Utah
WOW! thats some kickass work
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/147988-project-true-scale-aluminum-toyota-body.html | ||||
Кузова,все о них и для них - Страница 5 | This thread | Refback | 10-05-2011 08:25 PM | |
Wow, Amazing Scale RC Toyota - Tacoma World Forums | This thread | Refback | 10-04-2011 06:14 PM |
