Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Justin's Street(1.9) Truck: SCX10 Hilux....
Old 11-29-2011, 10:47 AM   #261
Originally Posted by SlickRockSpider View Post
Awesome build. I would expected nothing more. You make amazing scalers. How did you do at the comp with flashpoint (?)tires compared to pit bulls?
Evan
Wow, thanks buddy!
The flashpoints are a pretty soft but the 1.9 pitbulls are on their own playing field. The 1.9 pitbulls are the softest tire I have ever felt but can't run those on this rig, I use this yota as my CLASS ONE rig.
RC4WD came out with two new 1.9 Baja "MTZ" and "CLAW" tires, those tires are way softer then the flashpoint and are legal in CLASS ONE. All in all, I like the flashpoints, with the soft compound but not crazy soft compound, with the stock foams and they still keep good tire height. Hence they don't comprise too much, keeping your ground clearance still intact. Ground clearance is important to a least me in CLASS ONE, so the skid and pumpkins don't keep getting hung up on rocks or etc.
Also, if you haven't seen it already, check out the scale tire size chart I came up with.
Scale Tire Size Charts...
justinart24 is offline   Reply With Quote
Old 11-29-2011, 11:15 PM   #262
Just saw your tire chart...great work! It really needs to be stickied...pm the mods, I can't see it not....sticking! The highlux is looking good too.
Bulldog is offline   Reply With Quote
Old 12-03-2011, 07:58 PM   #263
Thanks buddy!
Old 12-03-2011, 07:59 PM   #264
Small update, painted up a Wild Willys driver.
Tamiya Wild Willy L Parts Tree Driver and Acc.
Mounted some mirrors too, from the axial exterior parts kit.
Axial Exterior Detail Parts Tree - Black
Mounted the sick RC4WD shackles and the light buckets.
RC4WD King Kong Tow Shackle with Mounting Bracket
Axial Light Bucket Set (Black)
Also picked up a Dinky steering wheel...wow...talk about some sick machining!
Dinky RC Yota Steering Wheel #SW007*-*Bodies and Accessories*-*-Scale Parts*-*The Crawlers Store LLC
Old 12-27-2011, 10:24 AM   #265
Default Re: Justin's Street(1.9) Truck: SCX10 Hilux....
Justin, my hat's off to you on this build. The more I look at it, the more I'm impressed. Despite all the time and money(!) I've got invested in the body of my 'Yota, I'm nonetheless considering building another body with a flatbed very similar to yours.
Did you build the bed with all solid bar stock? If so, it must be pretty darn heavy, huh? I'm curious if it hurt the overall performance compared to the plastic bed.
I'm still trying to figure out how you fit so much more under your cab than me! And I even have my servo winch mounted in the back under the bed. What interior are you running? I didn't see how you mounted the body. I assume it's Velcro'd into place?
Honestly, I think my only criticism is your tire choice. I know the Flashpoints work well, but your truck is so nice I think it deserves something more "scale-appropriate".
Seriously, keep up the good work!
BTW, this pic looks so real....
Tommy R is offline   Reply With Quote
Old 12-27-2011, 05:24 PM   #266
Read my replies in green.
Wow, thanks Tommy! This is my current favorite rig of my to drive, love the C1 class!
I did build the bed mostly out of solid stock. It a bit more heavy then the stock bed but at least I have design the metal to be low as possible for good COG...I hope.
Hahaha....after learning how to stuff the guts in the chevy TTC truck, the F350, and the D90....I have some practice. I am running the OG Hilux interior. I mounted the body by putting a piece of delrin sticking off my sliders, and have a bolt on each side below the doors mounting the cab.
I agree, I was at Tammies Hobbies in Oregon this weekend and almost bought the new MTZs.
BTW, thanks for all the kind words. Good luck on you yota....as you can see....my yota has gone through many rebuilds.
Old 12-27-2011, 05:28 PM   #267
Here is a little video of my trip to Lucia Falls this weekend.
Old 12-27-2011, 05:30 PM   #268
very tough looking truck, love the stance it has
CIELO is offline   Reply With Quote
Old 12-30-2011, 01:52 PM   #269
Thanks sir!
Old 12-30-2011, 02:14 PM   #270
The vid is great justin!! Looks like avery capable rig! Have you had a chance to try out the new C1 tires? I have the mtz's and they hook up awesome on my C1xj
kaneohecrawler is offline   Reply With Quote
Old 12-30-2011, 04:06 PM   #271
Oppan Gangnam Style
chino63's Avatar
Looks like it crawls as good as it looks!
Nice job man.
chino63 is offline   Reply With Quote
Old 12-31-2011, 12:11 AM   #272
How are you mounting the body?
Blkfxx is offline   Reply With Quote
Old 12-31-2011, 02:19 PM   #273
Thanks sir!
I was thinking about getting MTZ's but I like the tire high of the flashpoints. I have seen the MTZ's in person, there some what off a soft tire and comprese a bit more then the flash points(Dragging the belly a bit). Maybe when it gets nicer out I will pick up some of the MTZ's, when we have more WARCRC scale comps on mono-ish rock.
Nice job man.
Thanks Dean!I some day want to do yota axles like you but for now...I like the under&overdrive gears in the axial axles.
Here is how I mount my body. I use delrin(yes, I will be trimming the extra off soon) and tap a 3mm hole in it to bolt the body on.
I also tap two holes on the bottom and mount the delrin to the slider.
Old 12-31-2011, 02:29 PM   #274
Well, to help out in the scale points department with this truck, I ordered up two RC4WD Scale Plastic drivers. Per the scale point rules, these have knees....so I will get a total of -4pts with these two drivers wahooooo!
CLICK HERE>>>
Scale Plastic Driver Figure
Here is a shot of the figure in the Dinky R/C repop hilux interior....I run the OG interior.
Dinky RC hilux interior...
CLICK HERE>>> http://www.rccrawler.com/forum/scale...interiors.html
The pieces still mimic the Tamiya interlocking male/females pieces...making a good fit.
Old 01-02-2012, 02:43 PM   #275
very nice rig. really liking the rear bumper.
rockrigcustoms is offline   Reply With Quote
Old 01-09-2012, 01:03 AM   #276
Thanks!
Old 01-09-2012, 01:09 AM   #277
Well, this little truck got its first 1st place at comp today. This is now my really favorite rig to drive.
Here are a few pics from today.
Old 01-09-2012, 02:17 AM   #278
i'm liking the truck but i noticed in the one video that the rear looks like it slides around a little, or maybe its just the v treads not having much side to side traction, either way i like it, the tires set it off though!
turbomini is offline   Reply With Quote
Old 01-09-2012, 10:44 AM   #279
Thanks. As for the rear being loose, I havnt noticed anyyhing funny. But thqt rock at Lucia Falls gets pretty slick wet a bit of rain hits.
Old 01-10-2012, 10:17 AM   #280
This yota is the cats" me mow congrads on winning 1st place
chimney is offline   Reply With Quote
