02-04-2009, 04:03 AM | #61 |
Quarry Creeper Join Date: Apr 2006 Location: GUAM
| sick...................
this is one sick build!!!!!!!!!! awsome job man |
02-04-2009, 04:21 AM | #62 |
Pebble Pounder Join Date: Jan 2009 Location: South Africa,JHB
| Absolutely awesome. attention to detail is mind boggling. gonna definitely keep an eye on this thread. Pure inspiration material right there |
02-04-2009, 11:28 AM | #63 |
Pebble Pounder Join Date: Oct 2008 Location: KY
wow thats amazing i cant wait to see it finished
02-04-2009, 01:10 PM | #64 |
Pebble Pounder Join Date: Oct 2008 Location: The sticks
simply un-freaking-believable!!!! cant what to see whats to come!
02-04-2009, 04:30 PM | #65 |
Rock Stacker Join Date: Nov 2005 Location: Yay area
can't wait to see it with dents and scratches all over it like your f150 build |
02-04-2009, 05:04 PM | #66 |
Quarry Creeper Join Date: Sep 2005 Location: Minneapolis
I wish I hadn't found this thread until after the truck was finished. Now I'm gonna have to anxiously await every post... UPDATES??? |
02-04-2009, 05:13 PM | #67 |
Rock Crawler Join Date: Feb 2007 Location: Simi Vly
Simply outstanding. Just a week ago in Walmart the wifey comes up to me and tells me " you should make a body out of this for your crawler" and shows me a baking tin. LOL.. I told her she was crazy, NO ONE would be able to do that, ESPECIALLY ME.. lol, Guess I gotta show her this. Simply amazing man, outstanding work. |
02-04-2009, 05:45 PM | #68 |
Pebble Pounder Join Date: Nov 2008 Location: in a cardboard box, maybe a castle
Where do we all sign up for an AWESOME aluminum Toyota body, 'cause that is the most awesome thing since I purchased my Wedico Garden Trucks |
02-09-2009, 03:01 AM | #69 |
Pebble Pounder Join Date: Feb 2007 Location: troutdale
any updates?
02-09-2009, 10:00 AM | #70 |
Quarry Creeper Join Date: Jan 2006 Location: Wales
completley amazing you have outstanding skills and patience |
02-09-2009, 10:35 AM | #71 |
Rock Crawler Join Date: Jun 2008 Location: Naples
Unbelievable! That is truly amazing work. You must have great patience, it is a work of art.
02-09-2009, 01:16 PM | #72 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
porn .
02-14-2009, 09:01 PM | #73 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
Thanks for the compliments! Sorry for being so slow on updates fellas. Ben kind of busy with other builds. Well here is some progress I took a brake from the body and started on the chassis this is only a temporary frame just to get it rolling. I have something up my sleeve for the final frame. I began with the standard split 1/2" bent tubing and added cross supports and spring mounts. The front ones I bend by hand then shaped and drilled them. the rear ones were simply cut from scrap 1/2 square tubing I took some liberties from the 1:1 chassis. this one is narrower in the rear and the taper is in the wrong spot but i'll be using TLT axles so to keep it simple I positioned the springs in the same plane. Next I formed the springs then I slid them in the mounts using some fuel tubing as a bushing. this should provide ample movement with the spring then I made up some shackles and mounted them by drilling a hole for the front spring then welding a piece of tubing to the frame for the rear spring It looked pretty level when done Then I dropped it on the axles for a test fit of course I needed a flex shot Then just for kicks I dropped the bed on to see how it looked It will sit lower when its done plus i'll be running slingers which are a bit taller. Now for something completely different for the drivetrain. My goal with the truck was always to be as scale as possible so for that i needed a way to completely hide the running gear. this meant the smallest motor and gear box I could find without sacrificing to much power. I did some research and figured since I will only be crawling, a 1/18 brushless system would be the way to go. So I shopped around and settled on the most powerful Tekin I could find, the mini rage extreme 8kv now for a tranny I was going to make my own using pinion gears but a good friend gave me a better idea I've seen people use cordless drill gear boxes before but they would have been to big for the motor. the cordless screwdriver is perfect as it used a 380 size motor and has a separate planetary gear assembly I started bu pulling the running gear out Just to show how small the mini rage is, it is almost dwarfed by the 380 motor! to make the brushless work all I needed to do was remove the 380 screw on the brushless with some washers for spacers Then slid on the pinion. it's not exactly the right size for the shaft but still went on without trouble then I removed the screwdriver bit adapter by cutting it then splitting it with a chisel. Here is a shot of the gears from the output shaft. notice they are metal. nice! the next set is plastic but seem very stout Here it is all assembled. the only problem with the planetary drive is that there is no assembly hardwhere. it was held together by the case. I have it taped up for now but i'll show how i handled the problem later And just for comparison, here it is beside a stock motor. I should be able to hide that in a styrene 22r easy Time to hit the sack |
02-14-2009, 09:07 PM | #74 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Awesome update. I tried the fuel tubing idea before and it has not held up. If you bind up the leaf springs enough they will either cut through the tubing or the springs will come off all together. I have found the chino mod to be the best with the tightening of the leaf spring eyelet to limit slop to be a better solution long term. |
02-14-2009, 09:37 PM | #75 |
Rock Stacker Join Date: Nov 2008 Location: galena
that is a neat idea!!! is that gonna have enough tourque??? that does look VERY great!!!
02-14-2009, 10:43 PM | #76 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Totally awesome build!!! Some advise on the brushless. 8000kv will probably shred that planetary? You never know. Fiago makes a planetary just for high power brushless motors. Way to go, using a small brushless. Saves alot of room. |
02-14-2009, 11:04 PM | #77 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
Good looking tranny idea... What axles are you planing on using??
02-15-2009, 01:03 AM | #78 |
Rock Stacker Join Date: Mar 2008 Location: honolulu
das muthaphukn bad ass
02-15-2009, 01:13 AM | #79 |
RCC Addict Join Date: Dec 2007 Location: Calgary
"this is only a temporary frame just to get it rolling. I have something up my sleeve for the final frame." If thats the case let me know when your done with that frame, i'll buy it from you. |
02-15-2009, 03:52 AM | #80 |
RCC Addict Join Date: Feb 2007 Location: sweden
are you for real?? that is just amazing! how can you do such clean work with that thin alu?!
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/1-9-scale-rigs/147988-project-true-scale-aluminum-toyota-body.html | ||||
Кузова,все о них и для них - Страница 5 | This thread | Refback | 10-05-2011 08:25 PM | |
Wow, Amazing Scale RC Toyota - Tacoma World Forums | This thread | Refback | 10-04-2011 06:14 PM |
