| | #1 |
| Pebble Pounder Join Date: Nov 2007 Location: SoCal
| Ok, this is going to be the start of my first build thread. It will probably be long and drawn out but that's just how I work. I have yet to buy a RTR crawler as my last two trucks have been pieced together from various sources, so I'm not new to building just new to posting so you all can criticize ( I mean comment TLT axles Crushers on Hummers RC4WD R2 trans w/ dig TQ3 radio system custom aluminun frame rails RC4WD 90mm dual spring shocks 4 link front & rear motor 55t lathe rooster crawler body: TBD heres the start: ![]() all of your comments and suggestions are welcome Last edited by greedyg76; 05-25-2010 at 09:57 AM. |
| Sponsored Links | |
| | #2 |
| Well I think I have decided what body to go with. Now I have to finish this thing so I can it entered... http://www.rccrawler.com/forum/showthread.php?t=172975 |
| | #3 |
| OK, I found this Ambush CGR & cage on EvilBay Last edited by greedyg76; 05-26-2010 at 11:23 PM. |
| | #4 |
| I gave it my best shot cutting out my own frame rails, but without access to a band/scroll saw I didn't like how the prototypes turned out. The deadline for Proline's CGR build contest is rapidly approaching so I just broke down and ordered a SCX-10 frame set from TCS. This will probably change my original choice of shocks and trans but I can steal stuff off my other trucks if need be. |
| | #5 |
| While I'm waiting for the SCX chassis to show up, I figured I might as well work on the body. Did a little trimming on the fenders to clear the crushers at full stuff. I used Krylon Camo Ultra Flat OD Green and I really like how it turned out. I haven't decided if I will use the Proline western bumpers or bend up some tube ones. ![]() ![]() ![]() Anyone have an extra rock crusher and hummer wheel ? This thing needs a spare! Last edited by greedyg76; 05-06-2009 at 11:10 PM. |
| | #6 |
| Our Service Rocks! ![]() Join Date: Jan 2009 Location: Ukiah
| | #7 |
| RCC Addict Join Date: Apr 2009 Location: Amherst, OH
| looks good. was that straight up krylon or was it the fusion for plastics? |
| | #8 | |
| | #9 |
| BTY - did you see the top 3 winners of Prolines scale master challenge? http://www.prolineracing.com/t-CGR-Challenge.aspx |
| | #10 |
| anyone still interested in this build? |
| | #11 |
| RCC Addict ![]() Join Date: Jun 2007 Location: smokey point
| do you plan on putting some body lines in with a pen , really makes the door stand out, iv said this a few time in other threads but i love scouts! i had one when i was 16 and it was sick i changed it up to an fj40 tho, id like to build one like my old rig, great work keep us posted |
| | #12 |
| I would like to pen in the body lines, but I dont think my hand is steady enuff to do a good job |
| | #13 |
| | #14 |
| Well I got the SCX frame put together w/o any drama, It looks like it's gonna be a great platform to work from. Using my wheelbase jig, I started to put together some links. Since this truck wont see to much comp style abuse, I'm just using 4-40 all thread sleeved with 3/16 brake line and Traxxas rod ends. I had some tlt shocks that I was just using for mock up and I love the looks of the gold under this body but they don't work worth a damn. If they were smooth operators and kept the oil on the inside, I'd use em but I need to find an alternative. Maybe a shock that is a bit shorter, the ride height is a bit higher that what I was shooting for. I'll post up some pics later tonight. |
| | #15 |
| Rock Crawler ![]() Join Date: Apr 2008 Location: SO CAL
| nice, build, where in so cal are you? |
| | #16 |
| | #17 |
| it looks like the SCX frame sets the upper and lower links very close together in regards to vertical separation at the frame end. It seems that this will cause the axle to have more of an arching path of travel rather than straight up and down. Seeing how suspension travel will be on the shorter end for this "scaler" the effect will probably be un-noticable. As for the vertical sep on the axle end, I'm going for about 50% more than the frame end, which should yeild pretty neutral anti-squat #'s right? I realize there are more variables and I have gone down the "search" route many a times, but I think vertical separation between upper and lower links is key as far as anti-squat. Please enlighten me if I am off base on this. |
| | #18 |
| Well finally got some time to spend on the scout this afternoon. I finished cutting and drilling out the rear upper link mount, got all the links done and sleeved, motor/trans mounted and the drive shafts cut to length and installed. ![]() ![]() ![]() ![]() ![]() I used the metal yokes on the axle ends since they take a little more abuse from rocks. Double trianglulated links ![]() I used Traxxas big bore shocks from a Jato, they seem just about the right length. Here's some mandatory flex shots, I might end up dropping the body one notch down since I have some room at full stuff ![]() ![]() Hopefully tomorrow I'll have time to yank all the electronics out of the JK to donate to the scout and taker out for s shake down run.... Last edited by greedyg76; 11-07-2009 at 10:57 PM. |
| | #19 |
| Pebble Pounder Join Date: Oct 2009 Location: Tulsa
| this is looking awesome, love the color what wheels are those? |
| | #20 |
| Thread Tools | |
| Display Modes | |
