| | #1 |
| Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
| i want to start my first scale build and i really like the tundra hilift, but i REALLY dont like the way the stock 3spd tranny hangs so far down below the frame. is there another tranny that is smaller and easier to conceal underneath of the truck. im not really into speed so theres really no use for a 3spd. just want to figure it out before i go ahead and buy the hilift. otherwise i will have to come up with something else to build |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Feb 2008 Location: stockton
| you can mod it and put a axiel tanny in or i just liffted the stock three speed up. i got way more gc |
| | #3 |
| | #4 |
| Rock Crawler Join Date: Jul 2007 Location: los angeles
| some people here use the rc4wd r2 tranny, if i remember right some people said it bolts on to the frame but im not sure. use the search option in this forum to look it up you will find your answer there. |
| | #5 |
| RCC Addict Join Date: Dec 2004 Location: HELL.....
| ya i used an r2 and it damn near bolted right into the frame rails. you just need to make some 1/4" or so spacers for one side |
| | #6 |
| pics? i would like to see how far it hangs down. |
| | #7 |
| Newbie Join Date: May 2007 Location: concord
| i had a stampede tranny in mine. |
| | #8 |
| | #9 |
| Pebble Pounder Join Date: Nov 2008 Location: between a rock and a hard place
| I heard of people using R2 trannys in there setups. Also a member on here mounted there 3spd on its side but he had to make a custom mount on his to do so |
| | #10 |
| Quarry Creeper Join Date: Sep 2008 Location: Detroit
| I am currently building a modified 3 speed for these, I have a hilux HL. I will have 1 inch of tranny hanging below the frame rail which is way less than stock, this is not a sideways mount, butchered tranny, I simply moved some gears around and made a custom rear tranny plate from two stock pieces. Tranny still bolts up the same. Only problem is you have to notch the frame for this mod but it looks and performs like a stock unit, will post some pics when I get it done. I am about 50 percent done now. |
| Thread Tools | |
| Display Modes | |
