01-18-2009, 05:40 PM | #21 |
RCC Addict Join Date: Nov 2006 Location: southaven
looks good man keep it up how do the tires feel? i was tinking about geting a set myself. |
01-18-2009, 05:51 PM | #22 |
Rock Crawler Join Date: Jul 2006 Location: Kelowna BC Canada
01-18-2009, 06:36 PM | #23 |
Rock Crawler Join Date: Nov 2008 Location: Lake Texoma, texas
NICE!!!!!!!!!!! |
01-18-2009, 06:36 PM | #24 |
Rock Stacker Join Date: Aug 2008 Location: Sioux Falls
damn nice start to this yota
01-18-2009, 07:47 PM | #25 |
| Thanks... Thank you... Here are some more pics from todays work, i got one side sort of done... I also did some work to the bottom of the box...:-P I think i will be doing some filling on the wheel wells... |
01-18-2009, 07:56 PM | #26 |
Pebble Pounder Join Date: Nov 2008 Location: Hamburg, MI
awww dont stop keep going
01-18-2009, 08:25 PM | #27 |
01-18-2009, 09:56 PM | #28 |
Ok i got some more done... here are some with the axles under it |
01-18-2009, 11:08 PM | #29 |
Got tires lol im really liking this build good job bro
01-18-2009, 11:44 PM | #30 |
01-19-2009, 01:47 AM | #31 |
Pebble Pounder Join Date: Dec 2008 Location: Cen Cal
But Mike doesn't run a winch. I think your build is sick anyways
01-19-2009, 09:03 AM | #32 |
01-19-2009, 12:45 PM | #33 |
Quarry Creeper Join Date: Nov 2008 Location: N. California
Very cool, I am sure Mike and Marlin will be very honored You definitely picked two of the coolest first gen toyotas to do up in scale versions :P |
01-19-2009, 01:23 PM | #34 |
01-19-2009, 02:29 PM | #35 |
Quarry Creeper Join Date: Mar 2005 Location: The 2one7
What chassis are you planning on using? Homemade or store bought? Also have you planned out how/where the electronics are going to be laid out? That is the big hurdle that i am facing now using the X-Trail. I am not going to have an interior to start, but i am using a 3speed . I also am going 4-link front and rear, with possibility of running a leaf setup in the front down the road. |
01-19-2009, 03:02 PM | #36 | |
1. Welllllll, i will be making a steel frame. 2. The electronics will most likely be under the hood. 3. The battery will probly be a 2s lipo under the box???? 4. I will be doing leaf spring's front and rear. 5. ?????? I haven't decided if i am going to have an interior?????? | |
01-19-2009, 04:39 PM | #37 |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
Both projects are looking good so far. I'm still amazed at all you guys with miultiple projects going on at once. I really like the drop bed, are you planning on using that as the mounting point to the chassis? Oh, yeah. Have you considered CAC soft8s wheels, they look pretty close to the ones on Mikes truck. They are 2.0 but don't look too big. Soft8s on my truck. Last edited by cutlaSS; 01-19-2009 at 04:47 PM. |
01-19-2009, 05:03 PM | #38 |
I thought about them, but they are not in the budget:-( Yes i will be using the drop bead as a mounting point to the frame i will try to male the mounting point as close to the 1:1 as i can... P.S. i was talking to big mike over on marlin crawler.com and was very honored that i was building a replica of his 1:1... |
01-19-2009, 05:21 PM | #39 |
Quarry Creeper Join Date: May 2008 Location: Lafayette, Indiana
How hard was it to make those bead locks?
01-19-2009, 05:29 PM | #40 |
| Not very hard (fake bead locks) just find some round stuff around the house and trace it on to styrene, Then drill some holes, and cut very small round pieces of styrene to use as mini bolts. Then press them into the holes and glue them in styrene solvent. On second thought it wasn't that easy but you will get the hang of it after 3-4 hours of putting the little pieces in..... Oh and your finger tips will hurt for about a day after.... |
