Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: i need help
Old 03-12-2009, 07:01 PM   #1
Default i need help
i have a high lift and i dont have the four channle radio so the trans is in low the tires are not glued but the problem is that the the pignon gear the 23t in the the back of the tranny the bottom gear the e clip keeps comeing off i was wonderin if anybody else is or havein the same promble it slips off the nut on the shaft and then it dont move i know i didnt post in the highlift sticky but i would like to figure this thing out tried of tearing it all apart to have it come back off anything would help thanks
oldschool53 is offline   Reply With Quote
Old 03-13-2009, 12:36 PM   #2
I haven't had any problems with my HL. Maybe your "c" or "e" clip is just weak and needs to be replaced.
FodigoDave is offline   Reply With Quote
