| | #1 |
| Live,Eat,sleep RC ![]() Join Date: Nov 2005 Location: Oregon
| I've been asked numerous times to come up with a scale chassis for the MRC. My first crawler ever was a decked out scaler so I guess its only right I do it again, only with my own twist. Things I want and/or plan to incorporate: Flexible wheelbase from 9" to 12" this is achieved by simply moving the shock tower we provide to mounting locations forward or back to accommodate your needs. Universal Something that both 1.9 and 2.2's can use as a scaler platform. Reason why our chassis will have multiple link mounting locations. Panhard bar capable Ideally I'd really love for our users to incorporate a panhard bar setup. Panhard mount will be provided of course. My prototype (below) has a frame mounted servo in prep for a panhard bar, however I cannot find a suitable plate to mount the shocks, so I'm brainstorming ideas.. Anyways, I'm looking for you, the buyer, and you the hobbyist for suggestions, comments and ideas. I won't produce it if it doesn't appeal and work as it should. So I'm getting closer, still need to do the upper links.. I'm struggling with the front end, I want to run the servo mounted to the chassis but can't figure out the shock situation. Anyone can make a chassis that keeps the servo on the axle. But I've never seen a truck w/ the steering box on the axle. ![]() ![]() Its only right to copy my 1:1 so I'm going with the hilux body |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Nov 2006 Location: Rats nest Grafton ND
| Would love to see someone come out with some leaf spring perchs for the axles and possibly some springs to go with them. |
| | #3 |
| Newbie Join Date: Mar 2009 Location: lamar
| im likeing the looks so far. im also interested in this chassis as well. |
| | #4 |
| Newbie Join Date: Feb 2009 Location: North East Ohio
| I'm definately interested in seeing what develops. I'm building my first scaler to match my 1:1 TJ. I'm using the New Bright body, with a WB just over 9.5" I know the New Bright body is a common one for us TJ and JK builders, so making it compatible for them and marketing the chassis for the Wrangler crowd could bring you success in this project. The 9" to 12" WB should be perfect for the TJ, though I'm not sure the WB of the JK body. TSS has a custom TJ chassis for $100. I'd like to see one for cheaper. |
| | #5 |
| Crawler Addict ![]() Join Date: Jan 2009 Location: Jacksonville Illinois
| I'll be first in line when these become avalilable! I am waiting to start my scaler until I get this chassis. The looks of your posted pics is exactly what I am looking for and I bet these will sell very well for you. Got any extra prototypes with hardware?? Long story short great work keep it up |
| | #6 |
| Rock Stacker Join Date: Oct 2008 Location: HK
| As my idea, i just consider 4 points to a scale MRC: 1> The wheel base can be adjust around (10.5" ~ 12"), 2> The feasibility drive shafts (workable for WB as 10.5"~12"), 3> Retain the shock links, to reduce the cost, 4> Keep the wheel & tire, fully covered by the body shell, to make it in scale. Here is my personal advice. |
| | #7 |
| | #8 |
| Mr. Series Champ!!!! ![]() Join Date: Nov 2007 Location: CEN CAL
| great job on the chassis so far |
| | #9 |
| Rock Stacker Join Date: Mar 2008 Location: Pittsburgh
| I"m in for one if you make them. I have a Rubi body that fits the mrc axles perfectly. |
| | #10 |
| ✘ ɹǝʞɔɐʇs ʞɔoɹ ✘ ![]() Join Date: Jun 2008 Location: Wasilla
| whats the wheelbase on that thing? the shafts do look quite long maybe move the tranny back more center of the axles.. and the open area in the back behind the skid is going to hang up on everything. are you making skids for this thing? if not i think you should shorten the area where the skid mounts. Last edited by akguanja; 04-15-2009 at 12:53 AM. |
| | #11 |
| Quarry Creeper ![]() Join Date: Dec 2005 Location: Mechanicsville, VA
| It doens't look very balanced out IMO. I would move the motor/tranny back towards the center of the chasis. That front DS angle isn't going to be very effective either. I would suggest making framerails that drop down in the center to mount the motor/tranny. The way you have yours puts the COG too high IMO. You can check out my build in sig to see what I did with mine. It's not as pretty as something that's CNC'd (it was all done with cut-off wheel/dremel) but I can tell you that it kicks ass in the functional department. |
| | #12 |
| Rock Crawler Join Date: Sep 2008 Location: PA
| He has some good points. The driveshaft angles look way too steep. Plus, I think the wheelbase looks too long. |
| | #13 |
| Thanks for the words guys.. Here's a few things I'd like to mention. My current wheelbase is that of the Tamiya Hilux body pictured above. So its something that is typical wheelbase of a 1.9 scaler. My last scaler was the MSD scale chassis all decked out, loved the chassis, but I can tell this chassis CG is much lower and that chassis is a proven preformer. As for the skid section, I based the center sections length off of 5 chassis already on the market, mine is the average of these five, both suitable for larger tranmission and that of a smaller one such as the MRC trany. I believe what most of you are seeing is that fact the MRC parts are much smaller then usual which is making items appear much larger. If I placed a pede transmission in the middle everything would look normal. The chassis will have 2 diffferent optional trany mounts, one for small transmissions like the MRC, and one for larger transmissions like the 2.2 As for driveshaft, I was simply trying to get everything mocked up, I will be adding a delrin skid for the MRC transmission and centering it so that 1 normal set of stampede driveshafts can be used up front or in the rear, the chassis braces will be square rather then round an I'll even probably have a battery mount for the stock mrc battery. My main concern at the moment is simply seeing how the suspension is going to prefrom, the rest is easy in my opinion. Again thank you for your comments and your concerns please keep them coming! |
| | #14 |
| Rock Stacker Join Date: Oct 2008 Location: Richmond
| I'm very excited about what I see so far. The length of the rear driveshaft is not really a problem IMO and I actually like the look of it. We need to remember this is a scale chassis and the last time I was under my 1:1 my engine and tranny is in the front with a long drive shaft running to my rear. |
| | #15 | |
| | #16 |
| The chassis, blank skid, and braces will be the first on the market, then we will begin adding more options as time goes on. I have multiple things I'm working on right now and limited machine time but I hope to have a few out soon. Cost will be killer like always. The suspension geometry will be up to the user so the posibilitys are endless |
| | #17 |
| Progress |
| | #18 |
| My machinist has been rather busy and I'm trying to get the comp chassis out first.. I may just release this as the chassis, skid combo for now. I just need to finish electronics before I can begin crawlin with it. |
| | #19 |
| Got it running today, so far so good! Needs some fine tuning and need to figure out a sufficient way to mount body then the testing begins |
| | #20 |
| Newbie Join Date: Apr 2009 Location: omaha
| i cant wait to see some action shots! did you get the servo mounted to the chassis? |
| Thread Tools | |
| Display Modes | |
